Old 12-10-2020, 01:23 PM #46
firegod33r's Avatar
firegod33r firegod33r is offline
firegod33r is on a distinguished road
firegod33r's Avatar
Originally Posted by smeerun View Post
This video breaks it down real easy and is applicable to connecting any light setup with a button. I followed this video to a T and found success in wiring my raptors to a switch. Early in the video he goes over the wiring diagram.
How to Wire an LED Light Bar Properly (Project Night Light Episode 3) - YouTube
Sent from my Pixel 3 using Tapatalk
If I had the same harness it would make total sense.
firegod33r is offline   Reply With QuoteReply With Quote
Old 12-10-2020, 01:47 PM #47
smeerun's Avatar
smeerun smeerun is offline
smeerun has a spectacular aura about smeerun has a spectacular aura about smeerun has a spectacular aura about
smeerun's Avatar
Okay let me see if I am understanding correctly: The issue is that you do not know where the red wire coming from your switch goes to?
If that is the case, wire it to your fuse box (drivers side under the dash) using an Add-A-Fuse in the WIP (Wipers) fuse slot (use like a 5amp fuse). This only has power when the key is in the ignition or when the engine is running. This will give your switch LED's power and allow your switch (when enabled) to give the OK for your relay to draw power from your battery.
You can buy an Add-A-Fuse from any auto store for like $3.99. I bet if you brought in your harness that they would even crimp it for you if you asked.
FYI, for 5th gens you'll need the MINI Add-A-Fuse. To be specific, this is what you need: Advance Auto Parts - Down for Maintenance
[Smeerun's Build Log] - 2016 4Runner Trail Premium MGM w/KDSS
Exterior: Toyo OC A/T III 265/70/17 (TE Wheels) | Dobinsons UCA's + C59-302/GS59-700 Front + C59-500/GS59-705 Rear | C4 Rock Sliders | SSO Roof Rack | Ironman 8.5" Awning | Tacoma Low-Profile Antenna | Diode Dynamics SS3 Pro Fogs | CTH Folding Mirrors + LED Sequential Blinker Mirrors
Interior: VanTrue N4 3-chan Dashcam | Husky Liners Floor Mats | Canvasback Rear Covers | Blue Ridge "Attic"
smeerun is offline   Reply With QuoteReply With Quote
Old 12-10-2020, 02:02 PM #48
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Yes, that's what I said and he said it didn't work, which makes no sense to me.
If you took that red wire and ran to battery and the raptor lights were always on, then running it to something that was only hot when the vehicle is on should be your fix.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 12-10-2020, 02:38 PM #49
firegod33r's Avatar
firegod33r's Avatar
It did come with an ad a fuse so no issues there. So this goes back to my other question a few posts back...... essentially the blue backlight and the red would have to be wired together and into the add a fuse, so that the back light function works and also the switch now has power to trip the relay right?
Old 12-10-2020, 02:41 PM #50
firegod33r's Avatar
firegod33r's Avatar
When I connect the the red wire to the battery directly everything functions correctly except the switch turns on and off even when the vehicle is off, so you’re correct. I’m thinking maybe I did something wrong when you told me to connect the red via add a fuse, I’m gonna go re do it and try again.
Old 12-10-2020, 02:45 PM #51
pDubs's Avatar
pDubs's Avatar
Yeah, that's what I am thinking. If you hook it up to battery and the raptor lights can be turned on and off with the switch then that should be your fix.
I have an LED light bar that I have wired that way on purpose so I can push the AOB button if I need to light up campground or something I am doing without having to leave keys in the truck. While helpful, I have accidentally left it on and had to jump the vehicle after the battery died. LOL
2014 SR5P
Old 12-10-2020, 02:51 PM #52
smeerun's Avatar
smeerun's Avatar
And I think that this is one of the things firegod wants to avoid (although the raptor lights might take months to drain a car battery lololol).
@firegod33r
It sounds like you simply need to connect the blue/red together with an Add-A-Fuse into a the fuse box under the drivers side dash into a fuse slot that ONLY gets power when the key is in or the engine is on.
Again, I recommend the fuse slot called "WIP" which is power for the wipers which is a fuse slot that only gets power when the key is in of the engine is on.
