Old 04-16-2020, 06:49 PM #1
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Dobinsons Rear Drawers - 5th Gen 4Runner
Hey guys, here's an official thread for the Dobinsons rear drawers that go into a 5th Gen 4Runner. These have been around for about 3 years now, but I've never put a dedicated thread together for them here.
Here are a few quick Q&A that people always ask.
  • Yes, you can get the drawers only without the side wing panels
  • They are only intended for a standard model without 3rd row seats
  • 3rd row seats actually have a different floor, so a custom frame would be needed
  • Works fine with OE sliding floor once it has been removed
  • The sliding fridge latch was updated in early 2019 - uses the same as a regular fridge slide now
  • Only the left side can slide, you can't change it to the other side
  • The carpet is a dark grey or black with light speckles throughout. It appears different in different light
  • These have to ship by truck freight on a pallet so they don't get damaged
  • The drawers come fully assembled, but the stops that hold the drawers into the outer case aren't installed until the very last step. Be careful when you first get them, the drawer will come all the way out!!!
  • All standard replacement parts are readily available if needed
  • The drawers each slide out about 2/3 their length. They can't come out 100% due to the leverage it would make against the main cabinet and the mounting bolts
Here are the standard list of specs that apply.
  • 1.6mm Zinc Plated Robust Steel Construction, 12mm Heavy Duty Plywood tops
  • Panels with Marine Carpet Covering
  • Built-in Heavy-Duty Fridge Slide, 8 x Heavy Duty Stainless Steel Tie Down Points
  • Comprehensive outer wing trim kit to provide a factory fit.
  • Installation of drawers REQUIRES drilling and bolting through floor. Any existing sliding deck must be removed prior to drawer installation.
  • Aluminum Edging Protection, Heavy duty lockable latches. Sliding portion is not changeable from one side to the other.
  • Not compatible with 3rd row seat installed.
  • Massive 150KG (330LB) Drawer Capacity on Heavy Duty Roller Bearing System
  • Shipping is to the nearest Freight Terminal or to a Commercial address with a loading dock or forklift. Residential delivery adds additional separate costs
So the drawers are part number RD80-1001. Those can be ordered here without any side wing panels if you don't want to mess with those. Dobinsons 4th and 5th Gen 4Runner rear drawers only
The wing panels do add some cost to the full kit. The full kit can be ordered here: Dobinsons Drawers for 5th Gen 4Runner - Full Kit
If you don't add the side wing panels, the drawers can actually sit lower. Due to the high side plastic inner fender pieces, the drawers get raised up with spacers provided with the wing kit to clear those side panels. In my opinion, I prefer it without the panels, but you can order it whichever way you prefer.
Instructions on how to install these in a 5th Gen 4Runner are here: 4Runner Drawer Installation Guide
Some have tried to use turnbuckles from the floor up to points they have attached to the drawer sides, but if you bend out the drawer sides, you can change the tolerances and cause the drawers to have movement inside the outer cabinet. That's not a good idea. The drawers are closed extremely tightly, and require them to be slammed shut. This prevents any noises from coming from them.
I'll attach whatever photos I have saved of them from installs. If you own these already, please add your photos to the thread with any tips and tricks you figured out along the way or during the install.
Dobinsons Rear Drawers - 5th Gen 4Runner-4runner-drawers-jpeg  Dobinsons Rear Drawers - 5th Gen 4Runner-4runnerdrawersinstalled-jpg  Dobinsons Rear Drawers - 5th Gen 4Runner-5thgen4runner-jpg  Dobinsons Rear Drawers - 5th Gen 4Runner-5thgen4runner-b-jpg  Dobinsons Rear Drawers - 5th Gen 4Runner-5thgen4runner-c-jpg
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 04-16-2020, 07:20 PM #2
BWFBezerk's Avatar
BWFBezerk BWFBezerk is offline
BWFBezerk is on a distinguished road
BWFBezerk's Avatar
Any group buy or forum discounts available?
