Old 06-18-2018, 12:55 PM #1
TRDDavid TRDDavid is offline
TRDDavid is on a distinguished road
Lift Options For KDSS
Hello Everyone,
I have had my ‘17 TRD ORP W/KDSS for about 7 months now and I’m loving it.
I’m currently running some 3” spacers that I put on a few weeks after getting the car, but now after a few large mods the stock suspension is starting to sag, so it’s time for a proper lift.
My only issue is since I have the KDSS option I’m not really sure what lift kits I can and can’t get. I have seen several threads for HOW to install a lift kit with KDSS, but not much on WHAT to install.
I’m looking for something around 4” with a mid to heavy duty option to support the added weight. Any of you guys that have installed something similar with your KDSS equipt rigs?
Side question, what is the tallest I could go without having to add supporting mods (UCAs, Dif Drop, etc), and if I did decide to go over that limit what would be the list of necessary supporting mods to make it happen?
Thanks, any input is appreciated!
TRDDavid is offline   Reply With QuoteReply With Quote
Old 06-18-2018, 06:43 PM #2
4RNEWBIE 4RNEWBIE is offline
4RNEWBIE is on a distinguished road
3 inches about the max you can go with KDSS.
I went with Bilstein 6112/5160 combo, Icon light springs in rear and 700lb springs up front. I did add UCAs to avoid any alignment issues. Vendor told me it was not necessary, but was leaving on a trip the week everything was to arrive and did not want alignment issues to be a factor.
4RNEWBIE is offline   Reply With QuoteReply With Quote
Old 06-18-2018, 07:02 PM #3
mybabydaddy's Avatar
mybabydaddy mybabydaddy is offline
mybabydaddy is on a distinguished road
Will take some time, but google “5th gen 4Runner lift KDSS”.... you should get plenty of hits for T4R.org with threads discussing your topic. Don’t think you can go much above 3 inches tho w/our removing KDSS all together.
Happy hunting.
2017 Porsche Macan GTS - Carmine Red w/ matching side blades
2014 Black TEP w/ KDSS / nFab steps / Yakima Cross Bars / Bilstein 5100s (front at 1.75) / 1 inch rear Cornfed Spacers / FN Countersteer Type X / Nitto Terra Grappler G2s 265/70/R17 / RCI Aluminum (front) Skid - sold
2011 Silver Limited - sold
2007 SE Shadow Mica - sold
mybabydaddy is offline   Reply With QuoteReply With Quote
Old 06-18-2018, 07:47 PM #4
Badmeat's Avatar
Badmeat Badmeat is offline
Badmeat is on a distinguished road
Badmeat's Avatar
http://www.toyota-4runner.org/5th-ge...s-choices.html
2003 Ltd V8 - The RST RNR & 2019 Tundra TRD Pro
ALL SOLD:
2015 Inferno TRD Pro
2013 SR5-P
2001 SR5
Badmeat is offline   Reply With QuoteReply With Quote
Old 06-19-2018, 08:27 AM #5
billnourse's Avatar
billnourse billnourse is offline
billnourse will become famous soon enough
billnourse's Avatar
I have a Toytec Ultimate 3" with 650 front coils on a 2017 with KDSS. Have about 13,000 miles on it with no problems or issues. It holds a SSO Slimline front bumper and 10,000# winch.
Bill
billnourse is offline   Reply With QuoteReply With Quote
Old 06-19-2018, 09:03 AM #6
alphabeast's Avatar
alphabeast alphabeast is offline
Real Name: Shawn
alphabeast is on a distinguished road
alphabeast's Avatar
Real Name: Shawn
KDSS has very little bearing on a suspension based lift up to 3"... except of course what is involved with the installation.
