Oil Filter from O'Reilly - Will it Fit?
GreyhoundGuy
I need to do an oil change on our 2010 Limited. I've got the oil and thought I had a filter cartridge, but appears I used my last cartridge on the last oil change.
The nearest dealership is about 45 minutes away, but I have an O'Reilly Auto Parts about 10 minutes away. The O'Reilly website shows they have a Wix filter that will work. I just want to verify that the size and everything is compatible before driving to go get it. (I'd hate to pick it up, drive home, start the oil change, only to find out it doesn't fit.)
Anyone run this filter for O'Reilly?
Thanks in advance.
-Joel
Thanks in advance.
-Joel
It'll probably work to I'd highly recommend a Toyota one though. They are cheap so just keep several on hand.
WIX makes a good filter, Ive used NAPA GOLD 5173 which is also a WIX filter. May be the same one you posted. No issues to report.
Wix filters are made to "Meet or Exceed OEM specification". This means it works. Never use "High Quality" filters. Whose definition of High Quality? Napa filters are rebadged Wix, a good thing.
Some filter companies that "Meet or Exceed OEM Spec" do not make every make/model of filter. They will buy other filter companies and have their product name stamped on the filter. Last I heard no one trades with Fram. Fram is High Quality, whatever that means.
