Old 08-29-2019, 01:33 PM #31
MTN4RNR's Avatar
MTN4RNR MTN4RNR is offline
Real Name: Max
MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough
MTN4RNR's Avatar
Real Name: Max
Originally Posted by borfoo3 View Post
I do keep track of my trans temps. On a modded T4R, it is not really difficult to push trans temps up once you push the truck harder while loaded. Thankfully, haven't seen any warning lights, but planning to do a trans fluid swap with the Toyota stuff.
Back to OP's scenario, and assuming the purpose here is to solve this and not start another fluid X vs stupid OEM stuff debate, let's start by summarizing some facts:
1. truck is fully loaded for a trip + steep incline = high load on the transmission
2. Upsized tires/ stock gearing = effectively increases torque demand on transmission
3. supercharged setup = added demand on transmission by means of higher engine torque output
4. Slow drive/ airflow blockage impedes transmission cooling.
Our transmission cooling is mainly based on 2 parts:
a. The in-radiator heat exchanger passing heat to/from trans and engine coolant fluids. Coolant is usually ~190f to 194f, and
b. Good airflow around the transmission body.
5. Warm days/ hot surfaces under the sun worsen #4 above
Basically, I believe OP scenario above is pushing the stock transmission cooling loop beyond its capability. OP using a non OEM ATF, for better or worse, is at least a variable at question here
Potential solutions:
1. Swap back OEM ATF fluid, flush lines and inspect for any blockage
2. Add trans temp monitor and keep track of temps. Higher than average temps for extended periods can degrade the ATF life
3. Consider added cooling for trans by adding an in-line cooler.
I concur with this assessment. Mods can come with consequences and sometimes require additional mods to remedy them. I would definitely flush what you have because it's likely compromised in some way at this point. Then fill with whatever ATF you feel meets your specifications.
2016 MGM Trail Premium - KDSS
Explore4R.com
Building the MTN4RNR
Instagram --- life.to.the.max
Writer/Editor at Trail4Runner.com
MTN4RNR is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 01:41 PM #32
XswampX XswampX is offline
XswampX is on a distinguished road
Thanks everyone.
I changed the fluid as I believe Maxlife ATF is an absolutely top notch fluid.
I agree on stopping the bickering about factory recommended vs. not ATF. We have all said our peace.
Originally Posted by MTN4RNR View Post
Being in 4lo in these situations where you're slow going for a long period uphill will help moderate transmission temperatures as there is less slipping higher in the power band than when you're grunting along at low rpm. It will also allow the fan to kick in at a higher RPM and move more air through the engine/transmission radiator.
This was all in 2Hi and 4Hi. I will try 4L. Great points ^ thanks.
I have no additional skid plates above stock.
No tranny hunting going on.
Solid post @borfoo3 , thanks!
I'm going to monitor temps in the future. Check and swap fluid level then consider an auxiliary trans fluid cooler.
XswampX is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 01:57 PM #33
MTN4RNR's Avatar
Real Name: Max
MTN4RNR's Avatar
Real Name: Max
Originally Posted by XswampX View Post
Thanks everyone.
I'm going to monitor temps in the future. Check and swamp fluid level then consider inline cooler.
Thanks for following up! Sounds like you are on the right path. Please do update with anything you find out through the fluid exchange process and if any changes help with your problem!
Explore4R.com
Old 08-29-2019, 02:41 PM #34
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Thanks everyone.
On some trails where I left it in 4hi, the pan fluid was reading over 240F. NOT good!
Re did the trail in 4Lo and it stayed near 190-210F
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 02:51 PM #35
Big_Cuss Big_Cuss is offline
Big_Cuss will become famous soon enough
Originally Posted by Jetboy View Post
You caused this by putting the wrong transmission fluid in it. Sorry to be the bearer of bad news. Next time use the real stuff. Toyota fluid is more expensive, but it's the only ATF that is appropriate for this transmission. And you should never change it. Maybe you can flush it and put Toyota fluid back in and it'll work better. Hopefully you didn't damage the clutches.
This video will help explain why you should use the correct ATF.
Wow, just wow. Can't believe there's such a fundamentally STUPID video as that one, at 40+ freaking minutes, with such weak logic.
Let me get this straight. Some old, anal, ocd retired engineer presumes he can "out" two very big automotive chemical companies for making products with nearly completely fabricated credentials/specs, just because they don't list the LICENSES on the actual bottles, and instead do some in paperwork else where most likely?
