Old 09-26-2019, 10:53 PM #1
Shabang's Avatar
Shabang Shabang is offline
Shabang is on a distinguished road
Shabang's Avatar
Help with camping power setup
Sorry for the broad question, but I'm new to the electrical side of the 4Runner. I'm going camping this thanksgiving, RTT and all that jazz. But I need a simple way to just charge phones and maybe a little LED strip in the tent.
What would you guys recommend doing to deal with this power need, dual battery setup while I'm at it? I am really a noobie as far as power goes in the 4Runner so any help is greatly helpful.
Thank you!
Shabang is offline   Reply With QuoteReply With Quote
Old 09-26-2019, 11:03 PM #2
mrblah mrblah is offline
mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of
You can also run a battery box like goal zero or arkpak
2016 sr5 2x4 Mall rated edition:
Current peasant build: spacer lift 3 inches, lots of plastidip, sr5 wheels w/ 265s, lots of LED lights, and lots of overlanding stickers and sponsored stickers. faking it with the IG crowd since 2016.
Old 09-26-2019, 11:14 PM #3
thinkviv's Avatar
thinkviv thinkviv is offline
thinkviv is on a distinguished road
thinkviv's Avatar
For such simple needs I would consider a lithium power bank, you could charge it through the existing power ports and something like the goal zero yeti 400 would have enough power for your needs and more.
IMO a dual battery setup would be going overboard for charging cell phones and a running a small led light in a RTT. In fact, you could probably get away with those a small handheld powerpack like a 20,000mAh and an led light that you can recharge with USB.
2015 TEP - Magnetic Grey w/ KDSS
thinkviv is offline   Reply With QuoteReply With Quote
Old 09-26-2019, 11:48 PM #4
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner will become famous soon enough RAD4Runner will become famous soon enough
RAD4Runner's Avatar
Start with this^^^
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 12:38 AM #5
zmannerz zmannerz is offline
zmannerz is on a distinguished road
Thank you!
I just got back from camping. I used a power bank for my phone. For about $30 you can get one that will charge your phone several times. These batteries are useful anytime you are traveling. When camping I try not to use my phone much, but I do use it for music. This was the first time I brought a power bank camping, and it was very handy.
For a tent light I used a cheap led light that takes a single aaa battery.
zmannerz is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 01:25 AM #6
ChrisJHarney's Avatar
ChrisJHarney ChrisJHarney is offline
ChrisJHarney will become famous soon enough
If you have more money than time, major brands like Goal Zero and the like are sold everywhere with every available attachment and gizmo you can think of, and you can buy the solar panel(s) that those brands make as well and be totally off the grid and not have to worry about your truck needing to charge up the battery banks. It can get a little pricey, but you're good to go out of the box.
If you want to get a little creative and do some research, you can build a small box of your own, buy a couple 6V deep cycle golf cart batteries (true deep cycle batteries, not the ones that are commonly used for dual battery setups), wire them safely in series, add a high quality solar panel with charge regulator, and basically be good for weeks on end out in the bush. Depending on your storage needs, the battery box can be tucked away in the cargo area and you can run lights, charge phones, tablets, computers, etc....
If you aren't tapping into the vehicle's charging system, a stand alone home made unit isn't really that difficult to build, and as long as you use quality components, will out perform any all-in-one system you can buy. But it will take some time, tools, and research. But isn't that what modding our trucks is for?
ChrisJHarney is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 08:52 AM #7
jhguth jhguth is offline
jhguth is a name known to all jhguth is a name known to all jhguth is a name known to all jhguth is a name known to all jhguth is a name known to all jhguth is a name known to all
If you want a battery pack don't get a goalzero, get a smaller brand off amazon, they cost a lot less
(jackery, rockpals, etc...)
Here is a pretty good comparison video:
YouTube
I have a 31m battery with plenty of power for camping stuff but still carry this 300Wh Rockpals so I can power stuff away from the vehicle (also comes in handy around the house when there is a power outage or something): https://www.amazon.com/dp/B07FFNTGZ6..._noGJDb39VC72N
I have to power an apap so ended up with the rockpals because a lot of the other batteries will shutoff after so many hours if you're not pulling a certain wattage (jackery is I think 6 hours if less than 10W) and my apap often only watts.
if you have no need for 120V and just need to power USB devices, then those are really cheap
jhguth is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 09:03 AM #8
honda250xtitan is a glorious beacon of light honda250xtitan is a glorious beacon of light honda250xtitan is a glorious beacon of light honda250xtitan is a glorious beacon of light honda250xtitan is a glorious beacon of light
you don't need anything for that. the light strip will last the trip. your phones will be fine till you get back in service so they'll be in airplane mode anyways. charge them in the car on the way there and back. 4runner has a 110 plug in the back anyways. run the car a bit to charge whatever you need.
