I have a 2011. I have all the bolts out of the valve cover. It just doesnt seem to want to budge. Has anyone found a writeup on this job. This job is a pain in the butt. Any help is appreciated.
Your going to have to pry up on the valve cover to get it free. There are just stuck to the old gasket. MAKE 100% SURE YOU HAVE REMOVED ALL OF THE VALVE COVER BOLTS 1ST. Its a pretty easy job just take your time. I have quite a bit of wrench time under my belt so it took me about an hour and half.
Thought I would update this thread, as I just had to re-do the job for a couple more leaking spark plug seals. Still looking pretty clean after 32 10k miles oil changes.
Jeremy, how many miles do have right now? We are just over 316K on a September 2014 ST5. No valve cover oil leaks so far.
Are the timing chains sloppy on yours?
321k. They do seem to have a bit of pin wear, and can slightly lift the long chain from the sprocket. I may finally fix the timing cover leak next year and replace the chains and tensioners.
That is crazy clean.
__________________ 2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Hello all, new to the forum and to 4runners. I recently traded in my Tacoma for a 2010 4runner w/ 211,000 miles. I changed the spark plugs this week and noticed oil accumulation in several of the spark plug holes. No signs of oil burning or head gasket leakage from what I can tell. I'm led to believe a valve cover gasket and spark plug gasket job is in order. Before diving in and ordering parts, I just wanted to confirm the part numbers I have here are correct. Also, are there any other parts or tools I would need or recommended for this job beyond basic hand tools. Any sealant needed around the valve cover gasket when replacing? Here is the list I have so far (my main point of concern was if the intake manifold gasket was the correct one as there were a few in the parts fiche to select from). I'm also planning to replace the PCV valve as a preventative measure. thanks in advance
11193-70010 x 6 (plug tube seal)
11214-31030 x 1 (valve cover gasket)
11213-0P010 X 1 (valve cover gasket)
17176-31140 x 1 (intake manifold gasket)
Did you determine if the gasket at the top or the joint at the bottom of the tube was leaking? Mine is leaking too, but I haven't disassembled it yet. Trying to order all the parts from Toyota now, but it's kind of difficult to tell from the parts diagrams which seals are needed.
Jeff
