Old 02-06-2016, 01:04 PM #1
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
Front strut install question
Installed a set of Bilstein 6112s yesterday, was the first time I replaced a strut assembly. I tightened down the top hat and bushings while on the spring compressor nice and snug. However, after driving on them for 50 miles I've developed a very pronounced rattle in the front. I went to check on the bushings/washers this morning and they are movable by hand. Did I goof this up?
Picture of how the setup sits now.
Any suggestions on a remedy?
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 02-06-2016, 01:35 PM #2
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Kinda late now, but you should have taken photos before you started!
No instructions? No notes taken as to how the other ones were configured?
This is what the top of mine looks like.
I'm pretty sure you placed your Lower Cushion Retainers in the wrong place!
You may have DAMAGED your Sub Assembly Supports.
Front strut install question-6112-top-jpg  Front strut install question-8418300-gif
Best Regards,
Saker
Last edited by Saker; 02-06-2016 at 02:12 PM. Reason: added text; illustration added
Old 02-06-2016, 01:59 PM #3
T5RUNNER T5RUNNER is offline
T5RUNNER is on a distinguished road
It looks to me like you have an extra washer under the top bushing that should not be there. I wonder if that means you are missing a washer on the bottom bushing.
Also, 4Runners do not have struts. Why does everyone call them struts?
2010 Trail w/KDSS
1997 Limited w/locker: sold
T5RUNNER is offline   Reply With QuoteReply With Quote
Old 02-06-2016, 02:11 PM #4
Jeremy556's Avatar
Jeremy556's Avatar
Thank you. That is a huge pet peeve of mine.
Coil-over shock assembly in a double wishbone suspension
Macpherson strut assembly
Old 02-06-2016, 02:17 PM #5
Saker's Avatar
Saker's Avatar
Wording like this doesn't help any either......
Genuine Original Equipment Replacement Parts 2014 Toyota 4Runner SR5
All Vehicles - 2014 - Toyota - 4Runner - SR5 - FRONT SUSPENSION - FRONT SUSPENSION - STRUTS & COMPONENTS
Best Regards,
Saker
Old 02-06-2016, 02:41 PM #6
Xtremluck's Avatar
Xtremluck's Avatar
Thanks for all the info guys. I guess sometimes you have to learn the hard way. At the shop getting everything corrected. Expensive mistake but at least I'll know for the next time.
Old 12-30-2016, 05:47 PM #7
The Waco Kid's Avatar
The Waco Kid The Waco Kid is offline
The Waco Kid will become famous soon enough
OK, I'm having a similar issue on my driver side front, but mine are installed exactly as you have them pictured @Saker . I've installed, removed, and reinstalled but I'm still getting the rattle from the top washer/retainer. I can't tell if my lock nut isn't bottoming out or threading correctly, or if I have a problem elsewhere. Should I add a shim to the top to help compress the washer on the bushing?
Everything has been installed per the instructions from Bilstein, and it's identical to what I did on the passenger side, except that side has no issue. The passenger side has more preload as I'm at a clip higher on that side to offset the passenger lean I had. This was recommended in Bilstein's instructions, so I don't think that could be the cause.
I'm really at a loss for why it won't compress completely.
2014 Classic Silver TE w/ KDSS - The Waco Kid's Build and Adventure Thread
Wife's Ride: 2017 RX 350
Past Vehicle:2001 Dodge Dakota Sport 4.7L V8 Quad Cab.
The Waco Kid is offline   Reply With QuoteReply With Quote
Installed Bilsteins 5100 last night... front strut question Patrickg 4th Gen T4Rs 14 07-24-2015 02:55 PM
OME 881 Coils-3" Lift Front Strut Assy w/KYB Gas-A-Just strut-3rd gen runner STRRAYNGE For Sale: Suspension/Wheels/Tires 7 04-30-2012 09:44 PM
Daystar Front 1" Strut Spacers Install Austin.Hales 3rd gen T4Rs 8 03-27-2012 11:27 PM
Last suspension question I promise!! Front strut bolts? Jc12 3rd gen T4Rs 16 02-21-2012 02:56 AM
noob, FJ shock/strut and front spacer question. NorCalKevin 4th Gen T4Rs 13 06-27-2011 12:56 AM
