06-02-2018, 02:24 PM
#1
Senior Member
Senior Member
Transmission Fluid Change procedure
Just thought I would post what is in the repair manual for future reference.
__________________
2011 SR5 4x4, Magnuson Supercharger, ICON ET coil overs, MT ICON LT rear, MT offset lower links, URD Y-Pipe, TC UCAs, Baja Rack, MT Sliders, RCI Aluminum skids, 4.56 gearing with ARB lockers front and rear. 305/70 Goodyear MTRs (34") on Konig Countersteer 17x8. Addicted front bumper, Custom undercover tube protection rear. LT font or SAS going on next.
1989 Hilux - 22RE, SAS, hydro assist, Full Exo cage, dual ultimate cases, RCVs, 529s w Detroit locker rear + ARB front, Diamond Axle, bead locks, 40s.
06-02-2018, 02:45 PM
#2
Senior Member
Senior Member
Slight difference on the 4wd transmission if you don't have another way to check the temp...
__________________
06-02-2018, 07:30 PM
#3
Member
Member
This needs to be a sticky or go somewhere where it won't get lost. Thanks!
__________________
-2016 7%'er---RCI aluminum skids; C4Fab sliders; Rago Fab modular storage panels; Complete 3M ceramic tint; The Ultimate Camping Mod; Xenondepot HID kit; BFG KO2's
-1967 Stephens M416 military trailer---slow build
06-03-2018, 05:45 AM
#4
Member
Member
Quote:
DIY maintenance quick reference
__________________
2015 2WD Blizzard Pearl Limited, Black Interior
06-03-2018, 05:49 AM
#5
Member
Member
Quote:
Originally Posted by Rmack
Niiiice! Thanks, Rmack!
__________________
06-03-2018, 11:12 AM
#6
Senior Member
Senior Member
The title of this thread is a bit misleading... It's just the fill procedure from the FSM not the change procedure. I don't think the FSM give an actual fluid change/flush procedure.
If you just drain the pan you will only be chaining about 1.5qt of the 6+ total.
Most people use the transmission cooler line and the trans pump to get a full change.
Basically
-disconnect the lower hose and dump to a bucket out of the radiator.
-Run the motor for 10-15 seconds (should pump out about 2qt
-Put about 2 qt in the fill (I think it is easiest to run a hose down from the engine compartment and use gravity)
-Repeat until fluid is clear and fresh (should be about 8qt)
Now do the level check procedure outlined in the FSM (at the top of this thread).
I'm sure this is outlined somewhere else here on the forum... Just thought I would throw it in here since it could be confusing based on the thread title.
__________________
06-03-2018, 01:52 PM
#7
Member
Member
This thread is new so it’s actually not in there yet, but I’ll ad when I get a chance.
__________________
2016 Trail Edition Premium w/ KDSS. LT265/70R17 BFG KO2s, Ceramic Pro, TSO pro grille, sliding cargo tray, WeatherTech floor liners, '10-'13 trail running boards.
Nobody cares about your vehicle as much you do. DIY Maintenance Quick Reference
06-03-2018, 01:54 PM
#8
Member
Member
Basically
The new Tacoma manual has you do 3 drain/fill/recirc cycles to constitute a fluid replacement, I suspect this would suffice if you’re not brave enough to do the “feed and bleed”.
06-04-2018, 04:37 AM
#9
Member
Member
If I may go on a tangent here: why would you ever need to flush transmission fluid?? Tend to hear more horror stories of high mileage vehicles popping the trans shortly after a flush..
Wouldn't it be better to just use the pan/ overflow steps above to do this 1-2 quarts at a time every 60k or so?
__________________
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
06-04-2018, 08:42 AM
#10
Senior Member
Senior Member
I’d give that a whirl. Can you elaborate a bit on the Tacoma procedure? Now where’s the damn drain plug?
__________________
2010 Trail - 135k mi - KDSS - Classic Silver Metallic - Bilstein 5100s - Tires: Michelin X-LT A/S 36psi - Oil: M1 EP 5W/30 - Diffs and T/C: Delvac 75W-90 Synthetic - Toyota WS ATF - ScanGauge - Viofo dashcam - Husky Weatherbeaters - Plasti Dip wheels and chrome delete - Wheel Center Caps delete - Roof Rack Cross Bars delete - Cargo Tray divider delete
06-04-2018, 08:58 AM
#11
Senior Member
Senior Member
I do not agree with the Toyota instructions on the tranny fluid pan drain/drop procedure on filling prior to starting the engine ...
you do not fill to the fluid level hole... YOU PUT INTO THE TRANNY 2QTS !!! when the engine is OFF the fluid will be much higher than the level fill hole so the tranny if you follow this toyota procedure will not have the proper amount of fluid .
IMO you put in 2qts start engine open the fluid level hole as the temp rises some fluid will come out then when its in the 110F temp range put the level plug in .. all done............
when you want to do fluid exchange drop pan and do a good cleaning of it ..
06-04-2018, 11:29 AM
#12
Senior Member
Senior Member
I think you are getting the term flush confused with an exchange/replace of fluid.
Flush is something where a cleaning fluid is pushed through the trans with pressure and can dislodge material....
Just running the engine to push out the fluid and replacing it with new fluid should not cause any problems at all.
The problem with draining from the pan only is that you will be mixing the new and old fluid quite a bit. It will work, but if you are taking the time.. Might as well put in fresh clean fluid and avoid mixing as much as you can.
These really only need to be done at 80-100k intervals. Probably more often after the first since you can't really get all new fluid in.
__________________
06-04-2018, 02:20 PM
#13
Senior Member
Senior Member
I don't think you understood what they call for in the FSM procedure. You fill initially until it drains from the overflow just to set a baseline... Then plug the overflow and put in the required amount based on the procedure done.. For just a or drain plug or pan removal... 1.8 qt additional. Then you do the fluid level check once up to temp.
__________________
06-06-2018, 01:24 AM
#14
Senior Member
Senior Member
Basically
it seems tedious to pump out 2 qts at a time.. why cant you just let the engine pump the entire 6+ quarts out of the trans at once?
06-15-2018, 10:20 AM
#15
Senior Member
Senior Member
when the trannty fluid level port / plug is off and engine is off this will not hold the amount you drained out ..
many have done this MY way .. you measure what you drained out then you put in the new fluid the same amount .. the fluid level hole in place .. then start engine open level hole and when it gets to 110 f range add fluid till it comes out or plug fill hole if fluid drains out with what you added ..
this is not gonna do any damage as the fluid you removed is the same amount you put in, that is the safe way rather fill the tranny to the level hole with the engine off ..
engine off a good amount for fluid drains back into the pan and will be well above the fluid level port ..
you all do it your way good luck ..IMO my way much easier ..less mess.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
