2018 Glove Box light replacement
Are you sure the bulb is burnt out? The headlights need to be on for the glovebox light to be on as well.
If it is burn out, there is a little hinge you just pop open, then use some needle nose pliers (don't shatter bulb) to pull down to pop out. Then replace. I replaced mine with LED bulb as it's a bit brighter.
I am replacing with a LED as well. Just cant for the life of me figure out how to get it out, lol.
