Jarheadoo7
I had the front end torn down today and noticed under the plastic cover, each hole a push pin went into, the plastic had rubbed the paint down to the metal on the radiator cross bar.
Also pulled the battery and under the plastic tray was all worn down from vibration.
So, if you order a can of por-15 you now have:
- Under the rear spoiler
- under the front plastic over
- under the battery tray
- under the plastic door sill covers
- rear hatch, under lower weatherstripping, above the bumper
I also put some flocking tape down in all these locations to protect from future rubbing.
Por-15
POR 15 45032 - 4oz Can Gloss Black Rust Preventative Paint - Paint Over Rust! (Single Can) https://www.amazon.com/dp/B00Q0I62IU/ref=cm_sw_r_cp_api_i_t7rTCbBG8990A
Flocking tape
J.V. Converting FLOCK-1/BLK05833 JVCC FLOCK-1 Flocking Tape: 1/2" x 25 ft, black https://www.amazon.com/dp/B01B5FNRA8/ref=cm_sw_r_cp_api_i_z9rTCbV2HFD89
Por-15
Flocking tape
