08-25-2020, 07:29 PM
#106
Mine was when in gear with ac running. Specifically in reverse. Here is a video of it.
August 25, 2020 - YouTube
Sent from my SM-N970U using Tapatalk
14' 4runner SR5 4x4, Baja Designs Squadron Amber Fogs, Dual Battery, Icon Extended travel CO, Icon tubular UCA's, RCI Skids, Custom Sliders, Icon 2.5 RR Shocks, OME 2895e, custom aluminum cargo area, Dometic 50 fridge, front runner fridge slide. Relentless fabrication LOPRO, Expedition one rear bumper with swingout. Build Thread
08-25-2020, 08:02 PM
#107
Originally Posted by TrailRunnin14
Is it making any noise at all? Any vibrations when fully cranked with the A/C compressor kicks on?
No. Nothing crazy but it has some vibration only when A/C clutch kicks in and last for 2-3 seconds. In gear or while driving nothing at all.
08-25-2020, 08:07 PM
#108
Wow! Just watched your video, really bad, mine don’t do nothing close to it. Glad you solved that problem!
08-25-2020, 11:54 PM
#109
WTF Magnuson they look exactly the same, I hope something is different internally in this one. I’ll come back with an update after I’m done replacing my water pump.
Mods are loading.......
08-26-2020, 03:01 AM
#110
What the heck, I hope it works out for you. I wish I knew what tensioner I have then.
08-27-2020, 09:42 AM
#111
Sent email to Magnuson pic of your tensioner was included. Trying to get logical explanation why people are getting different looking tensioner with the same part # . Hope they can clear that for us.
08-27-2020, 12:56 PM
#112
I got a response yesterday from Magnuson over my concern of the tensioner issue. I sent them pics of mine and they are sending me a new one. So it will be interesting to see which one I get.
08-27-2020, 04:31 PM
#113
I will say when I inatalled mine the overall thickness of the tensioner was less. I dont know if uou can see it in the picture but the black arm for the hose support had to be bent a little so that I could get the bolt started. The tension was definitely more than the other one, I used the same breaker bar on both and the new one was much harder to get the belt on.
08-28-2020, 07:58 PM
#114
Any luck man ? Because mine getting worse. Magnuson never got back to me.
08-28-2020, 08:52 PM
#115
Yes I have one on the way. I’ll keep you updated. I could probably give you a contact if you need one.
08-28-2020, 09:24 PM
#116
That would be great. Thanks
08-28-2020, 11:05 PM
#117
I sent you a PM.
09-01-2020, 06:25 PM
#118
Now to add a little more to this, here is what I received today from Magnuson.
09-01-2020, 11:43 PM
#119
Maybe we are looking at this all wrong. Maybe I am the one who got the wrong tensioner?
At least yours has a different part number now. Maybe it will be better.
09-02-2020, 06:09 PM
#120
Real Name: Pak
Real Name: Pak
Originally Posted by Paragon1
mine has been fantastic since day one, apart from the coolant hose rubbing against the belt and getting cut, but the dealer fixed that. Hopefully they'll figure it out.
this happened to me today too. I was freaking out because coolant was all over the place. What was the fix? If i put it close to one side itll be too close to the fan and if i put it the other side itll be hitting the belt.
2015 Toyota 4Runner Trail Edition/KDSS, SCS Stealth BR6, C4 rear bumper ,Relentless front bumper ,RCI under armor, 4.88 gears, dual battery, iKamper rtt
