Originally Posted by RO1973
I've been using these guys for a long time with zero issues. I'm genuinely curious why you say that? Were they not supposed to use balancing beads?
Thanks.
From my understanding, beads/Equal are for specific applications like 18 wheelers. You should not have to use them in a tire of this size or a normal road going application. I've only used them in offroad applications where I had bigger tires and had to drive on the road too. I've even used airsoft BBs and they worked. Was actually kind a fun listening to them hit the rim as I came to a stop. Either way, I used them as a much cheaper and easier alternative to my tires going out of balance every time I knocked a wheel weight off or if I ever blew a bead while aired down, but it wasn't the "right" way.
I could be wrong, but I don't think the imbalance just goes away. The beads just pick up the weight differences from inside the tires as the tire creates centrifugal force as it rolls. Essentially, it's putting a band aid on the real problem of a bad tire, the mechanics balancer is broken, or he doesn't know how to use it.
I guess my point is that I am surprised a shop would resort to using such balancers on this application rather than finding the real issue.
