Old 05-20-2017, 03:01 PM #1
jawkdna's Avatar
jawkdna jawkdna is offline
jawkdna has a spectacular aura about jawkdna has a spectacular aura about
jawkdna's Avatar
Battery Upgrade Opinions: 31 vs 34
So I've already searched the forum extensively on battery upgrades...
I am looking to upgrade from the stock 27 Panasonic to a 31 or a 34 battery (Odyssey) and I am curious on some opinions...
The truck is 6 months old and I am slowly building it up to be a surfing exploration adventure rig, no rock crawling more overlanding type stuff. I won't be adding a winch and I plan on keeping stock bumper, but I will be adding lights and some electronics and upgrading the suspension...
31 Pros - Really High CCA and power
31 Cons - Weight, Mild maintenance, battery cable modifications to fit, bigger battery tray
34 Pros - Less weight, No battery cable modifications to fit, No battery tray
34 Cons - Less CCA and power then the 31 (but still better than the 27 stock)
I guess what I am asking here is, money aside, is the weight of the 31 worth the gains over the 34 on a rig for mild adventuring.
Everyone's Mileage May Vary...
but anyone with some experience with these in their truck goes further then my googled knowledge...
"Outgunned, outnumbered, though never outclassed" - Bolt Thrower
XXX
Toyota Trucks Patches, Pins & Stickers | 2016 Trail Premium Edition | Icon Stage 2 | KO2 285s | BlackGate Customs KDSS Rear Sway Bar Drop Kit | RCI Skids | Pelfreybilt Sliders | Gobi Stealth Rack | TRD CAI | Sprint Booster | DuroBumps | Stahlbus Oil Drain Valve
jawkdna is offline   Reply With QuoteReply With Quote
Old 05-20-2017, 05:56 PM #2
Engineer's Avatar
Engineer Engineer is offline
Real Name: Charles
Engineer has a spectacular aura about Engineer has a spectacular aura about
Engineer's Avatar
Real Name: Charles
I am still on the OEM battery but I think for your needs the 34 would be ideal - I am leaning that direction when the time comes. It really does depend on if you need the extra capacity but the reality is if you do you can always get a solar charger, run the truck for a while, or have a small Honda generator (pick you favorite brand)
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
Engineer is offline   Reply With QuoteReply With Quote
Old 05-20-2017, 06:48 PM #3
"krax" "krax" is offline
"krax" is on a distinguished road
I've got a group 34 Odyssey. No issues, obviously, but I've never run it down so I couldn't tell you if it's got enough juice for you.
Just make sure you get the spacer for it. It's like a $4 part from Odyssey that makes the new battery tall enough to work with the factory tie-down.
"krax" is offline   Reply With QuoteReply With Quote
Old 05-20-2017, 11:00 PM #4
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
For what it's worth, I went with the Group 31M. For less than $50 for a battery tray and a couple of cable extensions it pretty much drops right in. (At least in my 2011 Trail it did) A few bucks to fix up the battery tie down and you're good to go.
If your at all worried about running out of juice, I would go with the 31M just because you can......
nglayton is offline   Reply With QuoteReply With Quote
Old 05-21-2017, 01:55 AM #5
Ray Dunakin's Avatar
Ray Dunakin Ray Dunakin is offline
Ray Dunakin is a splendid one to behold Ray Dunakin is a splendid one to behold Ray Dunakin is a splendid one to behold Ray Dunakin is a splendid one to behold Ray Dunakin is a splendid one to behold Ray Dunakin is a splendid one to behold Ray Dunakin is a splendid one to behold Ray Dunakin is a splendid one to behold
At what point does it become necessary (or at least wise) to upgrade the battery and/or alternator?
I don't need a winch, but I would like to add some lights eventually. And I currently have a lot of electronic gadgets (radar detector, dash cam) that either operate off the 12v outlets, or have batteries that I'm frequently recharging via the outlets (several cameras, drone batteries, iPhone, etc).
Ghost towns, mines, and more: www.raydunakin.com
2016 silver Trail Edition w/KDSS; BudBuilt sliders w/full tread plate; upgraded rear hatch lift struts;
BFG KO2 265/70/17; Gobi "no-rise" Stealth rack w/ladder; MetalTech front bumper;
King coil overs, upgraded springs, ~1.5" lift; RCI skid plates.
