kaitlyn2004
Instead of an elevated sleeping platform, I'm looking into making a gear SHELF above the sleeping floor.
Could I for example run plywood on supports across, resting on those elevated mouldings (yellow dots) - can those side pieces support weight, or are they hollow and/or risk damage to whatever is under/behind it?
Similarly, could I "build up" a raised support from the blue dots? Similarly, with the support beam and weight on it, is this fine or would it punch through whatever is there?
Attached image for reference
