Aiming Baja Designs Squadrons
Chilow
Tried searching, but didn't find any info on aiming the Baja Designs Squadrons in the fog light location. When mine are on, it looks like it's above the headlights, but the angle of the squadrons appear to be "level" if that makes sense. Doesn't look like they are pointed in the upward direction at all. Can these be aimed?
I just did the same thing. What I ended doing was mount the lights as if your going to button everything up. I left the Allen screws a little lose. Then just push/ aim them down and tighten Allen screws to your liking.
It does create a gap but it’s lowered
The WC lenses work great when used off-road though, which is where they're meant to be used.
If you're using them on the street, you should look into their SAE model or morimotos, or TRD Pro LED fogs.
