Old 05-22-2019, 10:09 PM #1
The_Green_Wang's Avatar
The_Green_Wang The_Green_Wang is offline
The_Green_Wang is a jewel in the rough The_Green_Wang is a jewel in the rough The_Green_Wang is a jewel in the rough
What bump stops are you running?
Hey guys,
Saw some post but most were old or a specific one. What bump stops are you running for both front and rear and how do you like them? Normal rubber bump stop or hydraulic bump stops? Looking into purchasing some to make the ride performance better and smoother.
Nick
Sent from my SM-N950U using Tapatalk
The_Green_Wang is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 10:45 PM #2
williamlv282's Avatar
williamlv282 williamlv282 is offline
williamlv282 will become famous soon enough
DuroBumps
1987 Classic Silver 22re - Stock
2015 Classic Silver Trail Premium
Lift: Dobinson C59-314 Front Coils, C59-725 Rear Coils, Total Chaos Upper Control Arms
Wheels: 17x8.5" FN Overland Spec B Gunmetal
Tires: 285/70/17 Cooper Maxx S/T
williamlv282 is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 10:53 PM #3
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
energy suspension in the front
Timbrens in the rear
i like this setup a lot...
I had the toytec extensions w/ oem bumpstops before and that sucked donkey balls
Old 05-22-2019, 11:01 PM #4
MyanRagahis's Avatar
MyanRagahis MyanRagahis is offline
MyanRagahis will become famous soon enough MyanRagahis will become famous soon enough
I'm using Wheelers Superbumps up front and rears are Durobumps.
Haven't gotten to test the rears yet.
Fronts were an immediate difference to me. Control arms would actually make contact with the bumps with my lift rather than not at all with stock bumps. Drops and bumps are much softer and squishier with them, even just driving down the driveway.
I made a video of the fronts.
YouTube
YouTube
MyanRagahis is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 11:07 PM #5
mrblah's Avatar
mrblah's Avatar
YouTube
your youtube video was what made me buy new bumpstops and the fact that i got tired of feeling my teeth rattle over corrugations, speed bumps and pot holes.
I also noticed rub marks on the suspension components where it impacted the oem bumps, when I was fixing other things wrong with my suspension.
Old 05-22-2019, 11:25 PM #6
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Some great info there; love that Radflo 2.5IFP, was close to going that route...maybe one day...not ready yet.
Anyway, on topic,
I have a 1.2/1.0 lift and will not go higher. What bump stops can I benefit from? When I install the new setup I will have the same lift with 6112 in the front and Icon 2.0 IFP with 1" Eibach springs in the back.
I don't want to pay more than 200-250 between front and rears unless I can be convinced that air bumps in the rear can make things seriously more comfy for the kids and dog. The Icon ones that mount inside the rear spring seem like a great idea but 650 is out of the question.
I guess Wheelers is great for the front (but will it help with 1" lift?) but what about the rear?
Thanks for any suggestions!
Old 05-22-2019, 11:40 PM #7
mrblah's Avatar
mrblah's Avatar
Anyway, on topic,
energy suspension for the fronts are dirt cheap. I got the idea from a member: akkording on this forum. I think it was like 30 bucks on amazon.
Timbrens are not cheap. There are no affordable rears. Even, the durobumps aren't cheap so thats why I got timbrens. Since there are no value oriented options for the rears. Hydraulic bumps is overkill, and I also run airbags so hydro bumps are a no go for me. FYI, airbags also act as bumps also....so I won't give up my airbags lol.
I would have gone with wheelers in the front, but i'm a cheap skate bastard if i can get away with something more value oriented.
IMHO, anything is better than stock. If you take a flashlight, and look at your front lower A-arm, you will see a impact mark at STOCK height...that was enough for me to upgrade. Basically, you will be happy with anything squishier and taller than stock, since they are designed to compress. The OEM front and rear's don't compress at all, thats why the toytec extensions w/ oem bumps suck so bad. It made the rear feel even worse. Only difference between all these aftermarket choices comes down to is price.
Old 05-22-2019, 11:54 PM #8
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
Yep I got the same energy suspension ones. Forgot to put then on when I did the lift. So I still need to install them.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 11:56 PM #9
mrblah's Avatar
mrblah's Avatar
lol, they aren't hard to install. You need big giant channel locks, and you will have to jack the car up, but you don't have to remove the wheel.
I installed my neighbors and mine in a hour or two.
Old 05-23-2019, 12:30 AM #10
Bayou_Pro's Avatar
Bayou_Pro's Avatar
Yeah I didn't know if there was a nut I had to get to in there or if they just threaded in. Got lazy and didn't go back and do it. Might throw then on tomorrow if I have time. Thanks.
Paul
Old 05-23-2019, 02:19 AM #11
mrblah's Avatar
mrblah's Avatar
Hmm...Wheelers' set of front and rears is under 200. Now, I am as cheap as the next guy as well, so I would rather wait for some % off
For Energy Suspension front is this what we are talking about?
Energy Suspension Bump Stop 8.9104G
Thanks.
yes, i got the red ones so mine are 8.9104R. I think R means red lol.
Old 05-23-2019, 03:13 AM #12
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
Wheeler's SuperBumps up front and ICON hydraulic bump stops in the rear (in coil setup).
Pros:
Superbumps: decent price, works great at softening harsh impacts
ICON: works great at softening harsh impacts or when carrying heavy loads over bumps, adjustable height
Cons:
Superbumps: large enough to almost always be on contact at stock or mild lift. I'd prefer something shorter to allow the suspension to do it's job
ICON: $$$, location in the rear coil is not ideal.
pics 1&2 are front superbumps. Pic 3 is ICON hydro bump vs stock bump stop. Pic 4 is ICON hydro bump installed
What bump stops are you running?-1-jpg  What bump stops are you running?-2-jpg  What bump stops are you running?-3-jpg  What bump stops are you running?-4-jpg
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 05-23-2019, 07:14 AM #13
Awesome guys! Thank you. Was thinking of getting the wheelers but wasnt sure. I'll definitely look into energy suspension. Running 3inches of lift with stock bumps stops and well...they need to go. My rear is especially stiff when going over speed bumps etc
Old 05-23-2019, 08:34 AM #14
SnowYeti's Avatar
SnowYeti SnowYeti is offline
SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough
SnowYeti's Avatar
I contacted DuroBumps and they have tooled a shorter version for the rear, for those of us doing 0”-2” lifts. Not up on their sight yet, I am going to email him back today to find out the status. I will post the reply. I am dong a 1” lift in back with Eibach springs, so these would be perfect
Email sent.
Reading through his original reply he does say this new version will be perfect for a 1” lift.
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
SnowYeti is offline   Reply With QuoteReply With Quote
Old 05-23-2019, 09:57 AM #15
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
Email sent.
what do you think would be ideal for a 2" lift?
tm965 is offline   Reply With QuoteReply With Quote
air , bump , purchasing , running , stops
Energy Suspension 8.9104R rear bump stops in place of front bump stops Akkording 5th gen T4Rs 66 01-16-2024 12:10 AM
Bump stops crashman 4th Gen T4Rs 24 05-16-2018 09:55 AM
Bump stops lhsoulrebel 3rd gen T4Rs 9 08-14-2013 11:36 PM
Bump Stops for 94 4x4 rrands1 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-15-2011 11:09 PM
Do I need new bump stops or UCA's masson74 3rd gen T4Rs 11 09-22-2011 11:26 PM
