TRDpro suspension on a 2011, front sits higher.
Hbryanlopez
Recently installed a set of trdpro suspension on my 2011. The ride is great by the way in comparison to my bilstein 5100. For those of you who might be thinking about doing this, keep this in mind. My 2011 sr5 sat an inch higher than your actual trdpro, which was actually perfect. This leveled me out, this was also higher than my previous .85 setting on my bilstein.
My issue was that the trdpro suspension I bought already had the Toytec leveling spacer of 1 inch which perfectly leveled the 2015 trdpro I bought the suspension from. Once installed on my 2011 my t4r had a bad rake and I had to redo the installation again without the spacer. So if you're in the same boat, I just thought you should know. Some photos bellow.
trdpro on left sits 1inch lower than my 2011 sr5 with trdpro suspension.
This is how it looked with the 1inch toytec spacer which leveled out the 2015 trdpro i bought the suspension from.
