03-23-2018, 10:54 AM
5th gen TPMS disable
Been searching the site and haven't found anything other than the pvc canister idea.
Anyone know if this method would work on a 5th gen?
https://www.tacomaworld.com/threads/...sabled.284690/
2017 4R Canadian Pro (Moon-roof) w/, 2.5 King Coilovers w/ 700# Coils, Toytec Superflex Rear Coils, JBA UCA's, RCI Sliders, ARB Summit Bar, CBI Ditch Light Brackets, Superwinch Tiger Shark 9500 SR, ARB Rear-diff Breather, Dipped Rear Badges, "Raptor" Style Grill Lights, Spidertrax 1.25" Wheel Spacers, Cooper ST Maxx 255/80/17
03-23-2018, 10:55 AM
Real Name: Sparky
Real Name: Sparky
Remove TPMS or don't install it in your new wheels.
Done.
Old and (c)rusty.
03-23-2018, 02:49 PM
Done.
Removing the TPMS sensors does not disable the warning light
Jim _ My Adventure Blog: http://suntothenorth.blogspot.com
2018 TRD Off Road Premium
ARB on-board compressor - RadFlo coilovers & rear suspension - Engel freezer-fridge - All Pro LCAs - African Outback roof rack, RCI skid plates
03-23-2018, 03:16 PM
The TPMS system is federal law, and is written in such a way that all manufacturers have to integrate their chosen technology in a way that it cannot be disabled. Not saying it can't be "hacked" to disable, but you risk other problems perhaps. The thing I find most egregious, is the $100ºº or so cost of the sensor when the batteries go dead.
03-23-2018, 03:40 PM
most independent tire shops will clone 5 TPMS for ~ $100. amazon sells a set of qyt4 autel programmable 315Mhz tpms ~ $119.
i prefer to be safe with TPMS on all my wheels
03-23-2018, 05:12 PM
Why would you want to disable it? Just so the light wouldn't be on when you're aired down? I'd rather have the safety of knowing if a tire is low while daily driving vs. not dealing with the light during the rare circumstance I'm aired down. The TPMS light has alerted to me to nails in my tires a number of times that would have otherwise taken me much longer to notice.
2014 Trail Edition Premium w/KDSS - 3" Suspension Lift - FOX 2.5 DSC Coilovers - FOX 2.0 IFP Shocks - OME 3" Springs - LR UCA's - Metaltech Sliders - XD Enduro Pro Wheels - 285/70r17 BFG KO2's - Kenwood 5 Channel Amp w/ JBL speakers and JL 12" W3V3 - K&N intake - HID low beams - TRS LED Fogs
03-29-2018, 08:48 PM
If you buy the TIS Techstream from Amazon ($100) then you can program your own TPMS sensors and not have to worry about the light, you can even adjust the psi that turns on the light, set it to 5psi and never have the light go on again!
03-29-2018, 11:14 PM
Real Name: Halko
Real Name: Halko
Um, a little piece of tape over the light. You laugh but several folks in here have done it.
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
03-29-2018, 11:45 PM
I have been doing this ever since I put my BFG tires on with no sensors.
03-29-2018, 11:59 PM
Real Name: Sparky
Real Name: Sparky
It's a dumb system that doesn't tell you which tire is involved or what the pressure is, or if there is just fault with the system.
GMs and other cars will give you pressure readouts for each tire in real time (are they super accurate, no, but close enough).
Old and (c)rusty.
03-30-2018, 12:14 AM
I've just been ignoring the warning light all winter, don't even notice it anymore.
04-02-2018, 02:38 PM
I agree it's dumb that it doesn't tell you which tire it is, but it still alerts you to address the issue.
This is completely off topic, but back when I was considering replacing the head unit that's why I was interested in iDatalink Maestro. In addition to integrating the steering wheel controls and all that, you can use it to access vehicle diagnostic data like oil temp/pressure and also the individual tire pressures from the tpms system. Hopefully this will be addressed in the next 4Runner, since my friend has a TRDP Tacoma and the HUD in the instrument cluster is full color and will show tire pressure among many other things.
04-02-2018, 07:17 PM
How did I drive the last 40 years in a vehicle with no more than power steering and brakes as the only safety features and live to tell.......it's a Miracle, I tells Ya!
04-02-2018, 07:49 PM
I was going to de-solder the LED for the light, but just ended up putting a small piece of gorilla tape over it instead. I installed aftermarket sensors that use a different frequency and also display each tire's pressure and temperature.
