12-29-2020, 03:45 PM
#31
Originally Posted by Pirateghost
What keeps the Baxter spin-on adapter from coming loose when you remove the spin-on oil filter?
The adapter is tightened to a higher spec than the spin-on filter. So unless the oil filter is grossly over-tightened, the adapter won't move.
12-31-2020, 07:13 PM
#32
[QUOTE=02SE;3584645]I like cartridge filters myself. I don't consider the oil change procedure to be that big of a deal, and I like being able to inspect the filter element without having to cut open canister filters.
The plastic housing is no problem either, unless you run into a ham-fisted hack lube tech, who over-torques the housing, and strips the skid-plate fasteners with his trusty impact wrench.
Which is why I do my own oil changes, and those for immediate family.
Nailed it ! I agree with everything you said.
2010 4R SR5, "best 4 wheel vehicle that I've ever owned" TRADED !
2019 4R TRD Off Road
12-31-2020, 10:02 PM
#34
Originally Posted by Saker
Don’t forget about the guy that drops your plastic filter cover and puts a hairline crack in it only to fail while driving down the road.....
that’s why my first oil change on this T4R will go to aluminum!
YMMV
With my (new to me) 2016 w/100K miles I replaced the plastic with the aluminum version. Glad I did because when I went to take it off it was WAY over torque and wouldn't have trusted it. Good call to make the switch either way.
Sent from my Pixel 3 using Tapatalk
[ Smeerun's Build Log] - 2016 4Runner Trail Premium MGM w/KDSS
Exterior: Toyo OC A/T III 265/70/17 (TE Wheels) | Dobinsons UCA's + C59-302/GS59-700 Front + C59-500/GS59-705 Rear | C4 Rock Sliders | SSO Roof Rack | Ironman 8.5" Awning | Tacoma Low-Profile Antenna | Diode Dynamics SS3 Pro Fogs | CTH Folding Mirrors + LED Sequential Blinker Mirrors
Interior: VanTrue N4 3-chan Dashcam | Husky Liners Floor Mats | Canvasback Rear Covers | Blue Ridge "Attic"
01-02-2021, 12:11 AM
#35
Real Name: Chris
Real Name: Chris
Same here, I had a HELL of a time getting that damn thing to break loose, it was WAY over torqued after my "Toyota Care" aka Toyota doesn't care oil change. No Toyota tech will ever touch my oil filter again God willing, and I just did the metal housing swap so now I'm more comfortable taking it off in the future
01-02-2021, 11:10 PM
#36
I knew when My wife bought her ‘14 4R new back then that the plastic housing would break.
I bought a dealer replacement and packed it away in a closet.
No doubt some Sunday the thing will crack during removal/installation.
I’m ready.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
03-21-2021, 06:53 PM
#37
Real Name: Jonathan
Real Name: Jonathan
Add me as another one switching to the metal Avalon housing.
I always laugh at the people on here that are like "drr, plastic bad, metal good, why Toyota use plastic? I'm smarter than a Toyota engineer." But I guess the dealer techs abused my housing over the years. I'm out of warranty now so did my oil change this weekend. It took a damn breaker bar to get the housing off which is excessive for something that should only be tightened to 18 lb ft, and it looked like two of the tabs got a little bent when I took it off.
So I put it back on and torque it to spec and those two tabs snapped off and its now leaking where one snapped off. Awesome. Ordered the metal Avalon housing. Sounds like I'll just lose the oil that was in the canister and not the entire system, so that's good. Can anyone confirm that the stock filter drain plug fits on the Avalon metal filter canister?
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
03-22-2021, 08:00 PM
#38
Banned
Real Name: Mark
Banned
Real Name: Mark
I always laugh at the people on here that are like "drr, plastic bad, metal good, why Toyota use plastic? I'm smarter than a Toyota engineer." But I guess the dealer techs abused my housing over the years. I'm out of warranty now so did my oil change this weekend. It took a damn breaker bar to get the housing off which is excessive for something that be should only be tightened to 18 lb ft, and it looked like two of the tabs got a little bent when I took it off.
Yes, if you ordered Toyota part number 15620-31060. Swap the drain plug (with gasket) and the inner mesh tube.
03-22-2021, 09:27 PM
#39
Real Name: Jonathan
Real Name: Jonathan
Thanks! Can confirm personally as well now. Got the metal canister today from a local dealer and it's a perfect fit and the drain plug from the 4Runner's plastic canister screws right in. The center pickup tube is easy to swap out. I lost just under 1/2 quart of oil in the swap, so topped it off and should be good to go now.