I freaking guarantee you Valvoline has all the licenses necessary to make the claims on their bottle, as evidenced not being sued by everyone who ever put that stuff in their car.
What a blowhard.
Listen to the myriad of other folks who said it ain't the fluid. It's the blocking of radiation and possibly extra load. Fix that and you'll be good.
Big_Cuss is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 02:56 PM #36
MTN4RNR's Avatar
Real Name: Max
MTN4RNR's Avatar
Real Name: Max
What a blowhard.
We have all moved on...
Explore4R.com
Old 08-29-2019, 02:58 PM #37
Not from the youtube views/comments, it seems. A good historical first part of that vid, but the contentions at the end (which is most of what people are taking away from the vid) are likely inaccurate.
Old 08-29-2019, 03:01 PM #38
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
Thanks everyone.
Solid post @borfoo3, thanks!
it doesn't have to be hunting for the converter to be making a ton more heat. the entire rig would work better with gearing appropriate to the larger tires, that includes the transmission...
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 03:57 PM #39
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Thanks everyone.
Keep us up to date, i would like to see the remedy and the actual cause. Would also like to see if any other forced air rigs have the same issue. Was it common for the FJ's or taco's?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 08-31-2019, 01:28 PM #40
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
it comes down to this
use which fluid ? a or b
a--[what aisin and toyota engineers and materials scientists formulate as the fluid to use]
vs
b--[what some team of unknown and unaccountable random ****wits trying to reverse engineer what toyota paid millions for recommend, because it's a conspiracy]
Do what you wish. My transmission doesn't overheat....
c -- same petroleum engineers filling orders for Toyota engineers.
Do what you wish. My transmission doesn't overheat and I understand mechanics a hell of a lot more than you.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 08-31-2019, 01:31 PM #41
What a blowhard.
I made it less than a minute in and shut off. Guy is from Weber St. LOL. Might as well be from Boise St school of trucking.
Old 08-31-2019, 04:32 PM #42
yardsale's Avatar
yardsale yardsale is offline
yardsale will become famous soon enough
yardsale's Avatar
@Jetboy : While I am not sure about the tranny fluid, I strongly disagree with your assessment that Rotella is bad for a gas engine. Yes, you might ruin your cat over time, but the engine itself will be very happy with the Rotella. Especially with the 5w-40 synthetic.
yardsale is offline   Reply With QuoteReply With Quote
Old 08-31-2019, 06:25 PM #43
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
yea its just simply an opinion from an expert.. nothing scientific.. no analysis.. just a guy rehashing the same crap that's already been all over the internet..
now if we can get Project Farm from youtube to run analysis of Toyota WS then that would convince me
1jzgte is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 01:02 AM #44
With outdoor temps in the 80s and light city driving (via Torque) my tranny temps are running 160-190. I decided to buy the Hayden 697 cooler and was able to mount it well spaced off of the SC LTR with some coupling nuts used as spacers. I also found an off the shelf 90 deg metal bracket at the hardware store that secured the bottom of the cooler to the 90 deg tab off the inside of the front bumper structural cross beam. Pretty clean mounting. Curious to see the drops, expecting at least 20 degrees. Out of an abundance of caution I am also going to fully flush the fluid and get fresh Valvoline MaxLife ATF back in. Not to rehash but from the Valvoline website,
"Suitable for use in ... Toyota WS"
Old 09-10-2019, 10:21 AM #45
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
I'm a physicist. I sort of doubt that you do. But if you'd like to tell me the stokes number ideal for the clutch packs in the A750F - please educate us all! I'd love to learn about the particulate suspension differences between Type 4 and WS. Obviously we already know that WS is very different from Type 4 in both viscosity and additives based on lab tests. There's still a lot we don't know. Maybe you could help out?
It's not Toyota's engineers. It's the engineers from Aisin - who specifically state in the manual for the A750F not to use type 4. The viscosity is too high.
cooler , fluid , trans , transmission , vehicle
Why is my transmission overheating?? 96TrailSurfer 3rd gen T4Rs 12 01-26-2021 04:11 PM
Transmission Overheating - Torque Converter Issue? 96TrailSurfer 3rd gen T4Rs 15 08-03-2018 11:52 AM
Transmission Overheating BE4Runner 3rd gen T4Rs 12 04-27-2017 03:43 PM
1990 4runner auto transmission overheating mexico General Discussions 3 09-02-2012 10:25 PM
1990 5 Speed Manual Transmission Overheating Tucson T4R Classic T4Rs 1 08-29-2005 01:32 PM
