07-09-2020, 03:29 PM
#61
Originally Posted by gibburnz
You can install the BSB with the sliding tray, it just won't slide anymore! The turnbuckles it comes with will extend that much further down and lock the box in place on top of the sliding tray.
True however I wonder if/how it effects figment being higher up like that. Seats may not recline all the way back (I don’t think I care about that?)
I may end up just removing the sliding tray and getting the standard carpet setup back there.
07-10-2020, 02:43 AM
#62
Originally Posted by Bronc
The right side lock rod fell out on mine as well, installed loctite. I contacted the company and they said that they would start applying loctite to the rods and fasteners. Also, check the central bolt that holds the lock arm in place, mine was very loose.
Sent from my SM-T813 using Tapatalk
Originally Posted by LA260
Anyone knows what's the max weight that can go in top?
Sent from my moto g(7) plus using Tapatalk
The right side of mine came loose as well. Fixed it with blue lock tite.
My wife (120 LB ish) slept on top of it last week. Didn’t even dent the top or flex.
07-16-2020, 07:10 PM
#63
If you ever remove the tray I’ll be willing to buy it from you.
10-17-2020, 06:52 PM
#64
Anyone install some type of layered foam insert into the dealers for your equipment? If so which foam?
10-30-2020, 03:36 PM
#65
www.johntrottocreations.com
2016 SR5 - Eibach Pro Truck Lift, Freedom Offroad UCAs, 255/75/R17 BFG KO2, C4Fab Lo-Pro Bumper, Smittybilt 9.5 Winch, Rocky Road Super Sliders, SSO Roof Rack, Boss Strong Box.
10-31-2020, 01:39 PM
#66
Nice job on adding the angle.
As well as sleeping area it will be easier to slide in "stuff".
Mike S.
2020 TRD PRO Army Green
2011 Metallic Gray SR5 3" Lift - SOLD
12-27-2020, 02:00 AM
#67
Real Name: John
Real Name: John
Had Box for over a year now 4th Gen
Merry Christmas gang.
I haven't been on the boards for a while and coming back to it.
BOSS strong box has been with me over a year now. It totally fits my needs for camping and outdoor gear.
As you know this is marketed to 5th Gen. however the dimensions fit the 4th gen as well. Mine is 2003 and measured the advertised dimensions and fits like a glove.
I added "beauty panels" to the Face to give it a clean, finished look. Made from Kydex, hot glue and magnets.
Hope it helps
trdxyr
12-27-2020, 02:01 AM
#68
Real Name: John
Real Name: John
Originally Posted by jtice
Nice work on the angle piece for support.!
trdxyr
07-31-2021, 08:40 PM
#69
Fridge slide?
Thanks for all these pictures, and for all these observations on the Boss box! I know this thread hasn't been active for a while, but thought I'd try asking a question anyway. Have any of you have tried putting a fridge slide on top of it? It's hard for me to tell how thick the top is. Seems like a tilting fridge slide on this thing would be a perfect setup for me... but only if that won't damage the box. Thanks!
07-31-2021, 08:59 PM
#70
I figure it would hold up just fine, just have to get the force distributed on a large area.
You could used very large washers, or better yet,
For added strength, you could always bolt the fridge rails down through the box, then through a metal bar inside the box,
Think of the bar acting as one long continuous washer for the bolts.
that for sure would be more than strong enough.
07-31-2021, 09:38 PM
#71
Thanks a lot for that info. Sounds like a good solution. If I end up buying this box and mounting a fridge to the top, I'll post a photo. This thing really is pretty close to what I was hoping to find. Still haven't ruled out building my own box (out of plywood), but I really like the idea of a metal box.
07-31-2021, 10:07 PM
#72
I thought about building one also, and even with todays insane wood prices it would still be cheaper.
But I hate when a box itself takes up space, The metal boxes tend to have more storage per their size, since their walls are very thin.
Plus this box was basically what I would have built, I really like the fit and how they designed it, so just went with it.
I store my fridge on my rear driver side seat, folded down.
This keeps it lower in the vehicle than on top the box.
07-31-2021, 10:25 PM
#73
Sounds like that works well. I've barely started my modifications, so I still have a lot of thinking and measuring to do. You're right about the metal box probably being a more efficient use of space than wood, in terms of storage for size. Also, the single-drawer design (rather than multiple drawers) maximizes usable volume. I like the design, too.
Turns out Trail4runner wrote another great article, which I found after asking my fridge question--the fridge in the article is even the very same fridge I have! There sure are lots of resources in the 4Runner world.
07-31-2021, 10:34 PM
#74
Some of the multiple drawer setups are sweet, BUT, there is SO much wasted space with the extra walls and rails.
I like how these boxes have the one thin divider down the middle, taking up no extra space.
And if you wanted to, Im sure it wouldnt be too hard to fab some other dividers and bolt them into the boxes one hug drawer.
Nice on the writeup, looks like that should work out great then.
08-01-2021, 04:25 AM
#75
Real Name: Ryan
Real Name: Ryan
LOL… I saw this email pop up and I figured I’d share the article I wrote but you beat me to it. Glad you enjoyed it!
Mounting a Fridge Slide Bracket to the BOSS StrongBox Drawer System
2011 Trail Edition. Black. '17 RRW RRH-6's. w/285 KO2's. Rago molle panels. C4 Fabrication lo pro with 25" Xtreme LED, Smittybilt X20 winch and Agency 6 fairlead/shackle. RRW V3 rock sliders. TRD front skid. Spidertrax spacers. Gobi Stealth rack and ladder. ARB Safari snorkel. AnzoUSA 14+ tails. Blacked out projector/retro-fit head lights. Baja Designs pro fogs, S2 ditches and rear dust lights. Eibach 2.5" lift w/ ICON delta joint UCA's. C4 dual-swing rear bumper.
Check out Trail4Runner.com for more Installs and Write-Ups. Find my author link here.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