Sent from my SM-G988U using Tapatalk
BWFBezerk is offline   Reply With QuoteReply With Quote
Old 04-16-2020, 07:22 PM #3
Crikeymike's Avatar
Crikeymike's Avatar
Yes, you can PM me for the T4R discount. It applies to everything on my site
Old 04-18-2020, 06:32 PM #4
Crikeymike's Avatar
Crikeymike's Avatar
Starting a good discount on these until the end of this month (April 2020)
Dobinsons Rear Drawers - 5th Gen 4Runner-drawer-coupon-jpg
Old 04-18-2020, 07:18 PM #5
trey99ek trey99ek is offline
trey99ek will become famous soon enough
Ugh. And I just bought a roof rack. These would be nice. And a lift. And tires.
Sent from my SM-G960U1 using Tapatalk
2008 Sport Edition - GONE
2020 TRD ORP
trey99ek is offline   Reply With QuoteReply With Quote
Old 04-24-2020, 12:36 AM #6
avo1789's Avatar
avo1789 avo1789 is offline
avo1789 is on a distinguished road
avo1789's Avatar
You mentioned that "The sliding fridge latch was updated in early 2019 - uses the same as a regular fridge slide now"
What do you mean by "regular fridge slide". I'd love to see some pictures of the updated version!
Sent from my SM-N960U using Tapatalk
avo1789 is offline   Reply With QuoteReply With Quote
Old 04-24-2020, 09:36 AM #7
Crikeymike's Avatar
Crikeymike's Avatar
It can be seen in the photos above, but just barely. It's got a little yellow part on it. It's the same as the blue one in this fridge slide. You push it down to release the sliding top on the left side.
Dobinsons Rear Drawers - 5th Gen 4Runner-40-50l-fridge-slide-1-jpg
Old 04-24-2020, 01:30 PM #8
IL4runner IL4runner is offline
IL4runner is on a distinguished road
Free shipping?
IL4runner is offline   Reply With QuoteReply With Quote
Old 04-24-2020, 06:13 PM #9
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Sorry if I am missing this, what's the weight on these?
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 04-24-2020, 06:27 PM #10
Crikeymike's Avatar
Crikeymike's Avatar
It's 125 LBS
Old 04-24-2020, 06:28 PM #11
Crikeymike's Avatar
Crikeymike's Avatar
Originally Posted by IL4runner View Post
Free shipping?
No, I'm giving $150 off until the end of this month though.
Old 10-28-2020, 12:06 AM #12
Toyota619 Toyota619 is offline
Toyota619 is on a distinguished road
Was getting ready to order some drawers and side wings for my 5th gen any chance there is a discount code still available
Toyota619 is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 10:38 AM #13
Crikeymike's Avatar
Crikeymike's Avatar
Just about to do a sale for all of November.
Check out the details on the top page of my site
Dobinsons 4Runner Drawers for Toyota 5th Gen 4Runner (2010-2020)
Old 11-11-2020, 05:53 PM #14
Crikeymike's Avatar
Crikeymike's Avatar
The month-long Black Friday sale is up and running and quite a few people have new drawer kits on the way to them already. Details are in my signature about the sale.
Old 08-31-2021, 06:38 PM #15
edepinto edepinto is offline
edepinto is on a distinguished road
Dobinsons install with turnbuckles
Thanks for the pics and info on Dobinsons. Noticed the pic with turnbuckles attached to existing tie-downs. Wondering if you could share the install portion with that vs drilling, etc...
Appreciate the assistance!
edepinto is offline   Reply With QuoteReply With Quote
drawer , drawers , panels , side , wing
FS: Dobinsons drawers for 4runner bmrplatinum For Sale: T4R Items 12 02-15-2020 12:17 AM
FS: 5th Gen Dobinsons Drawers - DFW Kfog375 For Sale: T4R Items 0 09-07-2018 04:20 PM
2014 4Runner Rear Storage Drawers sch0enne 5th gen T4Rs 23 11-19-2015 08:24 PM
