Old 10-28-2019, 01:59 PM #1
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
Ignition Issues - After driving through deep water
2017 4Runner TRD ORP 50k miles.
Ran it through some deep water, then the temps fell below freezing. Started up ok the next morning but then 2 days later and now for the last 2 weeks sometimes it starts fine and then sometimes I have to move the key around in the start position several times to find just the right place for it to kick off the starter. Any ideas? Solenoid? I read some posts on older 4Runners that they took off the starter and replaced some copper contacts on the solenoid (apparently solenoid is part of the starter) to fix the issue. Or perhaps it is the ignition?
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 10-28-2019, 06:55 PM #2
iRide4Runner's Avatar
iRide4Runner iRide4Runner is offline
Real Name: Nick
iRide4Runner is on a distinguished road
Real Name: Nick
I had a similar issue last winter after getting into deep water out East. See if you can pull an error code but mine was having issues with the crank position sensor. Drove back home to Colorado and the dry air solved my problem lol. If it is indeed a crank position sensor error you can pull the cap, dry it out, and pop some dielectric grease in there.
iRide4Runner is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 07:16 PM #3
TEujunga's Avatar
TEujunga TEujunga is offline
TEujunga has a spectacular aura about TEujunga has a spectacular aura about
TEujunga's Avatar
Bad crank position sensor would cause "crank/no start," not "no crank/no start" as the OP describes.
If jiggling the key in the ignition is actually having an effect and isn't just coincidental, then the problem is in the ignition switch, and is unrelated to the water crossing. If the water crossing really is the source of the problem, then jiggling the ignition key should have no effect, and the problem is likely in the starter or solenoid.
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
TEujunga is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 10:40 PM #4
mteolus's Avatar
mteolus's Avatar
Sounds like the ignition switch. When I find out I'll let you know. Seems odd at 50k though.
Old 10-28-2019, 11:01 PM #5
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
I had a similar issue... deep water crossing... no problems... several on/off cycles with no problems cranking/starting. Then two days later it wouldn't turn over. Turn the key to On, and everything would be normal. Turn the key to Start and dash would go dark but nothing would happen. Sometimes after a couple of attempts, or holding the key to Start for many seconds (2-10), it would crank and light off with no problem. No real error codes. Took to the dealer, and they couldn't track it down, as it became intermittent (sometimes it would crank no problem the first time, and other times it would take 20 attempts... you can guess how it acted at the dealer... never a problem). It ended up 'fixing' itself after about two months. I replaced the battery, starter relay, and ignition switch, all with no improvement.
My guess at this point is that the dealer installed 'alarm' (I didn't pay for it, but the dealership installs them on all the vehicles as soon as they roll off the rigs), somehow got it's kill-switch relay funked up by the water. I want to go in and short out the kill-switch relay, as I don't know when it will give me all heck again.
Good luck, and let us know what you find.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 11:29 PM #6
mteolus's Avatar
mteolus's Avatar
Sounds like the exact same thing.
One other note, if you run through deep water and then it freezes, don't use your emergency brake. I put it in gear and it wouldn't move the next morning. Finally I gave it enough gas and it broke loose. Pretty loud pop.
Old 10-28-2019, 11:33 PM #7
CF_Machete's Avatar
CF_Machete CF_Machete is offline
CF_Machete has a spectacular aura about CF_Machete has a spectacular aura about
CF_Machete's Avatar
if its your starter, replace it with the FJ starter... pretty sure its water proof. had some friends that found that out the hard way.
Troner envy... the struggle is real!
CF_Machete is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 04:43 AM #8
Deep_palancar's Avatar
Deep_palancar Deep_palancar is offline
Deep_palancar will become famous soon enough
Nope. Same starter. Water will kill them.
Deep_palancar is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 05:01 AM #9
Place your finger on the starter relay while someone turns the key. If you feel the relay click when the starter does not engage, then the starter is probably bad. $160, two bolts, < 1 hr.
Old 10-29-2019, 07:07 AM #10
CF_Machete's Avatar
CF_Machete's Avatar
You're right. It was a a mod
Who has Scuba'd their starter? - Toyota FJ Cruiser Forum
Old 10-29-2019, 01:31 PM #11
mteolus's Avatar
mteolus's Avatar
Well damn, at least it is only $160. Seems like a big flaw if the starters are not waterproof. I wonder if Taco's have this same problem....
And everyone was concerned around here about Diff breathers when the starter seems to be the biggest issue.
Old 10-29-2019, 02:59 PM #12
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
it's mud that kills them, right, not just water? mud will also kill your alternator.
jhguth is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 03:12 PM #13
-E5J-'s Avatar
-E5J- -E5J- is offline
Real Name: J
-E5J- has a spectacular aura about -E5J- has a spectacular aura about
-E5J-'s Avatar
Real Name: J
Approximately how high is the starter off the ground in a stock configuration?
The real question is, what depth of water is too deep for the stater to become submerged? 12 inches, 16 inches?
2019 4Runner TRD Pro, Midnight Black Metallic - RCI Sliders & Aluminum skids, WeatherTech Floor mats all around, Toyota wind/bug deflector on hood
2016 4Runner XP, Magnetic Grey Metallic - Sold
2015 4Runner Limited, Classic Silver - Sold
2002 4Runner SR5 Sport Edition, Thunder Cloud Metallic Grey - Sold
-E5J- is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 03:49 PM #14
DeltaWhiskey's Avatar
DeltaWhiskey DeltaWhiskey is offline
DeltaWhiskey has a spectacular aura about DeltaWhiskey has a spectacular aura about
On a side note, ignition switch wear is compounded by heavy keyrings.
2019 SW TRDORP
DeltaWhiskey is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 05:13 PM #15
mteolus's Avatar
mteolus's Avatar
Water was up to the top of the back bumper (where the black plastic piece is right below the rear gate) and I have a 3" lift. I'll measure. So I guess the starter is lower than that or the wake made the water even higher than that. Seems like if Toyota put a snorkel on as a factory option they would upgrade the starter too but I bet not.
Anyone familiar with New Mexico, the creek crossing was at the beginning of the Goose Lake Trail in Red River which is very popular. The creek keeps getting deeper every year. My buddies stock Jeep Rubicon made it without any issues.
ignition , part , solenoid , starter , times
New ignition lock cylinder - won't engage ignition - 1996 base CanadaEh 3rd gen T4Rs 2 07-26-2016 03:18 PM
Key/Ignition Removal Issues jelleyman94 3rd gen T4Rs 4 11-07-2015 01:02 PM
93 4Runner radio issues and door actuator issues. 128keaton Classic T4Rs 2 05-10-2015 10:11 PM
Ongoing Spark Plug + Ignition Coil issues T4RTahoe 3rd gen T4Rs 20 10-18-2014 05:51 PM
Ignition Issues rayratliff Classic T4Rs 4 12-20-2013 02:29 PM
