Old 11-04-2016, 09:28 AM #1
kuyaariel kuyaariel is offline
kuyaariel is on a distinguished road
Alright, decided on the Black Yuma Wheels. Have a few questions...
After some deliberation, I decided on the Black Yuma wheels to go onto my white 2016 Blizzard white t4r. I will also have someone else do the work for me (Discount Tire). I have a few questions to those more knowledgeable than I (which is pretty much everyone on this board)
Which rim will I need? I plan to reuse my stock tires. I assume it's the 17x8, with the 6x? bolt pattern. What is the "?" in the bolt pattern? This goes to my next question...
Will I be able to reuse my stock tires? I know my stock rims are 17x7.
Will there be special instructions needed as far as spacers?
I intend to get 5. Will I be able to replace the spare with this wheel?
Will I need to get special lug nuts?
And finally, where is the best (and least expensive) place to buy the 5 rims? I've seen some on Amazon and Ebay.
Thanks!
kuyaariel is offline   Reply With QuoteReply With Quote
Old 11-04-2016, 09:56 AM #2
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
It's typically not a wise idea to mount tires on a different rim.
Even remounting them in a different position can cause problems, and that's why they're supposed to mark them when they do so.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 11-04-2016, 10:38 AM #3
mountain mike's Avatar
mountain mike mountain mike is offline
mountain mike is on a distinguished road
Thanks!
Your bolt pattern is 6 on 5.5 or 6 on 139.7
Yes you can reuse your stock tires
As for spacers it is going to depend on the backspacing that you get on the new wheel. I want to say that the factory backspacing is around 4.75 (someone fact check me on that). If you go with a wheel with less backspacing it will stick out further. I have found that the more they stick out the more you will rub.
I have never heard of this before and I have switched tires on an off rims twice a year for years on two cars (snow tires in Colorado) and have never had an issues.
Can you please expand on the potential "problems"
2001 Black Sport Package
mountain mike is offline   Reply With QuoteReply With Quote
Old 11-04-2016, 01:14 PM #4
Thank you for answering my questions. Just a few more quick ones...
The one's I've seen on Ebay have zero offset. Should I be getting those?
Do I need to get special lugnuts?
Old 11-04-2016, 02:42 PM #5
Watchdogg's Avatar
Watchdogg Watchdogg is offline
Real Name: James
Watchdogg is on a distinguished road
Watchdogg's Avatar
Real Name: James
Looking at these wheels online it says acorn lugnuts required. So the answer is probably yes. You will need new lugs. Just checked my Trail wheels and they're 4.75 backspace.
Watchdogg is offline   Reply With QuoteReply With Quote
Old 11-04-2016, 03:37 PM #6
skratchd's Avatar
skratchd skratchd is offline
Real Name: John
skratchd is on a distinguished road
skratchd's Avatar
Real Name: John
Make sure you get acorn nuts with a sleeve that centers the wheel on the hub and uses at least 3/4 of the threads on the stud. Otherwise Toyota will not rotate your tires. Apparently it's a liability issue.
Sent from my SM-G360T using Tapatalk
skratchd is offline   Reply With QuoteReply With Quote
Old 11-05-2016, 01:07 AM #7
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Don't where you're located but sometimes 4wheel parts has sales ? Other tire & wheel online it's a good wheel !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 11-05-2016, 03:02 AM #8
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
FS: (4) SCS MATTE BLACK F5 WHEELS and BLACK SPLINE LUGS $500 SHIPPED liv2bike For Sale: Suspension/Wheels/Tires 1 09-26-2015 05:48 AM
Black Lug Nuts for Black Rock Yuma Wheels ? phillyd2 5th gen T4Rs 22 11-17-2013 10:10 AM
Black Sport on Fort Lewis. Duratracs and black TRD Wheels. A.Wilson013 3rd gen T4Rs 7 03-23-2011 10:08 AM
Pretty much decided on a 4Runner, got some questions on a Limited V8 kseto 4th Gen T4Rs 21 03-08-2005 10:50 AM
