What do you look for in styling in a wheel?
PeoplecallmeIan
I've gone through 2 sets of wheels in the year I've had my 4runner and I've been thinking of swapping them again. I've been looking at these Rhino wheels. What do you look for in a wheel or what do you think is missing in the market at the moment?
correct offset is the big one, and I like 5 spoke type wheels.
When you say correct, do you mean more of -/+? I personally think offset is a personal preference and I prefer a lot of negative so spacers don't need to be run. I would like to see a higher offset in the -12 to -38 range.
Engineered offset/backspacing
Spoke-ish
Alloy
Some shiney is okay
No fake bolt heads
Available center caps
-but I'm old.
Lightweight
Strong
Simple design and spoke layout, if not muted in appearance. I'd rather they not "look" fancy.
Good Offset, Backspacing, and width... preferably 8" or under.
I start with overall looks on the vehicle. After I settle on a few options I look for correct offset and size for the tire I want to run. And then choose what has the best quality out of who’s left.
Those are pretty cool. Kind of looks like the H1 beadlocks. Definitely a fan of bronze wheels though
I like either deep dish, or extremely concave wheels, so basically negative offset wheels with a simple design in 17 inch diameter. I also would like to see a wheel manufacture make a wheel that is wider than 9 inches, mainly because if you are going to run a negative offset, might as well run a wider wheel, otherwise, you are just pushing the wheel further out for no reason. Basically, I like the wheels I see on modified land cruisers.
not a fan of fake deadlock, affliction t-shirts, or ed hardy.