2014 TE w/ KDSS: ToyTec BOSS Suspension Kit / Toytec 1" Body Lift / JBA A-Arm's / Cooper Evolution MT 35" 12.5" / SCS Ray 10 17 X 9 / Budbuilt Bump Out Slider's / Gobi Stealth (No Rise) Rack / Hefty Fabworks Front Bumper / Ellis Precision Auto Shifter & Transfer Case Shifter/ Rigid D-Series LED Fogs / Precision LED Interior Lighting
alphabeast is offline   Reply With QuoteReply With Quote
Old 06-19-2018, 03:08 PM #7
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
Beyond 3" lift you might want to consider canceling the sway bars.. though that defeats the purpose of having a KDSS vehicle.
I'm close to 3" lift without issue so far.
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 06-19-2018, 03:57 PM #8
TotalAutomotiveLV TotalAutomotiveLV is offline
TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about
Here are 2 great options we have a struggle keeping in stock;
ICON Stage 2 Kit - K53062T
Comes standard with 650lb coils.
*You need to add Adjustable Track Bar for KDSS, Part #54200
KING Coilovers, Part #25001-243 and Rear Shocks, Part #25001-279 - Click Here
We stock these with Extended Travel and 600lb coils.
*KING Coilovers come standard with 550lb coils, but can be upgraded to 600, 650 and 700lb and no extra cost.
*You can also order Extended Travel at no extra cost.
Hope this helps with a couple options for KDSS owners.
When ordering online, remember to use Promo Code "T4R" for added savings on most brands.
_
TotalAutomotiveLV is offline   Reply With QuoteReply With Quote
Old 05-15-2019, 09:11 PM #9
Immortan joe's Avatar
Immortan joe Immortan joe is offline
Immortan joe is on a distinguished road
Hey all, I am new here and not sure if this is the best thread to ask this on but I have 275/70/17 k02s on a stock kdss and the wheels are rubbing on the front fender and rear body mount. Does anyone know if the 5100 Bilstein 0.85 will alleviate this ( I wouldn't mind leveling out the rake) and also would this be compatible with the KDSS? Thanks for your help.
Lift Options For KDSS-5a6a4a87-e6bb-4dc6-aefd-0813ea0dd88c-jpg
2019 4runner Offroad Pre
KMC XD 132
BFG k02 265/70/17
Twin ARB Compressor 1 gallon tank with remote house
Gobi stealth rack
Immortan joe is offline   Reply With QuoteReply With Quote
Old 05-16-2019, 02:31 AM #10
DesertCanyons's Avatar
DesertCanyons DesertCanyons is offline
Real Name: Dave
DesertCanyons will become famous soon enough
Real Name: Dave
ICON Lift with KDSS
I have the tubular variety (not Alum billet) ICON Stage 7 lift with extended travel for about 3" of lift. The tubular UCA is required for that high of a lift and it's recommended for achieving the correct front alignment. I got the sealed Delta joints. TALV helped me put together the package for a good price.
Everything went great. I installed it in my garage. Don't ask me how long it took, but be prepared to park the car for a few days and not drive it while you finish. It can be done faster but you need a car lift and a shop to do it faster.
Yes, there are good threads here about installing the lift with KDSS. I read them all and printed one out before I started. I had that and the ICON instructions in a binder on the table for reference. You need to know the spec' torque for every bolt before you start. I found that from reading posts here. There's a Toyota illustration floating around here of the front and rear end suspension system that shows the torque for each bolt. I hear it's in the repair manual. There are several good videos on YouTube that are helpful. Also make a list of all the tools that are recommended and have them on hand before you start.
You need a floor jack, jack stands and cylinder jacks. You need to jack the KDSS up with a cylinder jack and it helped me to strap the front KDSS piston in place while I worked. Be safe. Make sure the car is fully supported by jack stands before you get under it. Maybe you know some of this from putting spacers in.
I feel like the Stage 7 trailing arms and trac bar did not add much since the instructions say to set them the same length as the OEM stock. I am not sure if my alignment shop checked the rear alignment or could adjust it better. The trailing arms are bigger and stronger. But looking at the upper rear trailing arm you can see it's only a relatively narrow solid rod, leading me to conclude that it's tension-only, so having a big tubular upper arm didn't add any strength, IMHO.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
DesertCanyons is offline   Reply With QuoteReply With Quote
Old 05-16-2019, 04:14 PM #11
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
I have about 75,000 miles on my 3"/3" lifted rig with KDSS. No issues so far.
