02-20-2017, 03:00 PM
#61
Banned
Banned
i wish the plans weren't so expensive, my wife wanted me to get one until she saw it was $35/month
02-20-2017, 03:02 PM
#62
You can enable or disable the plans as needed or when you do trips.
I don't own a 4Runner anymore.
02-20-2017, 03:05 PM
#63
Banned
Banned
$35/month is the no-contract plan
02-20-2017, 03:06 PM
#64
You have an activation cost, but you also can turn OFF your plan entirely.
02-20-2017, 03:10 PM
#65
Banned
Banned
but then when you want to use it its $35/month, i.e. the no contract price
i wish it wasn't that expensive, $35 is more than its worth to me until i take longer trips where i am more remote
02-20-2017, 03:16 PM
#66
Real Name: Jacob
Real Name: Jacob
It looks to me like there's an $11 a month plan too, or $14 for the "freedom" version, according to their PDF here https://explore.garmin.com/en-US/inr...es-us-only.pdf. I ordered it from Amazon and it said backordered about 4 weeks, so I'll find out for sure when I get the thing.
02-20-2017, 03:18 PM
#67
If you have someone with a promotive account you can get the SE version for like 216 dollars.
I do the 35 dollar a month plan which is 40 incoming/40 outgoing. Do not give away your delorme account address, as it's VERY easy to burn through your messaging plans.
Also realize depending on line of sight it can take 6-8 minutes to send a message. But it's a great device.
02-20-2017, 03:22 PM
#68
Real Name: Jacob
Real Name: Jacob
Whats a promotive account? Not too late to cancel my order and get it cheaper.
02-20-2017, 03:42 PM
#69
Banned
Banned
its good enough for emergency but not anything beyond that, the $35 plan is the cheapest plan for tracking and messaging
02-20-2017, 03:58 PM
#70
Real Name: Jacob
Real Name: Jacob
That's really what I'm looking for, emergency contact. I don't think I really need the messaging, but I'll play with it and find out.
02-24-2017, 04:54 AM
#71
Real Name: Dave
Real Name: Dave
iPad mount on console side
Originally Posted by phillyd2
Ram Mounts! Sturdy enough for offroad. Removable. Doesn’t interfere with passenger.
This is the simplest and sturdiest idea I've seen. I couldn't get my console cover to budge but if I can I will give this side mount ball a try.
For now I ordered two large RAM Mount clamps to fit the side of the long slot next to the shifter and I'll give the whole system a try. With an iPhone6 and an iPad2 I ordered the mounts and clamps to fit. I want the iPhone close at hand so I can text while driving. Just kidding. I want to be able to view traffic reports on the iPhone and maps on the iPad. Photos to follow when I get it delivered and set up.
I find the Toyota console navigator to be cluttered with controls and shaped horizontal when you want to see where you're headed not what's out on the sides. Most of the screen is useless because of the wide format.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
02-24-2017, 07:51 AM
#72
Real Name: Dave
Real Name: Dave
Them Be Me Mods - 2011 Black Limited / Trail Mutt
02-24-2017, 01:37 PM
#73
Real Name: Dave
Real Name: Dave
Console cover removal
Thanks Dave.
@ phillyd2
That was really helpful. I'll give it a try again.
Dave
02-24-2017, 02:31 PM
#74
Real Name: Dave
Real Name: Dave
Originally Posted by DesertCanyons
Thanks Dave.
@ phillyd2
Dave
No problem. As mentioned, pull to the point you think it's breaking and then pull a little more to release the clips. You will laugh how easy it was
02-25-2017, 02:25 PM
#75
Banned
Banned
I used the same setup as
@ phillyd2
, however I added a bracket to stablize the plastic.
Even with aluminum brackets behind the plastic for the ball mount, the actual plastic itself is not firm enough to prevent wobbles, the bottom pushes in and out too easily.
What I did was fab a quick little aluminum bracket that supported the bottom to a bolt so that I can pull in the bottom to keep it tight and prevent wobble. This was a quick proof of concept, I am going to actually make a bracket that all the screws can attach too which will have a tab like this to mount to a bolt. It is screwed tight to the plastic and then another nut (and washer and lock washer and backer nut) is used to pull the entire screw towards the bolt.
Right now I have the ram mount post extension friction fit with electric tape to make sure I like the height before PVC gluing the post together, but I think the location works well with my first cut.
