07-29-2020, 10:40 PM
#31
Banned
Real Name: Tobias Fünke
Banned
Originally Posted by Steve Theodore
With my 4Runner I'm more concerned with keeping up with more modern SUVs and reducing it's overall burden as it gets older, but I recognize that there isn't too much to do.
I just get tired of seeing legit weight reduction threads and people answer "join a gym" as that isn't how real weight weenies operate. I dream of stripping 400 pounds off my 4Runner.
"Modern" suv's are unibodies without live axles. You are never going to keep up unless you force induction. Instead of worrying about reducing burden just perform preventative maintenance. 4runners go high mileage with little failures i wouldn't worry too much at 170k.
You get tired of not reading the answers that fit your narrative. People make jokes because it's an absurd endeavor for a vehicle you plan on using practically. You want to remove 400lbs from the truck say goodbye to your entire interior, hood, roof rack, running boards, skid plates, tow hitch, and possibly your rear hatch. Even then I doubt it will weigh 400lbs. Just sell your truck and get something that's more too your liking. This is silly.
07-29-2020, 10:58 PM
#32
Banned
Banned
@ Steve Theodore
Just to further clarify the point.
Your 4th gen weighs 4280lbs aprox. You are asking to remove 10% of the vehicles overall weight and still have something that can be used as an suv.
07-30-2020, 08:41 PM
#33
For anyone curious, the crossbars from the OEM rack weigh 5.5 pounds when removed. This is for a 4th generation 2008 model, so your mileage may vary on a 5th generation model.
Steve Theodore
2008 Toyota 4Runner Sport Edition V6 4x4
ex-2000 Toyota 4Runner SR-5 V6 4x4 5 speed (R.I.P. old girl)
2012 Lexus IS-F
2001 Lexus IS300 slicktop
07-30-2020, 09:17 PM
#34
remove all the JBL speakers and run a cup holder Bluetooth boombox
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
07-31-2020, 01:16 AM
#35
Real Name: MURDERED TRD
Learn how to Hypermile. Probably the best chance you got.
07-31-2020, 02:05 AM
#36
I'm not the one trying to get better fuel economy, I'm the one who always wants to increase performance by improving the power to weight ratio.
Trust me when I say I know none of the things I mentioned will add up to a significant result, but it's the way my works from being into high performance cars and bicycles. I'm hardwired to think about weight reduction.
If it helps to illustrate my point, while tracking performance metrics over the past few months I've personally lost 15 pounds (my Covid-15 as I call it), and it makes a slight improvement on my acceleration times in other cars I own that I track with an app called Dragy.
I know this isn't normal in the 4Runner world!
You bought the wrong vehicle. The 5th gen 4runner is an absolute pig, riding on an ancient chassis, archaic drivetrain and rudimentary suspension setup. It will always handle poorly on pavement no matter how much weight you are able to pull off it. Simple fact, the concept of a performance 4WD body on frame truck is just silly and useless.
Having said that I do own a "car based performance suv" but it at least gets decent gas mileage (28mpg) and handles like a sports sedan. I would even be comfortable taking it on a racetrack. A 4runner will never get remotely close to that no matter how hard you try.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
07-31-2020, 03:17 AM
#37
Reducing a vehicle's weight by 100 pounds typically yields a 1-2% gain in fuel economy. So you'd be hard-pressed to achieve any meaningful savings going this route on a family road trip.
As others have pointed out, correct tire inflation and moderation in speed and acceleration will have much more significant effects. Proper maintenance can also yield good gains: - Replace a dirty air filter and clean your mass airflow sensor.
- Clean or replace corroded battery cables so the alternator doesn't have to work as hard.
- Make sure your wheels are aligned and the tires are balanced.
- Make sure your brakes are properly adjusted and your calipers aren't sticking to avoid drag.
If you've done all this and still need to save more fuel, start drafting everyone in front of you!
No matter where you go, there you are.
2007 4Runner SR5 4WD | 4.0L V6 1GR-FE VVT-i
Philips Ultinon LED Interior Lighting, Weathertech FloorLiners, Toyo Open Country AT3 265/75/R16, Victory 4x4 Roof Rack, RacksBrax Brackets, ARB 2500 Awning & Awning Room, IceCo JP42 Refrigerator, Anker 757 LifePO4 Generator, Renogy 100w Monocrystalline Solar Panel, JVC KW-V660BT Head Unit
08-10-2020, 02:09 PM
#38
08-10-2020, 02:40 PM
#39
Originally Posted by caeavesrsx-s
That dude is HARDCORE!
Steve Theodore
2012 Lexus IS-F
08-11-2020, 05:41 AM
#40
I dream of stripping 400 pounds off my 4Runner...but it's a nearly impossible and definitely an impractical dream.
even at 400 pounds lighter a 4runner probably still wouldn't be competitive in efficiency and performance to a comparable unibody SUV. weight reduction seems like chasing ghosts for this platform. the more realistic approach would be to minimize weight gain wherever you can when modding (lightweight wheels, aluminum armor/bumpers, winches with synthetic rope etc)
08-11-2020, 10:30 AM
#41
Hoping that everyone reading this thread realizes it's only a day dream. I can recognize the folly in the amount of work it would take to achieve that dream in practice. That being said, it's just the way I operate and I'm hard wired to consider weight reduction and performance in any vehicle that I own.
Steve Theodore
2012 Lexus IS-F
08-11-2020, 09:46 PM
#42
Real Name: Ron
Real Name: Ron
Took some more weight off my '03 today, scraped the frame (again) and got another 1/4 lb of rust off it.
08-11-2020, 10:52 PM
#43
That's what we refer to as asymmetrical weight reduction!
Steve Theodore
2012 Lexus IS-F
06-01-2021, 07:11 PM
#44
Originally Posted by JLTD
Probably keeping your speed down will do the most for better mpg. That, plus tire inflation.
This, too. The 4.0 is notorious for fuel mileage dropping like a rock the higher over 60 mph
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
06-01-2021, 07:34 PM
#45
Originally Posted by mrblah
ditch the wife and the kids.
And the school bus seats.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
