10-29-2018, 05:59 PM
let me see your 5th gen HAM install pictures (non permanent)
I just got my Ham license and want to do a install that will not damage or permanently alter the T4. I had seen a clamp that goes on the center console
and holds the radio on a mount but can no longer find the set up
so if you would please post your non permanent install pics.
18 TRD/OR: 285/70/17 Cooper STT Pro, SPC adjustible uca's,Toytech3" lift w/ 2.5 front coilovers, 2.5 rear shocks w/Icon rear shock armor, super flex HD springs w/OME 10mm spacer, Rad Rubber designs fender flaps, Full RCI skids and lca armor, Diff breather mod, AC mod, SSO slimline bumper, smittybuilt x2o 10k winch, Factor55 prolink/hitchlink, 1.5 fairlead, Baja Designs S8 20” in bumper, Baja Designs Squadron ditch lights w/Rago brackets, Shrockworks sliders w/ tread plates, Jowett oil filter housing, Odyssey 34-1500t, Cobra 75wx st cb, HID pro interior led lights. custom made sleeping deck w/storage.
10-29-2018, 06:03 PM
What kind of Radio? Like a BaoFeng handheld? I've used 3M Dual Lock Velcro.
10-29-2018, 06:07 PM
sorry ...yaesu 7250DR
10-29-2018, 08:35 PM
Real Name: CJ
Real Name: CJ
Not specifically a HAM but I used a magnetic phone/tablet mount stuck on top of the dash for my GMRS radio. The radio bracket sticks like glue and I need to put a pretty good pull on it to get it loose. It hasn't shifted on there in the couple months it's been mounted. I was so impressed with the magnets in this little guy I ordered another one and am trying to figure out where to put it.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2014 Trail Edition -
Build Thread
2015 Epic in my own mind trip
10-30-2018, 09:35 AM
Somebody here or on TW 3D printed a bracket that hung off the side of the console by wedging into the skinny pocket and held the unit vertically. Is that it? I'm not inclined to search for it, but I recall seeing it. Might have been in a CB thread.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You can’t grasp its vastness from a plane. It’s diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
10-30-2018, 10:29 AM
Thanks! Thats most likely the one.
10-30-2018, 11:03 AM
I have a Yaesu FTM-400 mounted under the seat, display overhead and microphone on left of center console. Everything is removable with no damage.
Sent from my SM-G960U using Tapatalk
10-30-2018, 11:14 AM
2016 Trail,
10-30-2018, 01:57 PM
Real Name: Jake
Real Name: Jake
Pics of the mounting bracket on for the faceplate up top?? That looks awesome!
"Po" - '18 Super White TRDORP - Build Thread Here
"Sirius Black" - '03 Limited V8 Build (Sold) - Build Thread Here l 03->06 Headlight Swap Guide
My Photography // My Videography
10-30-2018, 02:00 PM
i just bent up and cut the faceplate bracket that came with the radio, just wedge a peice of aluminum in there and the clips should still hold fine assuming your faceplate isn't heavy.
10-30-2018, 02:04 PM
Real Name: 2016 Member of the Year
Ryan - KC2VQG
- 2020 4Runner TRD Off Road White
- 2016 4Runner TEP Black (Sold)
- 2012 4Runner Trail Edition Black (Sold)
- 2008 4Runner V8 Sport Edition Black (Sold)
12-09-2019, 04:27 PM
Real Name: Chris
Real Name: Chris
This is my install. Drilled a hole in the side of the stereo surround and mounted a Ram Ball, then short arm and Ram Ball on the back of my FTM-400. Still working on mic solution. Just starting the install, eating it one piece at a time.
12-09-2019, 04:54 PM
Originally Posted by jahdai42
Do you use double sided tape to attach it to the center console?
