Remote Start
davem
Just finished up my install of the 12Voltsolutions remote start. Quick shipping, Easy to install and NO wires to cut. Keeps factory fob and doesnt shut off when you open the door. Have one ordered for the wifes new Tundra as well. 15% off for holiday.
I have the factory remote start on my ‘15. I would love for it to -not- shut off when I open the door...
How does this work? If the remote start runs for 15 minutes and you get in the car while it is running, how do you get the key into the "run" position?
How does it bypass the immobilizer?
You get in, put key in and turn it on. Not to the starter position just on. Put foot on brake and put in gear.
Makes sense. Not sure what I was thinking.
How long did the install take? No cutting into wiring?
How do they disable the immobilizer?
I just finished installing the accesorides remote start in my 19 TRD ORP. It was simple. Not a one spliced wire. Came with detailed instructions. Very happy and highly recommended.
It probably takes as long undoing trim and reading directions as it does to route wires plug in connectors. Super simple and my one for our new Tundra is enroute as I type this.As far as the immobilizer I cant answer that, give them a call.
This wires right in side by side with your factory alarm if that’s what you’re asking. As a matter of fact mine came with a blue led that I mounted and when the truck is armed it lights up. Keep in mind this is off of the remote start. So they took into effect the factory system.
