Old 04-20-2017, 03:11 AM #16
DeepSea's Avatar
DeepSea DeepSea is offline
Real Name: Nate
DeepSea will become famous soon enough
DeepSea's Avatar
Real Name: Nate
Few more pics
Installed 1" body lift-img_5466-jpg  Installed 1" body lift-img_5469-jpg  Installed 1" body lift-img_5477-jpg  Installed 1" body lift-img_5483-jpg  Installed 1" body lift-img_5489-jpg  Installed 1" body lift-img_5493-jpg
2016 Quicksand TRDP, Eibach 2.0 PRO Kit, 285/70/17 Falken Wildpeak MT, 17x9 SCS F5, Prinsu Roof Rack, Canvas Back, Weathertech
Build: http://www.toyota-4runner.org/5th-ge...ld-hawaii.html
Filmmaker: https://www.youtube.com/user/freedomriding Instagram: https://www.instagram.com/freedomedia/[/SIZE][/SIZE]
DeepSea is offline   Reply With QuoteReply With Quote
Old 04-20-2017, 05:20 AM #17
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Originally Posted by wfo9 View Post
1" starts messing with the fan shroud clearance with engine torque... typically. 1/2" is no issue for sure. 1" little things start to be noticed...
Originally Posted by DeepSea View Post
....... Also, I had no issue with the fan nor shroud rubbing at all. Not sure why you think engine torque would be reduced?
I don't see where he stated "reduced"....
I do think he was referring to....... when the engine torques, it could possibly cause contact fan to shroud.
Best Regards,
Saker
Old 04-20-2017, 06:35 AM #18
deedubb's Avatar
deedubb deedubb is offline
deedubb is on a distinguished road
deedubb's Avatar
I may end up doing a 1/2" up front after I get the LT on up front. Should allow for a bit more up travel before being in to the fender.
Can you do a partial body lift in the front like that? Would you use 2 or 4 of the 8 spacers that come with the BL kit?
2016 MGM TEP with KDSS | Dobinsons 3" front - 2" rear springs | Dobinsons Diff Drop Kit | Bilstein 5100's | JBA UCA's | 17" SCS SR8 | 285/70/17 Falken Wildpeak M/T's | Ecotechne roof rack | CVT Mt Denali Extended Pioneer | Rago ditch light brackets with side shooter ditch lights | RCI sliders
deedubb is offline   Reply With QuoteReply With Quote
Old 04-20-2017, 01:46 PM #19
Ph3n0m427 Ph3n0m427 is offline
Ph3n0m427 is on a distinguished road
Few more pics
Did you cut your fan shroud or just took out the spacer where the screws go to hold it in place?
I have the same BL from Pat and I like it, only issue on a limited or early 5th gen is that the bottom part or front bumper cover wont line up correctly with the holes and the top of the back bumper isnt as sturdy so i had to add padding to make it solid
Ph3n0m427 is offline   Reply With QuoteReply With Quote
Old 04-20-2017, 02:03 PM #20
toku58's Avatar
toku58 toku58 is offline
toku58 is on a distinguished road
toku58's Avatar
does the new tires stick out from the fenders? That was the size I originally wanted but I got the 285 KM2's like your old set up, because of Recon.
2016 SR5 4WD W/3rd row seating, Bilstein 5100's all around, front set at .85" with 2" ToyTec spacers,and Daystar 1.5" in the rear. SPC UCA's, ToyTec Diff drop, BMC, fender liner relocated and lower bumper trim. LED's all around, Rola cross bars, Mamba M14 17x9 4.5" BS wheels, BFG KM2's 285/70R17, aftermarket MBRP stainless exhaust tip. No more mods on the runner!
toku58 is offline   Reply With QuoteReply With Quote
Old 04-20-2017, 02:52 PM #21
wfo9's Avatar
wfo9 wfo9 is offline
wfo9 has a spectacular aura about wfo9 has a spectacular aura about
wfo9's Avatar
Sorry, I meant that I may do a 1/2" body lift when I put long travel up front to allow for more fender clearance. It came out wrong. I would not recommend only body lifting one end...