Big benefit of KDSS on a lifted rig is stability on road. If you top load your rig it can get pretty precarious on turns. (Also think existing load riding higher due to lift.)The extra sized sway bar and KDSS help a lot to counteract that.
3" is generally considered the high end for KDSS equipped rigs. However, the last link I referenced below would provide a solution allowing you to go long travel rear with KDSS. I might go down that path next.
see these threads for good info:
Let's talk about KDSS and sway bars
5th Gen. KDSS vs. Non-KDSS handling performance & sway bar diameter differences.
New Sonoran Steel Product: KDSS High Articulation/Long Travel Trac/PanHard bar
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 05-16-2019, 04:56 PM #12
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
Toytec Boss. It's 3" up front and 2" in the back (levels it) but I actually got 4" more over the front skid which was great. Over 20k on mine now and great so far. Since the KDSS will push the wheel downward for more articulation (main reason I got KDSS), the Toytec Boss provides you with longer travel shocks. If you don't your shocks may lock out before you get to full articulation.
In addition, I recommend the Sonoran Steel Trac-bar as others have said. This will give you even more articulation if you have the long travel shocks installed with it. I installed this myself, but if I were to do it again I would probably hire someone to do it with better tools than I have available. I got it done but it wasn't easy for me with the limited tools that I have.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 05-16-2019, 05:13 PM #13
TEujunga's Avatar
TEujunga TEujunga is offline
TEujunga has a spectacular aura about TEujunga has a spectacular aura about
TEujunga's Avatar
Your wheels look like they stick out more than stock, which is likely the source of your rubbing issues when turning. If you have wheel spacers, try removing them.
No problem installing Bilstein 5100s at any available height, including 0.85". They will be compatible with KDSS, but likely won't have much effect on your rubbing issues.
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
TEujunga is offline   Reply With QuoteReply With Quote
Old 05-16-2019, 05:28 PM #14
CSM4runner's Avatar
CSM4runner CSM4runner is offline
CSM4runner is on a distinguished road
CSM4runner's Avatar
I have a 2016 trail with KDSS. I went with Dobinson since they make one specifically for T4R's with KDSS.
Dobinsons 5th Gen T4R Suspension options - lots of choices
this is the set-up i got;
C59-314 x 1
GS59-574 x 2
DD59-527K x 1
C59-725 with KDSS x 1
GS59-701 x 2
BJ59-001 x 2
It was a PITA to install but drives great and zero issues.
2016 4Runner Trail w/KDSS / Dobinsons 3/2" / Camburg UCAs/ KO2 275/7017 / Light Bar / Raptor Lights / Rockford Fosgate amp/ Rockford Fosgate P3 subwoofer / Thule 60" Aerobars
CSM4runner is offline   Reply With QuoteReply With Quote
Old 05-16-2019, 05:40 PM #15
Russlow Russlow is offline
Russlow is on a distinguished road
4 used S.O.T.A wheels for sale , 20x9 $400 firm. 1 year old. Located in duluth, georgia. Local pickup only. [email protected]
Russlow is offline   Reply With QuoteReply With Quote
Hi-Lift Gear: Best options for no Hi-Lift-ready rails/bumpers? eric_rosenwald 3rd gen T4Rs 3 06-04-2017 10:47 PM
Help! Lift with KDSS? redkaz04 5th gen T4Rs 15 05-04-2014 10:46 AM
Rear lift options with toytec/eibach front lift cma1188 3rd gen T4Rs 3 10-06-2013 01:40 PM
KDSS and lift sullyman New Members 0 06-12-2012 09:31 PM
Options for Upgrading Non-KDSS Suspension on a TE jerlane 5th gen T4Rs 10 04-19-2012 06:47 PM
