10-06-2016, 02:21 PM
IOS 10 won't pair with audio bluetooth
Hi All-
On my 2016 trail I have discovered that my iphone 6S with the IOS 10 update will not pair via bluetooth to my sound system so I can't play my itunes music or use the speaker phone over the sound system. Anyone else having this issue? I've tried it with my phone and my son's iphone that also has the IOS 10 update and neither device can pair now to the 4runner system. Any insights on how to fix this would be appreciated!
2016 Trail with Softec, KDSS, 3" lift, 285/70/17 BFG TAKO2's, Nfab rails, Bajarack roof rack, double 13.5" LED's forward, double LED's rear.
10-06-2016, 02:23 PM
Some people (myself included) are having an issue iOS 10 not pairing with any bluetooth speaker as well as battery drain.
Back up your phone and roll back to 9.3.5
10-06-2016, 02:32 PM
Real Name: GD
Real Name: GD
I would see if the dealer could check for an update, my 16 works fine with ios 10.0.2
'16 SR5 Premium
10-06-2016, 02:46 PM
Real Name: Kris
Real Name: Kris
Mine pairs, but the music cuts a lot and sounds fast-forwarded. I just turn Bluetooth off and on again, and it's fine after that.
2016 Trail Edition Premium
KF5UXO
10-06-2016, 03:26 PM
interesting....
the issue is when I turn bluetooth on and try and discover available devices, the 4runner never appears in the menu as an option. Other bluetooth devises show up but not the 4runner. Is there a max # of bluetooth devices the 3runner can recognize? right now it has my old phone and my daighter's phone shown as available devices so perhaps it will only allow up to 2 devices in it's memory? If so how do I clear out the other old phone I no longer use from the list stored in the 4runner system?
10-06-2016, 03:35 PM
Originally Posted by Woodsong
interesting....
Has to be a way to unpair, delete, forget, remove etc.... from the HU!
Not in T4R so can't tell for sure.....
I bet if you do a reset of the bluetoofffff, that'll do it.
Best Regards,
Saker
10-06-2016, 06:05 PM
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
10-06-2016, 06:35 PM
I had a problem where my Spotify music would suddenly pause and it would never be able to play again. What I did was:
turn off Bluetooth in phone
delete old pairing of iPhone on Toyota head unit
I reinstalled IOS 10 on phone
Turned on Bluetooth on phone and paired with Toyota
didn't have a problem since then and its been about a week since I tried this
10-06-2016, 07:41 PM
interesting....
Page 49 of the Audio-Nav manual states that 5 phones can be paired. Page 50 details how to delete a device. Assuming you have an Entune system...
2016 SR5P Classic Silver - Stock for now
10-06-2016, 09:13 PM
Real Name: Justin
Real Name: Justin
I had no issues after updating my iOS on my 6. Upgraded to a 7 and still no issues.
I did go through the system and delete the old phone and pair the new one. I'd start with that and see if that fixes it for you.
2010 4Runner SR5 Magnetic Gray: Radflo / Icon + Metaltech / Total Chaos / Dirt King / SCS Stealth 6 / BAMF Sliders + Pelfreybilt Bumper / PRINSU / Indel B / 2014+ IS 350 Retrofit
2012 GX460 Premium Black Onyx: Stock af
10-06-2016, 10:29 PM
I have the old head unit and I am not having any problems.
10-06-2016, 10:52 PM
LOL on the android "problem solved" link. haha
Ok...will read the manual to see how to delete old phone and see if I can get it to work tomorrow!
10-07-2016, 02:10 PM
Same issue here, also did this before the upgrade to ios10
