Old 01-07-2019, 10:12 AM #1
Stewart Stewart is offline
Stewart is on a distinguished road
Help me diagnose my problem.
Looking for some of you keyboard mechanics to help me diagnose the problem im having with my 4Runner.
Few details:
2010 SR5
101K miles
BFG All Terrain KO2 tires
The vehicle is always well maintained. All service intervals have been met - oil changed as required.
I think that I may need an alignment but here are the symptoms.
1) +25mph i can hear / feel a vibration that seems to be coming from the passenger front wheel area.
The sound resembles a gear whine or even road noise - you might even call it resonance..
2) I can feel a slight vibration in the steering wheel and gas pedal.
3) the sound is noticeable but know that I also have some aggressive tire tread . this sound im hearing makes the road noise from the tires even louder.
4) The brakes feel to be operating as they should - no vibration / pulsing when braking etc. Braking does not effect the symptoms im having.
5) The feel / noise happens when driving straight or turning left on a sweeping curve.
6) The sound / vibration seems to be lessened when going over undulations (Whoop de doos) in the pavement. (This could be the aggressive tire tread on the BFG's)
6) Whats puzzling is that when i turn right (Sweeping curve or highway ramp) the sound and vibration completely disappear!
So, what do you think?
Alignment issue?
Bearing Issue?
Transfer case issue?
Brake Issue?
Any help would be appreciated.
Thanks,
Stu
2010 SR5
1974 CORVETTE STINGRAY
Stewart is offline   Reply With QuoteReply With Quote
Old 01-07-2019, 10:19 AM #2
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Needle roller bearing?
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 01-07-2019, 10:21 AM #3
meder24's Avatar
meder24 meder24 is offline
meder24 is on a distinguished road
meder24's Avatar
I agree it sounds like a wheel bearing going out.
If you want it done right, do it yourself!
meder24 is offline   Reply With QuoteReply With Quote
Old 01-07-2019, 10:21 AM #4
CLO T4R CLO T4R is offline
CLO T4R is on a distinguished road
Sounds like a bearing issue to me. Jack up the front of your truck with both wheels up and see if you have any play on the wheels.
CLO T4R is offline   Reply With QuoteReply With Quote
Old 01-07-2019, 10:28 AM #5
eelliiss's Avatar
eelliiss eelliiss is offline
eelliiss will become famous soon enough
eelliiss's Avatar
Agree with all the wheel bearing responses. Classic symptoms. If you're doing it yourself, I recommend buying the full assembly.
Blue Pit Bearings | 2003-2017 Toyota 4runner 4x4
eelliiss is offline   Reply With QuoteReply With Quote
Old 01-07-2019, 10:28 AM #6
so the sound / vibration would disappear when turning? If yes, would you assume that the bad bearing would be the passenger front?
2010 SR5
Old 01-07-2019, 10:31 AM #7
eelliiss's Avatar
eelliiss's Avatar
Yes, the bad bearing would be on the opposite side of the turn you make in order to get the sound to go away.
Edit: Whoops, re-read your post. You're turning right when the sound disappears, so it would be the driver's side wheel bearing.
Old 01-07-2019, 10:34 AM #8
I would actually assume its the driver side just cause all the weight is being transferred to that side and its probably keeping the wheel hub from wobbling. But I still suggest jacking the front of your truck up and see which side has play/noise.
Old 01-07-2019, 10:35 AM #9
ok got it. sound goes away when making right turns so bad bearing would be driver side.
2010 SR5
Old 01-07-2019, 10:42 AM #10
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Agree with the wheel bearing diagnosis. I would change both front bearings as the other one is probably not far from failing too.
Old 01-07-2019, 03:37 PM #11
WindyCity4Runner WindyCity4Runner is offline
WindyCity4Runner is on a distinguished road
If your wheel bearings are OK, how many miles are on your tires? My snow tires just started making a noise like what you describe. I originally thought it was wheel bearings but it's just the tires.
WindyCity4Runner is offline   Reply With QuoteReply With Quote
Old 01-07-2019, 04:56 PM #12
i have about 20K on the tires.
2010 SR5
Old 01-07-2019, 05:39 PM #13
themaestro's Avatar
themaestro themaestro is offline
themaestro will become famous soon enough
themaestro's Avatar
I just did this myself at 75K.
go to Marion Bumper2Bumper Automotive
Different part for 4x4 or 2wd, but either way, buy 2 assemblies (driver, passenger)
Either take it to your trusted mechanic or do it yourself. I am not a serious wrench myself, but did both of mine on a Saturday. Its medium difficulty, but if you have the right tools its doable.
Watch this video: YouTube
Edit: Also, with 101K, its a perfect time to install new rotors and pads while you have the caliper off.
themaestro is offline   Reply With QuoteReply With Quote
Old 01-07-2019, 06:12 PM #14
willo willo is offline
Real Name: Will
willo is on a distinguished road
Real Name: Will
Have your tires re-balanced too.
  • You could just have lost a wheel weight
  • It'll make your new wheel bearing last longer.
willo is offline   Reply With QuoteReply With Quote
Old 01-07-2019, 09:13 PM #15
Breadman03's Avatar
Breadman03 Breadman03 is offline
Breadman03 is on a distinguished road
Breadman03's Avatar
My 2011 w/126k just had the same exact issue. @bumper2bumperauto makes a hub and wheel bearing that are already pressed together. I recently ordered 2 bearings from him and bought an impact wrench since I'm getting lazy. It took me maybe 2.5 hours to do both sides in my on-street parking, which included putting all four corners on jack stands to rotate my tires. I did both sides just to ensure I got the bad bearing.
The only negatives I experienced was that it took about 2 weeks to ship instead of the stated 2-7 days and had difficulty getting a response from the owner when I asked for an ETA. I'll gladly order from them again if I ever wear these bearings out.
Here's a link to his F/S thread.
https://www.toyota-4runner.org/for-sale-t4r-items/167122-fs-complete-front-wheel-bearing-assemblies-lowest-price-anywhere-$170-3.html#post3182774
Breadman03 is offline   Reply With QuoteReply With Quote
feel , issue , noise , sound , vibration
Help! Trying to diagnose swaying problem JustSomeName 3rd gen T4Rs 41 08-04-2022 10:14 AM
help diagnose tranny problem bloft50 3rd gen T4Rs 1 01-28-2015 11:16 AM
Help diagnose my brake problem? bgibbs11 4th Gen T4Rs 11 08-08-2013 10:20 AM
Please help me diagnose a vibration problem with my 99 4R diddlybo Maintenance/Detailing 1 07-29-2011 01:11 PM
Help me diagnose problem under the truck... AndyDe 4th Gen T4Rs 2 12-08-2006 04:04 PM
