Need New Tires
scotsman
I need to get new tires for my TRD Pro and I will admit I'm a bit of a poser in that it probably will never go off-road but I do like the appearance of a bigger tire. What do you recommend for that bigger look but not needing the ruggedness of say a KO2?
I would get a good street tire, but just bump it up a size from stock. You probably don't want any weight that you don't need. 275/70/17 will fit fine with no rubbing, but will give you the size you're after. Michelin defenders have been great on my wife's car.
This is assuming you're not dead set on an AT tire, even though you don't need it.
If it's appearance you're going for and not going off road, then Ridge Grapplers in a passenger load seems like the best choice IMO. Ridge Grapplers come in passenger versions in 265s and 285s depending on the size you want. I think the 265s still measure a bit larger than factory 265s.
Hope you don’t go thru what I just did. I have 2020 Pro and tried 10ply Falken in stock size. Love the aggressive look. Problem could not get them balanced. I had them mounted on my new SCS wheels and between 50 and 60 wheel shake. Tried another set same thing. Had them switch to the 4ply Falken same thing. Had them put back on stock Nitto Terra grapplers G2’s. Steering wheel no shake. Can you believe that. I was not going thru getting them road force balanced. There are posts on where guys tried that and still did not work. Just a little info.
I can believe it. I've never owned a Goodyear tire I liked. Sumitomo was in business for several years with Goodyear. Sumitomo is the parent company of Falken. I felt it was likely that some of Goodyear's poor quality might have trickled down...
Recently a buddy of mine and manager of a national tire chain told me his company has had lots of problems with Falken tire uniformity.
Based on his recommendation for a moderate A/T, and my own research, I went with the Yokohama Geolandar A/T G015. It is as quiet as the Dunlops that came on my 4Runner, but these are much better in the rain, snow, and the trails it's been on since they were installed. Much better in the rain than the KO2's I had on another vehicle.
No vibration or shimmy up to 80 mph. They are a firmer ride than stock being LT265/70R17 E, but it doesn't bother me.
Falken Wildpeak AT3 plus added benefit of 3 peak snow traction.
For what it’s worth, I’m on my second set of Falkens with no issues. They do tend to take more weight to get them balanced compared to other tires though. Back in March I had a mobile guy come out and transfer the tires from my factory wheels to a new set of FN wheels and he confirmed the same thing. He said they sell a bunch of the Nitto and Toyo tires and they usually don’t take much weight to get them balanced. When these Falkens are done, I’ll probably try something else.
I ran 265/70R17 in E load on my previous 2016 4Runner and always had balance problems. I honestly lived with it since I liked everything else about the tire (rugged as hell, great snow performance, good looking, good price), but I'm seriously considering avoiding Falken this time around since looking back on the whole thing having to have tires re-balanced constantly and never being quite right was really frustrating. I actually was also running SCS wheels at that point (plan on keeping with the stock TRD Pro wheels this time around).
I probably had Discount Tire re-balance my Falkens at least 3 or 4 times, and every time I felt like they were better for a few thousand miles and would then start to degrade again...
Thanks, It don’t make sense. I have never had a issues with tires on my Toyota’s getting them balanced. Brand new SCS wheels. 2 different sets of 10 ply for the front no good. And tried 4ply no good. The 4plys took less weight. After putting the Nitto’s on no problem. Alignment would not cause this. Especially when I had no issue with my Pro factory wheels. And no issues with my new wheels. I know there are plenty of posts where guys fought trying to keep them balanced. To me it’s not worth the hassle.
To each his own I guess. I originally went with Falken Wildpeaks and seems everyone loves them. I had a bad experience with them though. They wore super fast and around 30K miles in they all started the brown blooming real bad and I replaced them.
I switched up the General AT2 which are being replaced by ATX. Had those on my last 4th Gen for 50K with 0 issues and when I sold it they still had a little less than half tread life left. My friend has the car now and said he has put on about 20K more miles and still loves the tires.
But I read bad stories on the General tires that worked for me and vice versa.
