02-19-2019, 12:04 AM
#16
looks perfect. the wheelers rear springs ride great too.
02-19-2019, 09:51 AM
#17
ah so you went with the 600 pound coils that are an inch longer 3x14 from 3x13
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
02-19-2019, 07:29 PM
#18
That is correct. I used the coils from a Bilstein 6112 kit.
2017 Toyota 4runner TRD Pro
2012 Toyota Highlander
02-19-2019, 08:22 PM
#19
Measurements
Hey nice setup, I’m going this route. Do you mind posting the measurements from ground to fender and hub to fender?
02-19-2019, 09:38 PM
#20
I actually took some pictures of the measurements this morning from ground to fender. Dead even from front to back. I did not expect that.
Front pic
Rear pic
02-20-2019, 03:42 PM
#21
Any concern with down travel and topping out the factory shocks, front or rear, with this setup?
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
02-20-2019, 04:45 PM
#22
How much did you lift your rear? I'm looking to add a similar setup to my 4runner and wanted to compare.
02-20-2019, 05:44 PM
#23
Originally Posted by speedyglx
No clip setting. The shocks are from a TRD Pro. They have no clip settings like the 6112 shocks. The rears I kept stock. Same as the front, just replaced the coil.
I don't understand. You said you put 6112 on your TRD Pro which I assuming you took the OEM TRD Pro Bilsteins off. Were the 6112 not adjustable height?
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
02-20-2019, 05:54 PM
#24
No he used the 6112 springs ONLY with the factory TRD shocks.
Paul
02-20-2019, 05:58 PM
#25
02-20-2019, 06:09 PM
#26
Did you use wheel spacers OP? If so, which ones?
02-20-2019, 09:01 PM
#27
No because TRD Pros use the same shock as the shock from the Bilstein 6112 kit. Just no adjustments.
Wheeler T13 coil suppose to have a lift of 1.5 inches, I believe I got around 1.25 inches of lift.
Bayou_Pro and Akkording answered that question. Thank you.
02-20-2019, 09:02 PM
#28
No wheels spacer.
02-20-2019, 10:22 PM
#29
No wheels spacer.
Interesting, I am running 275's on my 2018 Pro with the stock Bilsteins and 1.5" top hat spacers and I don't think my wheels stick out anywhere near that much. I like the look.
02-20-2019, 11:23 PM
#30
I don't think they stick out that much. Here is another shot.
