Old 11-09-2019, 10:36 AM #16
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
Originally Posted by mteolus View Post
Sounds like the exact same thing.
One other note, if you run through deep water and then it freezes, don't use your emergency brake. I put it in gear and it wouldn't move the next morning. Finally I gave it enough gas and it broke loose. Pretty loud pop.
What's the latest status / findings?
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 11-09-2019, 01:37 PM #17
Mudballz's Avatar
Mudballz Mudballz is offline
Mudballz has a spectacular aura about Mudballz has a spectacular aura about Mudballz has a spectacular aura about
Mudballz's Avatar
☝️Yep update please
Mudballz is offline   Reply With QuoteReply With Quote
Old 11-26-2019, 03:05 AM #18
boyfester's Avatar
boyfester boyfester is offline
Real Name: Marc
boyfester is on a distinguished road
boyfester's Avatar
Real Name: Marc
Originally Posted by mo_mo View Post
I had a similar issue... deep water crossing... no problems... several on/off cycles with no problems cranking/starting. Then two days later it wouldn't turn over. Turn the key to On, and everything would be normal. Turn the key to Start and dash would go dark but nothing would happen. Sometimes after a couple of attempts, or holding the key to Start for many seconds (2-10), it would crank and light off with no problem. No real error codes. Took to the dealer, and they couldn't track it down, as it became intermittent (sometimes it would crank no problem the first time, and other times it would take 20 attempts... you can guess how it acted at the dealer... never a problem). It ended up 'fixing' itself after about two months. I replaced the battery, starter relay, and ignition switch, all with no improvement.
My guess at this point is that the dealer installed 'alarm' (I didn't pay for it, but the dealership installs them on all the vehicles as soon as they roll off the rigs), somehow got it's kill-switch relay funked up by the water. I want to go in and short out the kill-switch relay, as I don't know when it will give me all heck again.
Good luck, and let us know what you find.
I had the exact same problem with my '14 TE on the Mojave Road trail in CA. The deep Mojave River crossing at the end was up to the upper wheel well with my 2.5" lift and 255/75 tires, so I think it was about 36" deep. The truck made it through just fine and ran ok for 2 days afterward, but then continued to get worse every day. Finally, exactly one week later, the truck would not turn over. I could hear the starter "click" each time but it wouldn't turn over. After sitting for about 30 sec, I tried again and it lit up. I proceeded directly to the auto repair shop and dropped it off. They checked it out and replaced the starter and it now runs like a champ.
5th Gen TE, lifted and armored
boyfester is offline   Reply With QuoteReply With Quote
Old 11-26-2019, 09:36 AM #19
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Originally Posted by DeltaWhiskey View Post
On a side note, ignition switch wear is compounded by heavy keyrings.
Having been in auto parts for MANY years I've found this to be true.
Having a bunch of keys and/or a heavy fob accelerates wears the ignition tumbler and/or switch.
Each of my vehicles (7 of them) has its own key ring with just what's needed for that rig. In the case of my 68 F100 it uses 8 keys, so it uses 2 keyrings. My house keys are on their own ring (another 7 keys).
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 11-26-2019, 09:48 AM #20
Interesting. Sounds like the same crossing got both of us. Oddly enough, my starter never acted up by clicking (solenoid/power). It either engaged or didn't. Dealer couldn't duplicate, and it 'healed' up all on its own (been perfect for 8 months now).
Old 11-26-2019, 02:20 PM #21
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Exactly why I run discos on my keychains! Soon as it goes in the ignition, the rest gets removed. The only weight on my T4R key is the disco itself, the ring itself, a hitch pin key, and a driveshaft.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
ignition , part , solenoid , starter , times
New ignition lock cylinder - won't engage ignition - 1996 base CanadaEh 3rd gen T4Rs 2 07-26-2016 03:18 PM
Key/Ignition Removal Issues jelleyman94 3rd gen T4Rs 4 11-07-2015 01:02 PM
93 4Runner radio issues and door actuator issues. 128keaton Classic T4Rs 2 05-10-2015 10:11 PM
Ongoing Spark Plug + Ignition Coil issues T4RTahoe 3rd gen T4Rs 20 10-18-2014 05:51 PM
Ignition Issues rayratliff Classic T4Rs 4 12-20-2013 02:29 PM
