SCS Rim Sizing Question
Spinnukur
I'm Running 285/70/17 Nittos and am looking at the SCS F5. If what I've found on the interwebs is correct (all T4R), I need a rim with minimal offset and backspacing since I'm already running the ICON S6 suspension.
If that's the case, would I be fine with the F5's at 17 X 9 6 X 139.7 3.50" -38mm 23.5lbs ?
Thanks,
Spinn
Thanks,
Spinn
at -38mm offset, you probably will have to do a BMC.
I'm running something very close to that offset.
I contacted SCS about this very question and they mentioned I would need a BMC. I also contacted another T4R owner with the F5 17x9 rims and he mentioned he did the BMC too. I went to a local shop the other week for my BMC just now need to pull the trigger and get the rims in.
I found this photo album somewhere, the T4R has the F5 17x9s on with 285s gives you good photos to see the angles.
https://imgur.com/gallery/28xAe
