Old 03-14-2019, 06:28 PM #31
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
Originally Posted by tjnptel1 View Post
I didn't install the relay either thanks to the guidance of members on here. I recently installed the 6400k XD xenons but they appear to be closer to the 8000k temp. and they take closer to 90 secs to get to full power. anybody else experience this?
chances are you bought a cheap kit. they should be at operating temp within 2-3 seconds. also anything above about 5000k is decreasing light output in terms of night time visibility
llDemonll is offline   Reply With QuoteReply With Quote
Old 03-15-2019, 01:21 AM #32
gakattack gakattack is offline
gakattack will become famous soon enough
I installed the relay kit that came with the HIDs from the retrofit source.
2018 ORP, 2001 S4 Tial605, 2001 Maxima, 2013 GS350
gakattack is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 10:06 PM #33
1stTime4Runner 1stTime4Runner is offline
1stTime4Runner is on a distinguished road
Sorry to bring this back from the dead but I searched several threads and didn't really find an answer.
Running the xenon depot relay harness side to side I ran the wiring under the radiator cover, along the front of the radiator top (along the foam). I had just finished driving before the install and that area didnt seem to get very warm. Just wondering if I should add some extra loom for heat protection, or is there a better way to run it, or am I thinking into it too much?
2017 Barcelona red SR5: Bilstein 5100s, 2.5" in front, 1.5" Cornfed spacer in rear, Prothane sway bar bushings front and back, JBA Offroad UCAs, Graphite TRD wheels, 255/80/17 Cooper ST Maxx, Baja Design Fog Pods, XD 5000k HID
1stTime4Runner is offline   Reply With QuoteReply With Quote
Old 10-22-2019, 08:59 PM #34
jeroweezy's Avatar
jeroweezy jeroweezy is offline
jeroweezy will become famous soon enough
jeroweezy's Avatar
im running the morimoto elites for about a year and now my driver side wont light up from the start. sometimes it will flicker on startup but eventually when i do get two to start up the passenger will have a slight flicker. running relays on them
jeroweezy is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 12:44 AM #35
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
Nope, never installed. No issues
ForRun is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 11:44 AM #36
Narat_524 Narat_524 is offline
Narat_524 will become famous soon enough
No
Several sets of HIDs on a few different vehicles, never installed the relays, no issues.
Narat
2019 TRD ORP, Milestar Patagonia LT295/70R17, Method Trail 701 wheels, King suspension 600 sprgs, Dobinson C59-677V +400 rr sprgs, ECGS 4.56 grs, Frt E-Locker, Coastal Offroad Alu dual swing rear bmpr, CBI Alu frt bumper, SmittyBilt X20 10K Synth, Flatlink E, RCI full steel skids and sliders, DuroBumps, MetalTech RR LCA, Dual 31M/34M Northstar Batts, Blue Sea ML-ACR, LFD Offroad Bat tray, Schrockworks air pump relo brkt, ARB twin comp, Gibson exh, Infinity Component dsh and dr spkrs, Hertz HCX 165 hatch spkrs, 2x Kicker KEY 180.4 DSP amps, Kenwood TM-V71, Cobra 75 WX ST, Midland MXT275, ArcLight LEDs, XenonDepot HID low, LED High, Diode Dynamics Turn-as-Tail, Switchbacks, CaliRaised Ditch light brackets, Rigid SS Ditch lights, Stock OR wheels with 285/70R17 E GY DuraTracs, Custom drawer/sleep platform, Dometic CFX50, More lights and antennas than I can name, beer
Narat_524 is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 03:35 PM #37
dawudih's Avatar
dawudih dawudih is offline
dawudih is on a distinguished road
dawudih's Avatar
Just did the same thing as you; have you had any issues with this route?
2015 Trail
dawudih is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 11:13 PM #38
So far so good. I just hate all the extra wiring that gets tucked away. No issues with heat and wiring.
Old 01-23-2020, 02:49 PM #39
dawudih's Avatar
dawudih's Avatar
Just did my high beams with the Volt HID kit. No separate power supply is required with this vs the Morimoto HID kit I installed last week on my low beams. This thing makes light bars unnecessary. I disabled my DRL by cutting a light green wire under the dash next to my left foot rest. That took about 5 minutes, installation took about 1 hour. The only problem is the cluster of wires under the hood. Even if you zip tie and tuck everything, you can tell it's aftermarket due to the excessive length of cable. I'm using the 4300k on the lows and 4500 on the highs. The highs on the Volt kit do have a little blue tint, which I was trying to avoid. The Volt kit ballast is smaller & lower quality feeling, but it looked good on paper, so we'll see I guess. The fog lights look bad color wise, compared to the HID kits.
2015 Trail
Old 01-23-2020, 02:53 PM #40
dawudih's Avatar
dawudih's Avatar
What did you find out about this issue? Was is resolved & how?
2015 Trail
4 Rigid Lights, one switch, Shrockworks Relay distribution install MNT4R 5th gen T4Rs 21 03-03-2019 03:38 PM
Extra engine bay fuses relay install octanejunkie 3rd gen T4Rs 17 12-19-2017 04:31 PM
Remove/Install PCB Power Relay Lester Lugnut Off Topic 0 10-03-2017 11:23 PM
Is running a relay before a fuse block possible? What relay would you use? MightyP Engines / Suspension / Wheels / Tires / Audio / Accessories 3 09-28-2016 02:45 PM
