Old 04-01-2019, 01:51 PM #1
oakjefferson oakjefferson is offline
oakjefferson is on a distinguished road
Rear Gate handle coming loose - how to fix?
The left side of my handle is coming loose. I can see the screw coming out when I pull. I took the inside panel off but still can't access the screw. Any idea if I need to cut through the plastic inside to get access, or perhaps can I pop off the Toyota name/logo on the outside?
link to pics of issue
Imgur: The magic of the Internet
I found this old thread about removing decals- I'm wondering if this is the only way to go. If so - how to I put that plastic film back on (and take off without damaging)
Anyone remove the 4runner emblem on a 5th generation?
2012 SR5 Upgrade package. Stock as of now.
oakjefferson is offline   Reply With QuoteReply With Quote
Old 04-01-2019, 02:01 PM #2
the_fornicator the_fornicator is offline
the_fornicator has a spectacular aura about the_fornicator has a spectacular aura about
Never had to do a 5th gen before but with my 2nd gen, all handles had to be tightened from the inside. So, the interior shell of the trunk would have to be removed to access that bolt -window would have to be rolled up.
Maybe. Sorry, im no help lol
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
the_fornicator is offline   Reply With QuoteReply With Quote
Old 04-01-2019, 02:21 PM #3
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
Lucky you I just had mine off the other day
You have to remove the interior tailgate trim.
1. Tailgate trim:
  • Remove the small plastic cover at the strap, remove the 10mm bolt and lay the strap to the side.
  • Use a trim tool on the left side of the tailgate lamp cover to remove, unplug the wire harness.
  • On the passenger side locate the arrow on the side of the tailgate trim. Using a trim tool gently pry the trim outward. Grab a large flat trim tool and work your way around the side and bottom releasing the white plastic retainer clips, I think there are 7 total and 2 in the center of the trim.
2. remove the two bolts holding the MCU bracket.
3. then gently peel back the vapor barrier (do it on a cold day the butyl rubber seal isn't nearly as messy as when it is hot out)
4. get a 7mm shallow socket and from the backside work the two white retainer clips that are holding the MCU bracket. Rotating the socket on the back of the clip while you gently pull will release the clips stays allowing you to remove it without trashing the clip.
5. disconnect the two MCU wire harnesses and the light/tailgate harness on the top and set that aside.
6. finish removing the vapor barrier and lay it off to the side carefully, so that you don't fold it back on itself (if you do your most likely buying a new one) the Butyl is tacky when warm be careful with it.
7. with that out of the way you should see 4 bolts and two retaining clips that hold the tailgate latch handle trim. Remove them and put some either purple or other "removable" Loctite on them and snug, don't over-tighten.
8. clean out any munge that seeps down from the rear window in the bottom of the tailgate and make sure all the drains are clear while you have open.
9. Carefully install the vapor barrier, install the MCU bracket, connect the harnessess, replace the trim, connect the lights, replace the lift strap, done
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 04-01-2019, 02:21 PM #4
BP22's Avatar
BP22 BP22 is offline
Real Name: Brandon
BP22 will become famous soon enough
BP22's Avatar
Real Name: Brandon
I had the same thing happen to mine. You need to remove the interior panel and pull of the plastic sheeting. It's best to pull it off fast, it will retain it's stickiness and you can reapply. There are two bolts coming through that have nuts on them. On mine one of the nuts had come off and was inside the liftgate. I put some locktite on the bolts and put the nuts back on. So far so good.
Brandon
2015 T4R Trail Edition Premium
2002 T4R Sport 4WD
1991 LC FJ80 (Sold)
1995 T4R Limited 4WD (Sold)
BP22 is offline   Reply With QuoteReply With Quote
Old 04-01-2019, 02:34 PM #5
AH!!
I've heard something rattling around in the rear gate. I thought my kid dropped something tiny down the window slot - it's likely the nut you're talking about.
thanks!
Old 04-01-2019, 07:10 PM #6
jrandom's Avatar
jrandom's Avatar
Peeling it off fast, gees, I guess so? When the strands get long push it back down and start to peel again. You know kind of like when you use a part of a sticker to remove a the gunk from sticker (don't know any other way to explain it) You can use a piece of the butyl to remove itself this way. Then clean any residue up with isopropyl alcohol.
The dealer trashed mine replacing the backup camera and did a real S##T job putting it back. I bought a new one for $12 and 3M 08620 1/4" x 15' butyl tape and fixed their "warranty" work. Dumbass me didn't snap a pic before hand only after.
Also note that the retaining clips all have foam washers, in case you happen to see one lying on the ground
Rear Gate handle coming loose - how to fix?-img_9496-jpg
2013 TE w/ KDSS Nav
Old 04-02-2019, 08:12 AM #7
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Be careful, that black adhesive stuff is hard to get off things! I did mine 7 years ago when it came loose. Used blue loctite and its held since.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 06-24-2023, 01:17 PM #8
beedee beedee is offline
beedee will become famous soon enough beedee will become famous soon enough
Im glad I found this thread, as the left side of my rear garnish was noticeably loose. I followed the directions posted here and was able to fix it. While I was in there, I took off each of the 10mm nuts one at a time, applied blue loctite to them, then put them back on. All is well.
beedee is offline   Reply With QuoteReply With Quote
Old 06-25-2023, 02:41 PM #9
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Here’s another thread with more pics.
Removing rear hatch cover
1000MPH is offline   Reply With QuoteReply With Quote
access , coming , inside , loose , screw
Sloppy or loose door handle feel? falkon240 3rd gen T4Rs 0 07-05-2017 06:20 PM
Wtb 4th gen rear gate soft handle mechanism boostedprozac Want to Buy/Trade 0 07-24-2015 03:52 PM
Loose Shifter Handle? bradentyrer 4th Gen T4Rs 1 10-01-2013 11:12 PM
Rear Lift Gate Broken Handle Nash4 3rd gen T4Rs 5 04-10-2013 02:58 PM
rear lift gate handle zgensler31 3rd gen T4Rs 2 05-19-2012 10:45 AM
