04-22-2020, 11:31 PM
#16
Originally Posted by honda250xtitan
uh by that logic there is no reason for valving in shocks if you think the spring does it all.
Valving is for dampening, not lift.
04-23-2020, 10:24 AM
#17
no. valving is for rebound and compression.
04-23-2020, 10:50 AM
#18
Well I just ordered an awning from them and the quick release mounts from them. We'll see how it goes. I didn't even try the code. Ordered before the code was posted but good prices. We show see if the quality is good.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
04-23-2020, 02:26 PM
#19
For dampening of rebound and compression.
05-05-2020, 06:06 PM
#20
These came in
Untitled by redrunner87, on Flickr
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
05-05-2020, 06:46 PM
#21
Originally Posted by RedRunner_87
Only doing one side for comparison sake?
05-05-2020, 06:49 PM
#22
UCA look cool. Not sure about those green springs though.
05-05-2020, 07:07 PM
#23
It will definitely look interesting with my red 4Runner. But it is distinctive.
Are you supposed to do it another way?
5th Gen Build
05-05-2020, 08:09 PM
#24
those shocks aren't extended? are they held compressed?
05-05-2020, 10:18 PM
#25
They are 'foam cell' shocks, not 'gas pressurized' shocks. The foam cell (a closed cell rubber with trapped gas in the closed cells) acts as an accumulator (spring), and traps the gas within the foam such that it cannot go into the oil solution and create foaming/aeration/cavitation. Pressure is built up in the shocks with heat, but this compress the rubber foam cell. Since they don't have a nominal gas pressure, they don't extend on the bench.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
05-05-2020, 10:26 PM
#26
This is how they came in the box, I am not concerned about them. Many people I have talked to running the kit swear by it. It is obvious you don't like the concept of these shocks, which is fine. I bet you keep posting here, but have yet to email them any questions you have. Kind of funny you keep stopping by here to side comments on a suspension you will never run.
5th Gen Build
05-05-2020, 11:23 PM
#27
I have a red 4R as well, grab some pictures when you have a chance, interested in the kit with the UCA’s as well.
05-06-2020, 10:06 AM
#28
if it's funny than i'll continue
it's an open forum, people can comment all they want, just because i'm questioning it doesn't mean i'm not allowed to comment.
you're right, i'll never run a garbage shock setup like that.
05-06-2020, 11:33 AM
#29
The gas in every shock is necessary to accommodate the change in internal volume that results from the shock shaft. The internal volume of of the fluid reservoir is reduced by the volume of the shock shaft as it compresses. Without a gas chamber all shocks would basically act as a fixed length linkage and would not move at all, or they would rupture.
The goal then is to use a the gas to allow for volume changes while not mixing with the oil. Gas and oil foam doesn't create the same resistance to flow through the valves and the dampening goes out the window. So there's a few different ways to keep the gas and oil separate. One way is to use a floating piston in between the gas and oil (how it's done in monotubes - either inside the main body as an "IFP" or in a reservoir - same thing, different location. The only real function of the reservoir is to provide more volume of gas for less change in internal pressure through the stroke of the piston) and the other most way to separate the gas and oil is a rubber bladder or bag of gas (how it's done in most twin tube shocks).
The foam cell is basically the same thing as a bag of gas - just a lot of little bags of gas. It provides the same function as a floating piston and air chamber or the rubber bladder. The unknown is how long the foam lasts, how many cycles it can handle before breaking down, etc.
The reason you pressurize a monotube gas chamber is because you need to maintain positive gas pressure through the entire stroke of the shock. Even at full extension you want plenty of gas pressure inside to make sure that the floating piston is being pushed against the oil on the back side. That keeps the oil on the oil side where you want it. The seals are not designed to handle a scenario where there is a vacuum created on the air chamber side - gas will be pulled through the seals to the oil side. The pressure also helps to keep the oil from foaming or boiling at higher temps - but that's pretty rare if not impossible in a 4Runner. All oils will have some suspended gasses in them that would tend to off-gas at higher temps. More pressure helps prevent that off-gassing, but it's a pretty minor issue in a 4Runner and generally not a big issue in most applications anyway. There's basically no way you can push one hard enough to overheat most shocks. The self contained air bladders in typical twin tube shocks don't have that same issue. Nor does it appear the foam cells do. They can expand and contract without as much initial gas pressure required.
If the foam lasts a long time and doesn't break down or rupture the cells, it should be a fine way of making a shock. And it could be used just as easily in monotube by using a block of foam instead of the gas and piston design. The most obvious downside I see is that the foam probably has some limits on expansion and contraction volume. So the shock shaft will be limited in diameter as a result. That's why they use a pretty small piston shaft. An IFP design can accommodate a much larger piston shaft's volume displacement. That's why you'll see much larger heavier shaft and pistons in a race type shock. - Does that matter in a 4Runner that has 8 or 9" of suspension travel? Probably not at all. I've never seen a broken shaft that wasn't the result of a spacer lift causing a bottom out.
The shock shaft diameter beomes a lot more important on a 40" long extended shock (it has to do with the thin column issue - the longer it gets the less force it takes before an out of plane failure - bending under compression or collapse- is expected). That just isn't really an issue with the short travel suspensions we have on our 4Runners.
05-06-2020, 12:15 PM
#30
Ouch why the animosity?
