12-05-2019, 11:57 AM
Help a noobie out
Hey just purchased a 2019 SR5 RWD. I know say all you want just couldn’t justify buying a 4WD as I never will really have the time. I wanted to begin the process of modding and wanted to start with the lift. I love the look of the 4Runner and am looking into 285’s and SCS wheels. I need a lift to do this and as a daily driver can’t justify buying a $1000+ suspension system to drive to work and on the highway. I obviously want to save a bit of coin as well for other things like a Gobi and such down the road and just because of the wife. You know happy wife happy life. Drop all your suggestions below any help is greatly appreciated.
12-05-2019, 11:59 AM
Tip number one - read all the stickies. Tip number two - read tip number one.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
12-05-2019, 12:06 PM
why lift, etc if you are never going off-road and have a 2wd?
12-05-2019, 12:12 PM
1. Would prefer not to have to chop my car in all sorts of places to fit room for tires
2. I really like the look of the lifted 4Runner
That’s pretty much it. I want it to look bada** and I don’t think it can if it stays at stock height
12-05-2019, 12:24 PM
If you are going to get SCS wheels and 285s, you will have to do some body modifications. Could be minor like mine (fender liner mod and a small bit of front bumper trimming) or it may need a body mount chop. Without aftermarket upper control arms probably both.
So if I were you and you want to go on the cheap, find some deals on TRD Pro wheels (made by the same company as SCS but has a lesser offset, wheels won't stick out as much so less likely to rub) and get those. I have seen some Black Friday topics of people getting those for about $600. Then put 275/70R17s on them and get this lift from Toytec.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
12-05-2019, 12:31 PM
If you want a cheap affordable lift that will last a long time I would suggest either Dobinsons or Old Man Emu. Both have been tested for a long time in Australia and work well if you are on a budget.
I personally have a Dobinson's lift and have been extremely happy with it and most who have one are.
Here is a link a link with tons of pages of questions about their products. Just ask @DobinsonsMike any questions you might have, explain your situation, what you want to accomplish and he can point you in the right direction.
Dobinsons 5th Gen T4R Suspension options - lots of choices
2017 TRDOR, Dobinsons Suspension, C4 Fab Sliders, C4 Fab Low Pro Bumper, Extreme LED Bar in Bumper, RCI Skid Plates, ARB Diff Breather Kit, TRD Rims, Gobi Rack, Husky Liners
12-05-2019, 12:37 PM
it's a 2wd that will live on the highway, just throw some spacers on it and call it a day
12-05-2019, 12:56 PM
My first lift was as follows and I loved it price and performance wise: Bilstein 5100s front and back. Stock springs. Adjust the front to your liking and add a spacer in the rear.
Me being nit-picky but why skimp on the suspension that is going to effect your vehicle dynamics and stability but still spend $1500+ on a roof rack......
No to spacers even just for pavement pounding.
2018 TRD OFF ROAD
My Build
12-05-2019, 12:59 PM
Real Name: Micah
Real Name: Micah
If it's cosmetic only, check out the tire thread to see what size you can run without impinging then add spacer lifts if you want less than 2" or add Bilstein 5100s if you want more than 2".
12-05-2019, 01:04 PM
Just get the rims and upsize the tires to 275s and be done with it. Maybe spacers.
You sound like you don't want to dump a bunch of money into it. If you went with 285s:
* You'd need a lift (you can go springs+shocks+struts or just do spacers but a 2" spacer will affect ride quality)
* Will need an alignment after the lift
* Since you're going to try and save money, you probably won't get aftermarket UCAs if you're not getting a BMC (body mount chop). If you get UCAs at a later time down the road, you'll be paying for another alignment.
* You might need a body mount chop (won't know until you try)... consider testing fitting the tires that you have on if someone is nice enough to let you test-fit their set.
So, if you get a BMC, you won't need UCAs unless you want your caster at a specific angle. With 285s and stock UCAs, you probably won't get more than 1degree of caster.
If you're looking for a neat look on a budget, I'd get the rims, 0.5" to 1" spacers, and 275 tires. Note: With 275s, you can get a meaty tire look without a lift. Add spacers for more looks if you want.
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
12-05-2019, 01:38 PM
2 wheel drive aré plenty capable off road like getting to camping or fishing spots on forest roads. 5100 all around spc uca and pinch well mod.
12-05-2019, 01:43 PM
I'm 100% stock and and it looks badass. Well, it could be because I have the hood scoop.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
12-05-2019, 01:53 PM
Hood scoop adds horsepower, too.
12-05-2019, 02:19 PM
Only in the 4x4 ones.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
noobie here
02_SE_Runner_DAD |
3rd gen T4Rs |
11 |
04-02-2015 06:46 PM |
Nc Noobie
NcYota99 |
New Members |
3 |
05-02-2011 03:39 PM |
noobie help please?
r3d runner |
Classic T4Rs |
1 |
02-22-2011 04:22 PM |
noobie
mrnigel |
New Members |
1 |
02-02-2010 07:46 PM |
Noobie
NotoriousGT350 |
General Discussions |
10 |
01-09-2009 01:51 PM |
