Thread Tools Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
Old 06-08-2021, 05:14 PM #106
KRose KRose is offline
KRose is on a distinguished road
Great question. They were a somewhat unknown entity and had some negative reviews when I bought tires last. that said, I was looking at them on the discount tire site last night and noticed the 3 peak rating. I have no experience with that brand so far so i have some reading up to do. I see it's E which is good for me and my habit of driving around sharp rocks. Thanks for the input!
KRose is offline   Reply With QuoteReply With Quote
Old 06-09-2021, 10:06 AM #107
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
Originally Posted by nb rob View Post
that's interesting--I feel the opposite.
When I think narrow, I think offroad.
When I see wide tires and spacers, I think it's just for cosmetics
And that makes sense, because few put on skinny tires for looks vs. the other way around where wide tires are often used for looks.
But, wider tires can offer more grip, especially in aired down situations when the tire is allowed to wrap around the rock or root. Larger surface area of the tire allows it to wrap more and create more traction. Similar with pea gravel/loose rock and mud.
There really isn't a wrong answer here, because I bet that real life performance of skinny vs. wider isn't all that noticeable, especially when we're talking 10.5" vs 11.5" or so -- it's not that major. So it all comes down to personal preference and priorities.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 06-09-2021, 12:31 PM #108
spartacus's Avatar
spartacus's Avatar
Skinnier tires will be fine for most because they will never even come close to pushing the boundaries of the vehicle or the tire. Folks like the look of a tire. If you are an experienced off roader you are good with almost any tire since you will pick a line depending on the capability and limitation of your overall suspension, tires, locked or not and the vehicle etc.
Get the tire that suits you and then push it's boundaries and see if you want to change. I prefer a fat tire because it handles off road better for me but is not that great when it comes to mpgs and long mountain uphill grades because of it's heavy rolling resistance.
Old 06-10-2021, 11:30 PM #109
What tire pressure are you running for normal driving? I am usually 35-40 on road.
Old 06-19-2021, 03:51 PM #110
Deuxdiesel Deuxdiesel is offline
Deuxdiesel has a spectacular aura about Deuxdiesel has a spectacular aura about
255 KO2's on 8.5" wheels with zero offset. Yeah, it works just fine.
255/75/17 KO2 Pizza Cutters-img_2985-jpg
Deuxdiesel is offline   Reply With QuoteReply With Quote
Old 06-19-2021, 11:15 PM #111
Gstick Gstick is offline
Gstick will become famous soon enough
Will the 255/75/17 pizza cutters mounted on OEM TRD OR wheels fit under a stock 4R suspension ? (no lift front or rear)
2010 4R SR5, "best 4 wheel vehicle that I've ever owned" TRADED !
2019 4R TRD Off Road
Gstick is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 06:43 AM #112
I have a set of 255/75r17 Duratracs on OEM 4Runner steel wheels (7.5") for winter driving and they clear without any issue. I think the specs on the steelies are very similar to the TRD wheels.
Old 06-21-2021, 05:57 PM #113
Correct me if I'm wrong, but it looks like your 4R is lifted or maybe a leveling kit ?
It looks very good by the way !!!
Old 06-22-2021, 07:28 AM #114
It has a 1.6" front lift, now sagged to just over 1.2". Those tires fit fine before the lift. Remember, those tires are just .5" in diameter larger and 1 cm narrower. All 4R's are a little different it seems, but if you check your clearance with full lock, you will get a good idea if they will work.
Old 06-22-2021, 08:37 AM #115
ScoutRecon ScoutRecon is offline
ScoutRecon is on a distinguished road
I have a question for for the folks running the skinny tires. How do they handle in the sand aired down?
ScoutRecon is offline   Reply With QuoteReply With Quote
Old 06-22-2021, 05:51 PM #116
That debate will linger for years. Sand is like snow in that no two conditions are the same. There was a video years ago from this older Aussie guy who explained that the longer contact patch from a narrow tire acted like a ramp on sand, vs. the wider patch which acted like a wall. It made sense.
Old 06-22-2021, 06:51 PM #117
Yeah I can see that being debatable vs a wide tire, there is no perfect tire for every situation. I was just looking for some reviews from people who drive on beaches or in the desert driving in the loose stuff. Personally, I'm not really interested in a wider tire for where I drive the wife's runner and my 80 series. A wide tire is not my choice for snow or wet roads.
Old 09-14-2021, 02:16 PM #118
gsteitz gsteitz is offline
gsteitz is on a distinguished road
Attachment 383505
This looks awesome, and sealed the deal on 255s for me. Definitely think the 8.5" wheels help the look. Which ones are those?
gsteitz is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 06:52 PM #119
David9962000 David9962000 is offline
Real Name: David
David9962000 is on a distinguished road
Real Name: David
The 255/75 is 2LBS heavier than a K02 in a stock size both C load. Can you notice a gain in MPG?
David9962000 is offline   Reply With QuoteReply With Quote
Old 09-16-2021, 05:48 AM #120
My wheels are Motegi Trail 150's. I bought a set of slightly used O/R wheels and Discount scratched them all up, so this is what I chose as a free replacement. I am pretty much stuck at 19.4 average MPG, mostly rural and gravel roads.
Anyone running 255/80/17 Tires Pizza Cutters alexb 5th gen T4Rs 227 05-06-2020 09:41 AM
Steelies and pizza cutters Blacksunshyne 5th gen T4Rs 21 11-17-2018 10:07 AM
235/85-16, who runs pizza cutters? KAILUAZ 3rd gen T4Rs 20 06-09-2018 03:11 PM
Pizza cutters? simple06 5th gen T4Rs 5 04-06-2011 10:53 AM
Celeste Pizza Fakie Polls 11 02-18-2005 07:50 PM
