Old 09-04-2018, 12:07 PM #1
1996_Valencia_Owen 1996_Valencia_Owen is offline
Banned
1996_Valencia_Owen is on a distinguished road
Banned
Best single KDSS-compatible suspension option for slight lift, soft ride
Does anyone have any recommendations for the best spring/shock brand/part #s for the below?
-KDSS friendly
-1-3" lift max (my garage door is 6" above my roof at stock height now, and need to leave a little for bigger tires.
-As soft/buttery of a ride as possible.
-I don't pack the truck too heavily. Usually under 1,200 lbs combined people and cargo weight, so I don't need anything super firm.
Thanks!
1996_Valencia_Owen is offline   Reply With QuoteReply With Quote
Old 09-04-2018, 12:25 PM #2
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Depending on budget of course -
Accutune will custom valve fox or king shocks to your wishes included in the purchase price.
I found the Fox factory shocks to be very supple at near stock height in the front. Mine are not custom tuned, but I plan to revalve with a flutter stack soon to soften them up a bit more. As you go up in height - everything gets harsher. Just the nature of the angles of the suspension arms - nothing shocks can do to solve that geometry problem. Basically keep the lift relatively low is the best bet for soft suspension.
The fox 2.0 Performance rear shocks in my 4runner are not supple at all. IMO they are too stiff of valving without 400+lb in the rear. With the trailer on or lots of weight they're about right.
As another alternative I would guess the TRD Pro suspension would be a good bet for soft ride. I think they run pretty soft springs - like 550lb/in or something like that in the front. And the shocks are fairly softly valved as well.
Old 09-04-2018, 02:06 PM #3
Tuc4R's Avatar
Tuc4R Tuc4R is offline
Tuc4R is on a distinguished road
Tuc4R's Avatar
I am running ADS C/O's and rear shocks. They are simply amazing. I ran Icon on my Tacoma, and there is no comparison, the ADS rides soooo much better. They use the same quality components that they use in there high dollar race shock.
Best single KDSS-compatible suspension option for slight lift, soft ride-image1_3-jpg  Best single KDSS-compatible suspension option for slight lift, soft ride-image1_2-jpg
2018 TRD ORP W/KDSS & Sunroof - ADS C/O's and rear RR, TC UCA's, Icon 2' springs, SSO bumper, Smitty X20, Nitto RG, FX PRO wheels, AVID sliders, RCI Alum skids, Bussmann RTMR, Canvas backs, Accessorides remote start, Rago Molle’s, HID low's, LED high's, Morimoto XB fogs, Ceramic window tint, Ecotechne roof rack, ARB diff breather, Indel B TB51, Ellis shift knobs, Plastics Guy bump stops, ARB twin comp., Pedal Comm, X2 Power G27
Tuc4R is offline   Reply With QuoteReply With Quote
Old 09-04-2018, 04:00 PM #4
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
King
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 09-04-2018, 04:27 PM #5
mgk1789 mgk1789 is offline
Real Name: Brian
mgk1789 is on a distinguished road
Real Name: Brian
+1 KING
Best single KDSS-compatible suspension option for slight lift, soft ride-img_0129-jpg
mgk1789 is offline   Reply With QuoteReply With Quote
Old 09-04-2018, 04:41 PM #6
DesertFish's Avatar
DesertFish DesertFish is offline
DesertFish is on a distinguished road
DesertFish's Avatar
Wondering what people think about these options compared to the stock suspension as far as a supple ride. I've read so many conflicting thoughts on Kings/Icons/Fox/etc, I'm in a similar position as OP, looking for as soft a ride as possible.
16' Trail KDSS
275/70/r17 KO2
DesertFish is offline   Reply With QuoteReply With Quote
Old 09-04-2018, 05:01 PM #7
jbjones85's Avatar
jbjones85 jbjones85 is offline
Real Name: Josh
jbjones85 is on a distinguished road
jbjones85's Avatar
Real Name: Josh
I have a set of kings going on in a couple of weeks so can update a bit more after that but ran ICON in the past and have a spacer lift right now so will be able to offer some comparisons ('15 w/KDSS)
2015 TEP W/KDSS. 285/70 KO2's, OPOR Sliders, GOBI rack, King 2.5 ext. travel w/adj, Weathertech Mats, Vision X front lighting, Spacers until time for new tires, ARB OBA, RCI Skids, Ellis Precision FJ Style shifter.
jbjones85 is offline   Reply With QuoteReply With Quote
Old 09-04-2018, 05:26 PM #8
Banned
Banned
Good tips so far.
I was sorta hoping somebody would someday make a KDSS set of sways. I feel like an aftermarket company could make some that are slightly less stiff... so while still less rolly than stock, allow more on-road suppleness.
Old 09-04-2018, 05:43 PM #9
GChristo's Avatar
GChristo GChristo is offline
GChristo is on a distinguished road
GChristo's Avatar
What makes KDSS feel stiff vs a non-KDSS vehicle isn't the inherent rigidity of the sway bars as you may be thinking. There's a hydraulic piston attached to the front and back sways each. When you go over 12mph or meet certain other driving criteria like steering wheel position, g-forces etc, your stabilizer ECU will send a 12V signal to the accumulator assembly. That signal energizes the accumulator's solenoids resulting in reduced rate of flow through the KDSS hydraulic lines. Reduced rate of flow through the lines will mean that piston attached to the sway bars will not want to be as compliant. I am not an engineer so excuse me if I use incorrect terminology or have a loose interpretation.