Megaweapon's build/adventure thread
Ray Dunakin is offline   Reply With QuoteReply With Quote
Old 05-21-2017, 09:54 AM #6
weeeee's Avatar
weeeee weeeee is offline
weeeee will become famous soon enough
weeeee's Avatar
You covered most of the pros and cons in your first post. Ideally if you want to go with the largest battery you can keep in the stock location to keep up with power requirements etc. A winch, fridge, air compressor has a huge impact on draw. A group 31 has about double the capacity of a 35, and a marginal bump from a 34.
That being said, I've had issues with the sheet metal cracking from underneath the battery location. I welded it up the first time, now it's cracked again in two different locations. I may end up with two smaller batteries to better distribute the weight.
IG @go.xplre
weeeee is offline   Reply With QuoteReply With Quote
Old 05-21-2017, 11:26 AM #7
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
I know you are asking for 31 or 34 but you might want to consider 24 series (it also fits with stock hold-down bracket:
<<<< is offline   Reply With QuoteReply With Quote
Old 05-21-2017, 12:08 PM #8
e60ral e60ral is offline
Banned
e60ral will become famous soon enough
Banned
If all you are doing is adding lights and stuff just stay 24
Sent from my SM-G930V using Tapatalk
e60ral is offline   Reply With QuoteReply With Quote
Old 05-21-2017, 01:02 PM #9
LawnDart's Avatar
LawnDart LawnDart is offline
LawnDart will become famous soon enough LawnDart will become famous soon enough
LawnDart's Avatar
I haven't had those issues, but I know you've run your rig pretty intensely over some crappy terrain.
Victor, what tray were you using? I found the Pelfrey cage eliminated any hopping or vibration caused by such a big battery. I'm not saying it would have eliminated your cracking, but it might have staved it off.
I run 2 group 31s, one in front, and one in the cab. But I'm running a big inverter and a few other things inside for work and camping (fridge, etc).
I don't own a 4Runner anymore.
LawnDart is offline   Reply With QuoteReply With Quote
Old 05-21-2017, 01:40 PM #10
Jeremy556's Avatar
Jeremy556's Avatar
I just finished repairing mine for the 3rd time. I'm installing that battery cage this time to see if it makes a difference.
I also have a strut that connects to the radiator support, but not sure if I'm going to connect it just yet. It seemed to have made the cracking worse when I connected to the top of the stock tie down.
Old 05-21-2017, 01:43 PM #11
LawnDart's Avatar
LawnDart's Avatar
I had an aftermarket steel battery bottom tray, and no matter what I did the battery would twist and torque around no matter how tight i had the battery strapped down.
The Pelfrey cage just doesn't go anywhere. I am not saying that would eliminate the issue, but I think it'd help.
Old 05-21-2017, 03:13 PM #12
Banned
Banned
Does the pelfreybilt cage bolt down? It looks like it just uses the factory j hook locations
Old 05-21-2017, 03:15 PM #13
LawnDart's Avatar
LawnDart's Avatar
It uses J hooks but it uses huge and beefier j hooks.
Old 05-21-2017, 04:25 PM #14
Banned
Banned
you can buy beefy j hooks for $5
Old 05-21-2017, 04:45 PM #15
LawnDart's Avatar
LawnDart's Avatar
There's more to the design than just bigger hooks, and I apologize if I'm not describing it in detail. I wish I'd taken photos during the install at Goose Gear last October, but the cage itself is much more substantial and just a strong top tie down.
It certainly helps keep the Group 31 in place.
LED bulb upgrade. Opinions rocket67 5th gen T4Rs 22 06-03-2016 08:53 PM
Battery and Housing Upgrade tmcintosh3 4th Gen T4Rs 15 03-26-2016 12:11 PM
Battery Upgrade Suggestions Stellar 4th Gen T4Rs 16 01-21-2016 04:10 PM
Stay factory or upgrade opinions please. 804runner 3rd gen T4Rs 6 07-27-2012 04:23 PM
It's time for a Brake Upgrade. Need Opinions CoMarc 3rd gen T4Rs 3 06-01-2010 10:06 PM