Old 12-10-2020, 05:08 PM #53
firegod33r's Avatar
firegod33r's Avatar
Thumbs up
@firegod33r
I will do just that. Thanks everyone
@smeerun by the way...I’m following your build... Very nice and detailed man. Keep up the good work
Last edited by firegod33r; 12-10-2020 at 05:31 PM. Reason: Autocorrect is killing me.
Old 12-10-2020, 10:54 PM #54
smeerun's Avatar
smeerun's Avatar
Thank you!
Post some pics of your lights when they're all wired up
Old 12-11-2020, 02:18 PM #55
firegod33r's Avatar
firegod33r's Avatar
Thank you!
I will definitely post a pic or two when its done
Old 12-11-2020, 10:27 PM #56
youngwas's Avatar
youngwas youngwas is offline
youngwas will become famous soon enough
youngwas's Avatar
【55】Raptor Grill Lights ‣ Smoked Black Amber [4K]
This is the video I made installing Raptor Grill Lights. I used fuse adapter to plug directly to the fuse box because I like it ON when the car is on. It looks amazing and not that expensive to MOD. I recommend it. =)
2017 4Runner TRD PRO Cement
youngwas is offline   Reply With QuoteReply With Quote
Old 12-11-2020, 11:04 PM #57
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Nice vid.
That cover is called a Sight Shield, the clips are called Sight Shield Clips. You don’t just put a screwdriver under them and pop them off.
You press the middle of them and release them and they come out with your fingers!
That way you won’t break them!
Best Regards,
Saker
Old 01-09-2021, 04:32 PM #58
Tymck Tymck is offline
Tymck is on a distinguished road
I just wired my raptor lights up to a switch (“Sasquatch Lights” bc there was no raptor or marker lights option) from aironboard.com.
I also used a relay wiring harness I got from Amazon that people buy aftermarket for light bars ditch light etc.
Took me a while to figure it all out bc I had to cut and splice and modify the relay harness to fit my needs. I also didn’t want it powered directly from the battery (+) terminal because I feared I’d forget to turn the switch off after leaving my vehicle and either they would remain on or the small light in the switch itself would still be lit up.
So I wired the positive red power in to the add a fuse (came with raptor lights) that goes to the 10amp ENG fuse in the engine bay. Now switch functionality and light only work when engine is on.
Attached is a drawing of how I wired, cut, and modified everything. Hope this helps people that want a switch option for lights and also don’t want them to always have power even after car is turned off.
I am by no means an expert, this is just what I figured out after watching a bunch of YouTube videos and reading the forums. Do the same at your own risk! Haha, but really it works, wasn’t to hard, and I think it’s a safe option.
Wiring raptor lights to button?-df203c50-d998-4627-b913-0eba408c46aa-jpg  Wiring raptor lights to button?-f28ad2d0-83d1-4cfd-8a6a-5d26bb028cd0-jpeg  Wiring raptor lights to button?-929e29b5-52b5-4a0d-b04c-83bc3ebe38ad-jpg
Tymck is offline   Reply With QuoteReply With Quote
Old 03-26-2021, 02:12 PM #59
firegod33r's Avatar
firegod33r's Avatar
It’s funny because I have the exact same wiring harness, but still can figure out what to do with the extra RED lol
Is have a white from the relay to the original Amazon button, but then end up with a ground and red out of the white connnector?..
Wiring raptor lights to button?-caa447de-24c5-4a68-bda1-6d9b50106669-jpg
Old 03-26-2021, 09:54 PM #60
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
these work great and make all future accessories a breeze to add on. I have one and it works great.
Amazon.com: Auxbeam 8 Gang LED Switch Panel Automatic Dimmable Slim Touch Control Panel Box with Harness and Label Stickers for Car Marine Boat Caravan - Green Backlight: Industrial & Scientific
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
button , lights , link , raptor , wiring
Wiring for raptor headlights Kyngfish 3rd gen T4Rs 7 09-21-2021 11:36 AM
Has Anyone Tried These Raptor Lights? zw470 5th gen T4Rs 120 11-13-2020 11:52 PM
Raptor lights!! Lets see them! Zeke588 4th Gen T4Rs 5 03-08-2019 02:34 PM
Grill/raptor LED light wiring w/pictures Logan6 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 12-15-2017 11:19 PM
