05-21-2019, 09:11 AM
Stock 4Runner on trails
I would like to hit some trails in my ORP however I don't have any plans on modifying the suspension or putting rock sliders on it, how capable is it in stock form?
I am still a rookie when it comes to OHV driving. Easy to medium trails, nothing too hard core.
05-21-2019, 09:31 AM
Looks like your in Charlotte. I'm a recent transplant to the area and just made my first trip to Uwharrie National Forest last weekend in a 2015 Trail with totally stock suspension, just has Nitto Terra Grappler G2 in stock size and RSG rock sliders. Only did the "easy" trails and had no real issues. The skids got some love here and there due to the "low" ground clearance of the stock suspension and long wheelbase but just had to go slow and find good lines. It was just me and the wife solo, ran in to plenty of helpful people along the way. Overall good experience. And as an extra bonus my wife is now so worried about me damaging the 4Runner she actually asked if there was anything we could do to make it work better on the trails, she actually asked about a lift. Gotta keep the wife happy. R.I.P my credit card!
Not sure how much worse the harder trails are but I was only really limited by ground clearance on the trails I tried.
Go slow and easy and you should be fine as well.
2015 Trail Edition Premium - Nitto Terra Grappler G2 265/70/17 - The rest is the way Toyota built it....for now!!!
05-21-2019, 10:19 AM
Despite my modifications over the years, I still say the 4Runner is immensely capable of running in stock condition. Just keep an eye on clearances and be away of step side rails if you have them.
Getting yourself some serious skid plates, tires, and rock rails will get you places you cannot believe!
Mark
04 V8 SE, RST Twin stick conversion. 4x4 Labs rear bumper, SW Sliders & Bullbar, ARB Locked F&R, 5.39’s, Smittybilt 10,000lb winch, 1.5 4Crawler BL, Flowmaster, CB and 2m/70cm Ham, Sat. Radio, CO2 system, Lightforce, African Outback Rack, Budbuilt, Front Runner RTT. Rock Solid Toys Solid axles, Atlas Crawl Case, 40" Cooper STT Pro's on Fuel Anza D116 beadlocks, 5:38 gear set, ADS Coilovers.
05-21-2019, 10:46 AM
Very nice, welcome to Charlotte. How did you decide what trail to hit?
05-21-2019, 10:48 AM
Real Name: BobH
Real Name: BobH
You will be surprised on how well it will do on sand and trails. I ran the OEM tires the first 2 years and went on deep soft dune sand and rough dirt trails.
I have gone through a few rock gardens, nothing big, not rock crawling and did OK.
Just remember you have 9.6 inches clearance and watch the surface in front of you. Watch for sharp rocks and rocks that may hit the tire sidewalls. I have a few scrapes on my front skid plate but no damage.
Take it slow and watch the terrain closely.
IMO you should air down for trails, it softens the ride for you and the T4 and gives some traction help. I run 20 psi for trails and 15 for sand. You will need a compressor to air up when done.
Take that thing out and get it dirty. You can go where the 2WD trucks can't go.
05-21-2019, 10:54 AM
05-21-2019, 02:06 PM
Real Name: KE0OIC
Real Name: KE0OIC
Very capable! A lot of people think they need a bunch of modifications for offroading but that's just not the case. Add-ons and modifications just give you marginally better capability and better body protection. I always recommend that people go out stock and them figure out what additions they want to add.
Do consider ditching the steps. It's hard to see exactly what yours are like but if they're not designed to be sliders they're probably attached to the body rather than the frame and also will bend rather easily and get pushed up into the body. In either case you can end up with body damage where without them you would have cleared the object easily.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
05-21-2019, 02:10 PM
I really just did some research to find how the trails were rated and since it was my first trip there decided to go with the simpler trails. Even those required me to stop and get out a few times to find a good line or check what was on the other side of a hill before moving on.
05-21-2019, 02:44 PM
I am sure it is just not us two from the CLT area on this board. Maybe we should all get together and go out on a trail, hopefully teach me a thing or two.
05-21-2019, 04:49 PM
Real Name: Peter
Real Name: Peter
2016 MGM TEP w/KDSS - Bilstein Leveling Kit, C4 Sliders & Summit Ladder, FN BFDs, GFC RTT
Instagram
YouTube
05-21-2019, 05:10 PM
Tires are limiting factor way before ground clearance, etc.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You can’t grasp its vastness from a plane. It’s diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
05-21-2019, 06:15 PM
Even though I am new here, I have been wheeling for many years. Best advice is the same as others have said. You should learn what your vehicle and you can do with your Stock truck. Then modify if needed! First mod I will on mine, is tires. Second rocker protection/sliders. I love going places in a stock 4x4 and seeing the look on others faces! How did you do that! There are not many vehicles made that can go and do what your stock 4Runner can! Vance.
99’ Limited, 3.4 V6, auto, elocker. Completely stock, starting out under my care with 112k.
05-21-2019, 07:13 PM
Real Name: Tom
Real Name: Tom
Tires alone will really unleash a ton of the 4Runners potential. That said we have done some pretty amazing things with stock SR5 with stock tires! I suspect there was some scrapes/damage to body on a stock rig on Broken Arrow! A little lift on that trail is very helpful.
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
05-21-2019, 07:29 PM
We bought our OR in March of last year and headed to Durango area and Moab in August with the only relevant upgrade being tires. We went in to a local Jeep rental spot and I just asked the guy working there if he'd sell me a trail map and be willing to recommend some trails we could do in our stock suspension 4Runner with LT/E tires. He gave us a few places and listed them starting with "Here's where we take stock Jeeps etc. all the time" ranging on to "Don't even think about attempting this without lockers, a lift, a winch and friends". It was a big help to know what we were getting in to. From there it was simple: if we are uncomfortable with the look of it, we don't go any further and turn around. A few times, my wife (the 4Runner owner!) got out to check clearances so we could get a feel for what we could easily cover.
There's a lot of beautiful country to be seen and a stock 4Runner will get you to a lot of it. I'm learning all the time and with every trip.
That said, our next mod will probably be sliders; practical protection that pay for themselves in the first oops.
Oh the two primary things were did were Kennebec Pass near Durango and Yankee Boy Basin near Ouray. They're on Dangerous Roads website if you want to see some pics and videos. Have fun and be safe.
Her, Him & The Moose (RIP Moose 2010-2020) - Adventure bound
2018 TRD Off Road - First 4Runner!
@mooset4r on Instagram
05-21-2019, 09:24 PM
Real Name: Bob
Real Name: Bob
Originally Posted by Gone2vegas
That was great!
2018 TRD ORP, MGM, Xpel 35% Tint, Xpel Clear Bra, In-Dash 2m/70cm Icom Radio, Dual-band 1/4 wave antenna with Rago Mount, sPod Bantam, 2 x 32" behind the grille LED lightbars, Cali Raised 3-way Fog Lights.
Sold: 2011 SR5