wfo9 is offline   Reply With QuoteReply With Quote
Old 04-20-2017, 05:18 PM #22
DeepSea's Avatar
Real Name: Nate
DeepSea's Avatar
Real Name: Nate
No because the backspace and offset of these wheels keep them inside
Installed 1" body lift-img_5485-jpg
Old 04-20-2017, 05:20 PM #23
DeepSea's Avatar
Real Name: Nate
DeepSea's Avatar
Real Name: Nate
Not sure about that question
Old 04-20-2017, 05:27 PM #24
DeepSea's Avatar
Real Name: Nate
DeepSea's Avatar
Real Name: Nate
Didn't have to do anything to the fan shroud and double checked that the fan spun freely before starting the truck. I've driven 100+ miles since install and all is good.
For the front bumper, I did have to move it up in order for the bumper cover and fenders to seam tight because they wouldn't without. It had a slight 1/8" gap so I decided to move the bumper up. There are 8 studs it mounts to, which 6 are in a vertical column. That row of studs allow it to perfectly go up one inch. So now I have 4 of the 8 bolts holding the bumper but it's still plenty solid. Welding it is an option if you feel differently. Ive attached a pic.
Installed 1" body lift-img_5461-jpg
Old 04-20-2017, 05:28 PM #25
DeepSea's Avatar
Real Name: Nate
DeepSea's Avatar
Real Name: Nate
I see what you mean. So far, so good with no fan/shroud rubbing.
Old 04-21-2017, 01:48 AM #26
When i installed mine i didnt do anything to the fan shroud, i left it alone but then i could hear a noise coming from the engine when i break hard cuz the engine would dip down. i checked the fan and i noticed that there was some wear so i took the spacer out in the shroud and it fixed the noise. Double check your fan blade if you start hearing a noise when you break hard.
Old 04-21-2017, 09:57 AM #27
DeepSea's Avatar
Real Name: Nate
DeepSea's Avatar
Real Name: Nate
Thanks for sharing. I haven't noticed that yet but also haven't had to brake hard yet either. Where is their a spacer in the shroud?
Old 04-21-2017, 10:37 AM #28
take out the screws holding the shroud, you will notice a copper barrel spacer where you took the screw out. Push that out and put the screw back in to secure the shroud in place. this will give you close to a 1/2" clearance
Old 04-21-2017, 10:52 AM #29
DeepSea's Avatar
Real Name: Nate
DeepSea's Avatar
Real Name: Nate
Thanks b! I'll definitely keep this in mind now if I hear any fan/shroud rub
Old 04-21-2017, 11:04 AM #30
DeepSea's Avatar
Real Name: Nate
DeepSea's Avatar
Real Name: Nate
Originally Posted by Tlowe View Post
I'm expecting a video about it on your youtube soon! Your videos are absolutely top notch and I am super curious about these blocks. I knew it was possible but I hadnt seen a definite "kit" yet. I find it quite hard to believe that the only thing that cause interference or is affected by spreading the body and frame apart by an inch is the steering shaft.
Thanks b! I'm taking the 4R to the trails tomorrow so I'll have some footage with the BL and 305s to add to the next YouTube episode. The steering shaft has one bolt you loosen before the BL spacers install so the yoke can slide up then just retighten once done.
FS: 4th Gen 1" Toytec Body lift, 1" leveling front spacer lift mcwalke2 For Sale: Suspension/Wheels/Tires 6 02-05-2016 12:59 PM
2" body lift installed Magnum 3rd gen T4Rs 17 09-25-2013 04:30 AM
Body Lift Installed BlackYotaSport3 4th Gen T4Rs 19 01-22-2011 06:04 PM
2" R.B. body lift installed driffter33 Gallery 13 04-28-2010 12:38 AM
1" body lift installed J-money$$$ 3rd gen T4Rs 7 07-09-2009 06:38 AM
