View Poll Results: What to do
Keep it 17 62.96%
Keep it
17 62.96%
Swap it 10 37.04%
Swap it
10 37.04%
Voters: 27. You may not vote on this poll
Old 02-02-2018, 01:45 PM #1
DannyLlama's Avatar
DannyLlama DannyLlama is offline
Real Name: Danny
DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough
DannyLlama's Avatar
Real Name: Danny
Sidewall damage question
This happened during my last Anza Borrego desert... Pictures may not be too clear. Essentially, i noticed that I had side wall damage on my driver tire after the day trip. Luckily not enough to puncture the tube. the tread is even still attached.
I have an LE with full time 4WD, so I may have to replace all four tires if I need to swap this out ... what ya'll think about leaving it vs. swapping it out.. should I be concerned for my next trip?
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
DannyLlama is offline   Reply With QuoteReply With Quote
Old 02-02-2018, 01:50 PM #2
TfourR TfourR is offline
TfourR is on a distinguished road
I can't tell from the pic but is it down to the cords? If not you're good.
TfourR is offline   Reply With QuoteReply With Quote
Old 02-02-2018, 02:35 PM #3
johnbt's Avatar
johnbt johnbt is offline
johnbt will become famous soon enough johnbt will become famous soon enough
johnbt's Avatar
Tube? You put tubes in your tires?
Anyway, every chunk you knock out of a tire is one less layer of rubber to protect it the next time. Your call.
2023 TRD ORP w/KDSS. Red again.
This 2016 TEP w/KDSS is a big step up from the 1986 Subaru GL wagon I used on the Outer Banks beaches for 14 years. That thing would go anywhere in the sand on 185/70-13 tires. Dual range 5 speed, factory skid plate, 3 position manually adjustable rear shocks and armored exhaust. All factory, including the white spoke wheels. The front sub frame finally rusted apart.
johnbt is offline   Reply With QuoteReply With Quote
Old 02-02-2018, 02:37 PM #4
wanderMT wanderMT is offline
wanderMT is on a distinguished road
tube??
I would move to back and keep close eye for bulging and probably not drive over 70.
'15 Limited - base
wanderMT is offline   Reply With QuoteReply With Quote
Old 02-02-2018, 02:39 PM #5
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
if the side wall is flat not bulged out should not be a problem.
if it is out then should be replaced
catrains is offline   Reply With QuoteReply With Quote
Old 02-02-2018, 02:46 PM #6
Tisoy281's Avatar
Tisoy281 Tisoy281 is offline
Real Name: David
Tisoy281 will become famous soon enough
Tisoy281's Avatar
Real Name: David
So, if I ever have to change out a tire on my LE 4wd, I have to change ALL of them out? I had no clue... Time to **** up a tire so I can tell my old lady I need new ones...
Tisoy281 is offline   Reply With QuoteReply With Quote
Old 02-02-2018, 02:47 PM #7
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Keep it, but keep an eye on it.
OTOH if you get new tires, you will have good offroad spares.
delloro is offline   Reply With QuoteReply With Quote
Old 02-02-2018, 02:54 PM #8
DannyLlama's Avatar
Real Name: Danny
DannyLlama's Avatar
Real Name: Danny
This was really a test to identify the type A crowd on this forum. lol
Originally Posted by wanderMT View Post
tube??
WTH is it called? the part under the rubber? Not a tire knowledge expert here.
Thanks for all the feedback. No bulging. I have driven over 70 plenty, after. It happened about a month ago and it seems fine. I can however, very slightly peel it, but dont want to keep doing that and make it worse.
Dual Battery Thread
Old 02-02-2018, 03:16 PM #9
4Running Daily's Avatar
4Running Daily 4Running Daily is offline
Real Name: Connor
4Running Daily will become famous soon enough
Real Name: Connor
Ya there is no tube in your tire. Peel is back and see what you can see. If it's all rubber, leave it. It's fine. If not, replace asap.
/end thread
1996 Toyota 4Runner 4x4 w/ 5 speed- Lifted, Locked,Painted,Armored
Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Originally Posted by invisible4Runner View Post
Highlander = minivan, purses, soccer practice
4Runner = testosterone, steak, dirt
4Running Daily is offline   Reply With QuoteReply With Quote
Old 02-02-2018, 03:18 PM #10
johnbt's Avatar
johnbt's Avatar
https://tireguides.com/TireTips/TireDocument/14
#5, 6, 7, 8
I didn't know the precise names either. I just called it the body or "Is it down to the cords yet?"
Some people put tubes in radial tires, but most places won't do it for you.
AWD vehicles - like Subarus - need the tires to be the same diameter to keep the AWD system functioning and healthy. I've read about shops that will shave a new tire down to match the 3 worn ones so you don't have to buy 4 new ones.
Old 02-02-2018, 03:24 PM #11
if the rubber has a flap put some adhesive on it .. keep the cord clean sealed .
long time ago a had a slit in side wall but did not effect tire cords . covered the cut .
Old 02-02-2018, 04:13 PM #12
Tisoy281's Avatar
Real Name: David
Tisoy281's Avatar
Real Name: David
So... If I wanted to intentionally screw up a sidewall so I can tell my old lady I need new tires, what would be the best way to go about doing this without damaging my truck?
Oh, and asking for a friend...
Old 02-02-2018, 05:55 PM #13
DannyLlama's Avatar
Real Name: Danny
DannyLlama's Avatar
Real Name: Danny
What kind of adhesive do you recommend?
LMAO
On that note.. I have always wondered how much thread is lost before I have to consider replacing all 4. Anyone know the math or formula to this?
Dual Battery Thread
Old 02-02-2018, 06:55 PM #14
dow 795 sealant use some alcohol to clean rubber then apply this sealer very flexible and sticks good. needs 24 hrs to be cured .
used in construction on metal/concrete/windows very good adhesion.
Old 02-02-2018, 07:09 PM #15
DannyLlama's Avatar
Real Name: Danny
DannyLlama's Avatar
Real Name: Danny
dow 795 sealant use some alcohol to clean rubber then apply this sealer very flexible ans sticks good. needs 24 hrs to be cured .
What about extreme heat or cold climate impact? will the sealant crack and make matters worse?
Thanks btw
Dual Battery Thread
UCA hits top of sidewall after wreck, frame damage? boondocksDrew 4th Gen T4Rs 14 06-23-2021 01:47 PM
tire sidewall damage xnodesirex Engines / Suspension / Wheels / Tires / Audio / Accessories 4 10-26-2017 11:17 PM
Key Fob Water Damage Question GreyhoundGuy 4th Gen T4Rs 7 01-24-2014 09:06 AM
Paint Damage Question blonde1boarder 3rd gen T4Rs 1 12-07-2012 08:55 PM
Question about minor damage... doctob 4th Gen T4Rs 5 06-06-2005 10:10 AM
