Old 09-07-2019, 04:23 PM #1
ae82gtm ae82gtm is offline
ae82gtm is on a distinguished road
JL Audio Speaker Upgrade Thread
Hi Everyone,
I've been doing research for several weeks now, and it seems like there is scattered information and no concise instruction about a full JL Audio C2 setup.
@Mikey_Cheng , @Helix26404, @mallory25 has the best info on here, but still incomplete. Also, all three of these guys are inactive for over a year.
My OE setup is JBL equipped, but fitment is identical from base audio to JBL.
The setup would be:
-Dash
3.5" JL Audio C2-350x
Requires customizing the OE bracket, may need some material removed from plastic grille. This one is well documented here and here.
-Front Door
6x9" JL Audio C2-690TX
According to this it only requires Metra 82-8146 adaptor.
I'm a little surprised as Crutchfield lists top mount depth as 3.25" and "does not fit your vehicle".
Can anyone confirm regarding fitment? Windows roll up and down fine? Grille needs modification?
-Rear Door + Liftgate
6.5" JL Audio C2-650x
Virtually no information on here, other than this. Also listed as "does not fit your vehicle" by Crutchfield.
Use Scosche SAT6 adaptor? My biggest concern is depth. Crutchfield lists the top mount depth as 2.56"
Can anyone comment about fitment in rear door and/or hatch? I suspect hatch is the toughest fitment. Any kind of modification required? Any difference with using a TacoTunes adaptor vs. Metra/Scosche?
Add to this post if you can, it would be helpful to have a thread containing install of JL Audio C2 speakers!
Thanks!
ae82gtm is offline   Reply With QuoteReply With Quote
Old 09-08-2019, 12:06 PM #2
Ripper238's Avatar
Ripper238's Avatar
Im thinking of upgrading my 4R speakers to JL's, but i am not sure if they would be an improvement. Especially since i would rather not have to add an amp.
I generally use a local car audio place for my installs because they don't charge much and they have all the right parts and brackets to make it work. I may visit them and see what info i can gather then post back, they said last time there are brackets available.
Old 09-08-2019, 07:09 PM #3
I'm almost 100% confident speakers alone will make a tremendous difference. I had a non-JBL 4Runner and replaced all speakers. It's quite possibly better than the JBL version (which I have now). The JBL system is "fuller" thanks to the sub, but my non-JBL with aftermarket speakers had way cleaner (and clear) mids and highs.
The JBL system is much, much better than the base audio... but still can use some improvements.
If you do go the JL C2 route, post back and let us all know how install went!
Old 09-09-2019, 12:28 AM #4
4Rums 4Rums is offline
4Rums will become famous soon enough
The OEM JBL system in the 4runner is crossed over on the amplifier and cannot be modified (crossover points nor gains). Not sure of the exact crossover point, but somewhere around 300 (+-100) Hz for the front speakers. The front doors play the lower frequencies and the dash the highs. The speakers that you listed have very different sensitivity values with the 3.5" at 83db 1w/1m and the 6x9 at 93db 1w/1m. So the doors will sound quite a bit louder relative to the dash and the fader will not do much as they share the front channel. I would look for speakers that have similar sensitivity for the front doors and dash so that they are level matched and sound at the same relative volume.
4Rums is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 01:19 AM #5
Pandax Pandax is offline
Pandax is on a distinguished road
Need!!
Pandax is offline   Reply With QuoteReply With Quote
Old 09-09-2019, 04:31 PM #6
Anyone who has actually installed these JL Audio speakers and can comment (especially on the doors and hatch) about the install?
Front door: 6x9" C2-690TX
Rear door + hatch: 6.5" C2-650x
Old 04-22-2021, 11:39 PM #7
fx3s fx3s is offline
fx3s is on a distinguished road
Did they end up fitting in the hatch and rear?
fx3s is offline   Reply With QuoteReply With Quote
Old 07-10-2022, 10:21 PM #8
osugsxr osugsxr is offline
did the JL fit in the rear and hatch?
Old 12-21-2022, 10:01 AM #9
seems like they will fit
Premium Stereo Upgrade for Albany Toyota 4Runner
Old 05-06-2024, 09:47 PM #10
damon323 damon323 is offline
damon323 is on a distinguished road
Hi Everyone,
The setup would be:
-Dash
-Front Door
Thanks!
Just installed the C2 6x9’s! They easily fit with the Metra adapter! They show that they don’t fit on Crutchfield only because of that stupid thin outer ring on the door panel itself. Plenty of clearance for the magnet. I have a set of Pioneer 2-3/4 speakers in my dash. I got them prior because the non JBL system is terrible. Anyway, it’s not a proper “component” system but I don’t care, sounds amazing. The C2 6x9’s hit hard. I’m running them off my RD900/5 channel amp at 60 hz and they have zero problems doing so.
Hope this helps. I was curious about fitment and saw this forum. I pulled the trigger and wanted to post.
damon323 is offline   Reply With QuoteReply With Quote
adaptor , audio , depth , door , fitment
DIY 3.5" JL Audio dash speaker upgrade - Wow!! (detailed how-to) 57HotrodVW 5th gen T4Rs 71 05-07-2023 01:40 AM
4RunnerStunner's 2011 5th Gen JBL w/Navigation Speaker Upgrade Build Thread 4RunnerStunner 5th gen T4Rs 15 03-24-2019 06:21 PM
Zmilins Limited audio upgrade thread zmilin Engines / Suspension / Wheels / Tires / Audio / Accessories 16 06-16-2018 05:35 AM
Audio Upgrade - Audio guys come in and help wfo9 5th gen T4Rs 18 03-21-2015 07:24 PM
