Old 06-26-2019, 09:56 AM #1
gte610v gte610v is offline
gte610v is on a distinguished road
DIY Camp Solar Shower
I don’t post much, but wanted to share my take on the pvc solar shower. The ones I’ve seen were just ~10’ of pipe slapped on top of the roof. Good idea, just looks bad to me. I wanted the same thing, but more integrated. Since I almost always leave my Yakima Megawarrior on top, I figured I could nest it into the basket. Here it is
gte610v is offline   Reply With QuoteReply With Quote
Old 06-26-2019, 10:14 AM #2
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
Is that black hose pushing pressure into your pipes?
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 06-26-2019, 10:31 AM #3
Ah yes, shrader valve to run compressed air to pressurize the tank.
Old 06-26-2019, 11:13 AM #4
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
keep the pressure low, DWV isn't really made to be pressurized
jhguth is offline   Reply With QuoteReply With Quote
Old 06-26-2019, 11:17 AM #5
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
good advice here. If your design works good, maybe copper or aluminum would be better to handle the pressure??
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 06-26-2019, 11:31 AM #6
Akkording's Avatar
Akkording's Avatar
and you get +1000 man points for having a lift in the garage! That's also a lovely front yard and picket fence.
Old 06-26-2019, 11:59 AM #7
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
Yeah, but he doesn't need much pressure. It would work for the kids just on gravity.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
Old 06-26-2019, 12:49 PM #8
hahaha...thanks! worked hard to get all of that!
also, only running 20psi. I have a pop valve to regulate it for extra safety.
Old 06-26-2019, 01:53 PM #9
-E5J-'s Avatar
-E5J- -E5J- is offline
Real Name: J
-E5J- has a spectacular aura about -E5J- has a spectacular aura about
-E5J-'s Avatar
Real Name: J
I've always wanted a lift in my garage... VERY impressive.
2019 4Runner TRD Pro, Midnight Black Metallic - RCI Sliders & Aluminum skids, WeatherTech Floor mats all around, Toyota wind/bug deflector on hood
2016 4Runner XP, Magnetic Grey Metallic - Sold
2015 4Runner Limited, Classic Silver - Sold
2002 4Runner SR5 Sport Edition, Thunder Cloud Metallic Grey - Sold
-E5J- is offline   Reply With QuoteReply With Quote
Old 06-26-2019, 03:47 PM #10
Daohaus's Avatar
Daohaus Daohaus is offline
Real Name: Duan
Daohaus is on a distinguished road
Daohaus's Avatar
Real Name: Duan
i built something similar but a 4' long 4" section of piping. Thinking about modifying it so that I can attach a quick connect instead of the traditional screw on hose fitting.
Also, I have a bunch of CO2 that I use to carry whilst cycling, might be interesting to attach the CO2 bottle to the valve to run pressure to it while using the water.
2018 TRD Off Road Premium
Rotiform SIX-OR | Toyo Open Country RT 285/70/17 | Bilstein 6612/5160 OME 2895 | Rhino Rack | Valentine One | Rexing Dashcam
IG: @daohaus
Daohaus is offline   Reply With QuoteReply With Quote
nest , shower , solar , top , wanted
Solar surf Shower and surfboard racks done. Rogue_Runner77 5th gen T4Rs 22 05-21-2019 10:49 PM
Homemade Solar Shower SirWilliamGoes General Discussions 15 11-05-2017 02:28 PM
Road Shower 2 Five-Gallon Pressurized Solar Shower Review Ohio_Steve General Discussions 7 06-24-2017 11:57 PM
Solar roof top pipe shower Duke562 General Discussions 23 03-04-2016 12:12 PM
Going To Big Bear This Weekend to Camp & Play in the Dirt, Need good Camp Sites 5SPD_MAN_RUNNIN So Cal 6 07-09-2014 12:55 AM