You can certainly make off-road handling more compliant or 'plush', but the compliance you will be trying to build in will be opposed in part by how KDSS functions. It's not impossible to improve your ride, just be aware of this.
2014 Trail w/KDSS - LT255/75r17 C KO2 - King C/O - Baja UT - 140/440 mobile - Dual Bat
GChristo is offline   Reply With QuoteReply With Quote
Old 09-04-2018, 07:26 PM #10
Jetboy's Avatar
Jetboy's Avatar
The KDSS sway bar is much stiffer than the non KDSS bar. It's a 1.68" front and 1.18 rear diameter sway bar. That doesn't entirely identify the actual spring rate - but for comparison the normal one is 1.18 front and 0.79 rear. As a comparison the front bar is larger than even the HD aftermarket sway bars for an F350. It's very stiff.
Generally shocks need to be balanced with springs. Stiffer springs = softer shock dampening. With KDSS I think most shocks are too firm on compression.
I do think that it would be interesting to have a shop make a softer sway bar set for KDSS vehicles. Should be do-able if there was enough interest.
Old 09-04-2018, 07:37 PM #11
CoolMax's Avatar
CoolMax CoolMax is offline
CoolMax will become famous soon enough
CoolMax's Avatar
The answer to this question seems to change every yr.
I've heard that Fox is pretty good, that Icons are valved best out of the box - I've seen a couple of #Stage 7 setups on Instagram, that Kings aren't ideal because they are tuned for high-speed, Baja-type driving - supposedly not KDSS's strong suit.
To add to the confusion - OME is alright, and Toytec/Radflo is pretty smooth.
2013 Classic Silver Metallic Trail Edition w/ KDSS
CoolMax is offline   Reply With QuoteReply With Quote
Old 09-04-2018, 07:39 PM #12
CoolMax's Avatar
CoolMax's Avatar
Eager to read this comparison.
Old 09-04-2018, 08:09 PM #13
GChristo's Avatar
GChristo's Avatar
Indeed, though regardless of swaybar thickness, the KDSS system is still engaged. Drive down the same rutted road with and without KDSS engaged on the same vehicle. It's not a nuanced effect, it's night and day. Not disagreeing with you here. Simply emphasizing this system is not trivial.
Old 09-04-2018, 08:29 PM #14
Angelo's Avatar
Angelo Angelo is offline
Angelo will become famous soon enough
Angelo's Avatar
Having owned both the Bilstein Pro and TRD OR with KDSS, I can say that the Bilstein TRD Pro system is super comfortable with regard to soaking up bumps. The KDSS handles and corners better, but the stock Tokico shocks don't compare at all to the TRD tuned Bilsteins. I'd recommend the TRD Bilsteins (4R, no experience with the FJ ones) to anyone looking for mild / no lift.
If the TRD Bilsteins offered a little more lift, I'd have them on my KDSS already. I haven't ridden in a 6112/5160 and I know that they're supposed to be a little stiffer, but I expect with a soft ~530lbs spring similar to the Eibachs on the Pro, it'd be very similar.
Eibach - Dobinsons - Falken - Rigid
Consolidated Lighting Info Thread
Angelo is offline   Reply With QuoteReply With Quote
Old 09-04-2018, 08:37 PM #15
skinny420 skinny420 is offline
skinny420 is on a distinguished road
-KDSS friendly
Thanks!
I'm super pleased w/ Toytec Boss kit and TC UCAs (link in sig). IMHO, best (or darned good at least) bang for the buck if you're not hard core wheeling. I went w/ the HD rears b/c of my 130# box of crap I haul around w/ me.
I've driven 2000+ highway and 100s of around town miles since having it installed. Finally got off road this weekend at Fort Fisher. Have been many times b/f new suspension and was a great pleasure driving w/ new setup. For one, no more dragging skid plates on the sand; and B, although still "soft" the front was much less bouncy than before.
my $0.02
https://www.toyteclifts.com/ttboss-4...and-gx460.html
coils: 650# front; heavy duty rear
skinny420 is offline   Reply With QuoteReply With Quote
5th Gen - KDSS Compatible Lower Control Arms! TOTAL CHAOS 5th gen T4Rs 93 07-26-2019 05:02 PM
What is the best suspension/lift with KDSS 4High4Low Off-Roading 0 06-11-2018 12:13 AM
Suspension Lift for 2014 T4R with KDSS? sd3025 5th gen T4Rs 30 06-21-2017 04:40 PM
Suspension Question: Air Lift compatible with aftermarket springs? OrdnanceMarine 4th Gen T4Rs 11 03-06-2017 03:25 PM
SR5 suspension mod to ride like TE KDSS? Pastanoose 5th gen T4Rs 3 06-28-2014 02:31 PM
