Old 06-21-2020, 03:16 PM #1
4boer2's Avatar
4boer2 4boer2 is offline
4boer2 is on a distinguished road
4boer2's Avatar
Steering Rack or Inner Tie Rod?
Hello all, I am having trouble diagnosing a minor inconvenience and wondering if someone here could lend their opinion. Over very small bumps I can feel a knock through the steering wheel. I can easily reproduce it if the car is stationary and I saw at the wheel. On the ground I can't tell where it is coming from, so I got it on a lift. I shook the driver's tire at 12 and 6 and 9 and 3. Both tests felt connected and solid. Over to the passenger side 12 and 6 felt good, which means the wheel bearing is good, but 9 and 3 is where the noise is. See the attached video. I know the outer tie rod is good because I already changed it. I know it's not driveline or suspension related because the noise still happens with the weight off the wheels. So to me that narrows it down to the passenger inner tie rod or the steering rack itself. I think (and hope) it is the inner tie rod because if the rack was bad shouldn't the 9 and 3 test on the driver's side yielded the same result? What do you guys think?
Volume all the way up on the videos, I promise there are no jump scares.
IMG_4546 by Patrick Heyboer, on Flickr
FullSizeRender by Patrick Heyboer, on Flickr
4boer2 is offline   Reply With QuoteReply With Quote
Old 06-21-2020, 04:20 PM #2
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Interested in what you find. Might be your CV axle?
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 10:07 PM #3
4boer2's Avatar
4boer2's Avatar
After doing as much research as possible and coming up with no conclusion, I took it in to dealer today for an official diagnosis. I'm quite happy with that decision because I was completely wrong. "Inspected intermediate shaft. Found shaft steering rack side u-joint to be worn and dirty. Noise emanating from shaft. Recommend replacement of the intermediate shaft." I'll fix it at some point. Turns out some others have had this problem and I didn't need to create this thread, but I was so convinced it had to do with one side. This is why I am not a professional. Below are the threads with the same problem and solution.
2012 Toyota 4Runner SR5 4.0L V6 4WD AT Steering Shaft. Shaft, Steering Intermediate, NO.2 - 4520360181 - Genuine Toyota Part
Steering Rack Bushings
Ideas identifying this steering rattle? - Toyota 4Runner Forum - Largest 4Runner Forum
Old 06-26-2020, 12:49 PM #4
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Good to have a diagnosis and it's something you can do yourself, although a little pita it's not much $$$!
good , rack , rod , tie , wheel
Steering Rack Replaced now Steering wheel off, Please help! 4Runner4TW 3rd gen T4Rs 24 03-07-2023 01:00 PM
Excessive play on drivers side steering - replace steering rack guide cheeser 3rd gen T4Rs 17 05-05-2022 08:15 PM
Power Steering Pump or Steering Rack? *VIDEO* LexusFTW 3rd gen T4Rs 44 08-11-2021 10:11 AM
Steering Rack and Power Steering Pump Replacement thebrandon 3rd gen T4Rs 5 07-02-2013 10:07 AM
Power steering/steering rack question (need help fast) alex bland 3rd gen T4Rs 9 01-09-2010 07:37 PM
