03-20-2016, 02:16 PM
Real Name: Sean
Real Name: Sean
Rooftop Tent
Anyone out there in T4R land running an RTT on the factory roof rack and crossbars? It is getting very close to "that time of year" where I disappear each and every weekend into the hills, and so I'll need to mount up my RTT. This is my first T4R and I'm wondering if the factory roof rack and bars are up to the task, or if I should just bite the bullet and order a Gobi.
Anyone having success with the factory rack?
SOLD - 2016 Mag Grey TRDP, 40" Rigid E Series, Gobi Stealth, BFG KO2s 285/70, Tepui, BAMF sliders, Fox 2.5 DSC, Icon Delta Joint UCAs, SCS RAY 10 Matte Bronze
Current - 2020 Raptor....yeah, yeah, I know...but it is a helluva lot of fun!
03-20-2016, 02:30 PM
03-20-2016, 02:38 PM
Real Name: Max
Real Name: Max
Hey fellow Bay Area owner!
There are a few threads on here that go over this (hint: search using the above search bar)
To answer the question, yes you can put them on the factory rails, but because the stock crossbars are so low, getting one attached to them is a PITA. I bought my truck in Bend, OR, home of CVT. I went to rent one for a night and couldn't reasonably get it on without risking scratching the roof paint, or destroying my forearms. Solution? Install a set of Thule or Yakima load bars and you'll be set. Check out my build, and you will see what I am talking about.
Good luck! The MGM TRDP looks awesome!
03-20-2016, 02:50 PM
Here's how its done, I did it this way also up until I got may Gobi and it is a pain!!!!
Jicko Build Thread ...
Gobi and the Axia mounts is the way to go if your taking it off often, hauling the tent with you everywhere gets old real quick.
KiruxaT4R Build & Photos Thread
2014 4runner Trail, KDSS, 6112's w/King 650# springs, 5100, 295/70/17 DuraTrac, 4.88 Nitro Gears, Harrop Front E-locker, ToyTec 2.0 rear springs, Metal Tech Sliders, Full RCI STEEL skids, Prinsu Rack, C4 Fab Fuel Tank Skid, C4 Lo Pro bumper with High clearance, X20 winch, ARB Twin Compressor, Northstar 27F, Precision LED conversion, NoCo onboard charger, Icon Delta Joint UCA's, Dobinson's Rear Drawers.
1989 4Runner: All Stock
Real Name: Sean
Real Name: Sean
Thanks man! Awesome point on the bolts vs. roof clearance. I had thought about that and was going to test fit them today to check clearance, so you just saved me some work!
Nice Bronson! Message me if you ever want to get out and terrorize some dirt!!
03-20-2016, 03:09 PM
Real Name: Sean
Real Name: Sean
Awesome, thanks!
I leave the tent on for all 3 seasons and only remove it for winter so I'm not too concerned about the on/off hassle. Those mounts for the Gobi look pretty slick!
Much appreciated!
03-20-2016, 05:35 PM
Real Name: Mac
Real Name: Mac
I would NOT go Gobi again if the plan is to run a RTT - I'd get a flat rack to allow it to sit lower - if however you disagree then buy my Gobi and I'll buy one that works better! ;-)
_________
'15 TRDP - UnModified but Nicely Accessorized
03-20-2016, 06:19 PM
2015 Trail Edition, NAV, w/o KDSS. Stock. Sams Club Armor Floor Mats. Eclipse Sunshade. N-Fab Steps. Autohome AirTop RTT. Norcold MRFT40. Dual Battery w/Budbuilt Battery Tray. CTEK Dual Battery DC Charger. Smittybilt Beaver Tail. FJ shifter. WILCO Offroad Hitchgate. Rotopax Gas Cans.
03-20-2016, 08:31 PM
Real Name: Sean
Real Name: Sean
Is it the Gobi stealth, or the standard Gobi? If I go the Gobi route, I'd go with the stealth most likely.
03-20-2016, 08:32 PM
Real Name: Sean
Real Name: Sean
03-21-2016, 07:43 AM
Real Name: Mac
Real Name: Mac
i have the stealth
and in fairness I went with the larger Rainier and it overlaps on the sides and covers all but about 8" front to back
here it is open and closed
_________
03-21-2016, 11:58 AM
Real Name: Sean
Real Name: Sean
i have the stealth
I think it looks darn good. I have the Tepui Kukenam so I don't know that I would the same coverage/overhang issues you have. That being said, if we lived closer, I'd probably take it off of your hands. I can't even begin to imagine what it would cost to ship the rack and the ladder out here to CA.
03-21-2016, 11:59 PM
Yakima Racks
We are also using the Yakima crossbars and secure the tent with the Yakima snaparounds. This allows me to load and unload the tent using only 4 mounting bolts. I also installed the Racor lift, available on Amazon for about $100.
Roof Top Tent on Yakima
I tried mounting directly to the roof rails, but the tent rails scratched the rails pretty easily and it was more cumbersome to remove the cover to install the annex.
We will be upgrading the the Baja Rack Flat Utility rack, soon.
Good luck!
Wild_Turkey Build Thread
2015 SR5 Premium 4x4 / 3rd row seat: Bilstein 6112/5160 @2.5"F/2"R // Total Chaos UCA // C4Fab Rock Sliders / Fuel Tank Skid / Lo Pro Winch Bumper // 17x8 FN F(X) Pro Wheels // BFG AT KO2 275/70R17 // ARB Compressor/ Fridge/ Rear Air Locker // KC HiLites // James Baroud Grand Raid // Canvasback cargo liner // Rear Diff Breather Mod
03-22-2016, 01:28 AM
Real Name: Sean
Real Name: Sean
Good luck!
Man, I'm jealous of that hoist system!
Looks like I'm picking up a Gobi stealth rack this weekend, so that pretty much takes care of that I guess.