2016 TE : Grocery Getter, 285/70R17 Cooper at3 XLT, Prinsu Rack, King Coilovers, DuroBumps, Wheelers T13 coils, King shocks, King hydro bumps, Total Chaos mounts, DirtKing Fabrication UCA
2017 F250 6.7: Carli, Fox, Raceline, BajaDesigns, DIY Retrofit headlights
Old 09-27-2019, 09:44 AM #9
Bootleg's Avatar
Bootleg Bootleg is offline
Real Name: Brandon
Bootleg is on a distinguished road
Bootleg's Avatar
Real Name: Brandon
I have a Goal Zero Yeti 100 that has plenty of juice to keep my phone, wife's phone, my watch, wife's watch, lanterns, flashlights, speakers, etc. charged for 3-4 days, easy. You can find them under $200. I plug a power strip into mine and keep stuff on it pretty much the whole time we're camping.
2013 SR5 4wd Bike Hauler
275/70/17 BFG KO2 on 17x9 Level 8 MK6 <> Bilstein 6112 (@ 2.5") /5160 w/ Icon 2" springs <> JBA Offroad UCAs <> ShrockWorks step sliders <> Front Runner Full Length Rack <> Baja Ladder <> Canvasback cargo liner
Bootleg is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 10:26 AM #10
Heavy_GD's Avatar
Heavy_GD Heavy_GD is offline
Real Name: GD
Heavy_GD has a spectacular aura about Heavy_GD has a spectacular aura about
Heavy_GD's Avatar
Real Name: GD
For something this simple, I use a battery jump box deal and I have solar charging camp lights.
As a back up plan I have 12v rechargeable flashlights but I try not to use much light as it attracts insects.
'16 SR5 Premium
Heavy_GD is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 10:27 AM #11
Shabang's Avatar
Shabang's Avatar
I like this idea a lot actually, we're camping for about 5 days so really the more power the better. I'd be interested in doing some more research to build this.
Old 09-27-2019, 11:02 AM #12
CavPro's Avatar
CavPro CavPro is offline
CavPro has a spectacular aura about CavPro has a spectacular aura about
CavPro's Avatar
That rockpal is awesome, I've had mine for over a year and it is great. It's also gone down in price, like they always do. Except for anything with goalzero on it.
No matter what you get, you have to have realistic expectations about capacity and use.
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
CavPro is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 11:25 AM #13
Terrapod's Avatar
Terrapod Terrapod is offline
Real Name: Chad
Terrapod is just really nice Terrapod is just really nice Terrapod is just really nice Terrapod is just really nice Terrapod is just really nice
Terrapod's Avatar
Real Name: Chad
Highly recommend an external battery system. It separates the power usage from the vehicle and can be portable.
In my case, I have a custom built, LiFePO4 50Ah battery system that is charged via a 100W solar panel on my RTT. Works fantastic and does a great job running my fridge, charging devices, more.
And...FWIW - my total spend on this DIY system was right around $750.
2016 TE - 2.5 Icon Stage 2 Ext Coilovers, Icon 2.0 Remote Res rear shocks - RCI sliders & skids - Custom front LED in-grill mount - Rigid - General ATX 275/70 - SCS Wheels, Terrapod RTTx, Raingler, Baja Designs, Rhino Rack.
Terrapod is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 11:36 AM #14
Agent_Outside Agent_Outside is offline
Agent_Outside is a jewel in the rough Agent_Outside is a jewel in the rough Agent_Outside is a jewel in the rough Agent_Outside is a jewel in the rough
You can ignore the dual part if you’re not looking to go that route but this video also includes how I set my roof top tent up with power.
YouTube
Agent_Outside is offline   Reply With QuoteReply With Quote
Old 09-27-2019, 11:44 AM #15
socalkid's Avatar
socalkid socalkid is offline
socalkid is on a distinguished road
socalkid's Avatar
we have a Jackery 240 and it's more than enough for our needs (phones, iPad, Garmin inReach, head lamps, LED lanterns, etc) though we aren't running a fridge or any other equipment that would be a huge draw. longest we've been off grid is 3-4 days and using the car to charge stuff when driving and the Jackery for when camped i think we only used 25-30%, and that was without recharging the Jackery when driving on purpose to see how much we'd draw it down. honestly, its probably a little overkill for us at the moment but for $250 and the option to potentially power a small fridge in the near term were why we sprung for it.
1998 3RZ 5-spd Base 2wd - His
2019 TRD OR w/KDSS - Hers
socalkid is offline   Reply With QuoteReply With Quote
4runner , camping , helpful , power , setup
Anyone have a camping/sleeping setup inside of the 4Runner? cooler2442 5th gen T4Rs 114 01-31-2021 12:47 AM
4Runner - Camping Setup Sphonaut General Discussions 40 04-14-2019 02:07 PM
Questions: Dual Bat setup and Power Distribution block from Shrock rcebowl 4th Gen T4Rs 7 12-14-2016 12:17 AM
4Runner Car Camping Low Profile Setup (Cooling Fan, Bugs Screen, Exterior 360 degree johnnywofee 5th gen T4Rs 50 07-20-2015 06:20 PM
Creating a camping setup 3rawfedweims 4th Gen T4Rs 18 02-07-2011 12:25 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
