03-16-2024, 09:36 AM
#46
Get a 4R TRD ORP W/ KDSS night and day difference with on road handling.
03-18-2024, 04:54 AM
#47
Would it be practical to install a KDSS upgrade to my 2021 SR5, or is this a "cheeper to buy a new 4Runner with KDSS" situation?
I did a little reading about KDSS and it looks like a big upgrade with lots of parts/ labor.
03-18-2024, 04:22 PM
#48
KDSS is not something you are going to be able to add to a 4Runner.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
03-18-2024, 04:43 PM
#49
With the high resale values these 4Runner’s have, I’d definitely sell yours and buy a new 2024. In addition to the KDSS option, you would be getting what is likely the last year of the current model. If you upgrade from SR5 to Off Road Premium you’ll also get Softex seating, LED lighting, and heated seats & steering wheel.
If you’ve done mods to your 2021, it’s likely most would be compatible with the 2024.
03-20-2024, 09:36 AM
#50
Thank you all for the advice but it appears that buying a new KDSS equipped model would cost me around $15,000. That's a lot of money (for me) to spend just to get a truck that tracks better. I've owned a lot of 4x4 vehicles over the past 50+ yrs that didn't require a special suspension to drive on paved roads.
Changing the caster adjustment helped a lot. Since I don't need the flotation provided by the factory tire size. I'm looking at going to a 235/80/17 tire.
That may help the chasing the cracks in the road feeling.
03-20-2024, 12:46 PM
#51
OP, I think you might want to differentiate between "steering feel" and "self-centering." I believe what you're looking for is more of the latter and that can be improved (somewhat) by an alignment with 3.5 - 4.0 degrees of caster. The "feel" is somewhat baked into the steering system components and is much more expensive to alter.
03-20-2024, 02:38 PM
#52
Get a suspension lift kit. It might help
03-21-2024, 08:40 AM
#53
The factory size is considered a flotation size? I don't think so.
03-21-2024, 10:18 AM
#54
What size tire provides flotation?
The present size tire does provide more "flotation" than the 225/75/R15 that Toyota used to put on 4Runners.
Everything is relative, it depends on use. You need more flotation on sand than you do on asphalt.
I'd say we have a difference of opinion based on our use and personal experience.
03-21-2024, 11:36 AM
#55
A few things. 1) I don't find that a narrower tire helps with teh tracking feel. 2) If the truck isn't tracking well down the highway or you have cracks and uneven pavement pulling you a lot, you need more caster. 3) One thing you can change, relatively cheaply, to stiffen up the ride, is to use a digressively valves shock like the Bilstein 5100. These shocks provide more resistance on smaller bumps and less on larger bumps. This leads to less body roll in curves on the highway, at the cost of a slightly bumpier ride on dirt roads.
03-21-2024, 06:52 PM
#56
Agreed. I'm thinking that if one were to buy a flotation tire for a 4Runner application, the stock size would not be what they'd choose.
03-22-2024, 06:41 AM
#57
All can say is after driving Jeep Wranglers and Unlimites over the years my new 2024 is so superior driving, it's like floating on air. If you don't like the way the new 4 Runner drives, you best stick with 2 WD models.
2024 4 Runner Premium TRD Off Road
03-22-2024, 10:17 AM
#58
Why, does a 2wd 4Runner drive better?
I don't need to float on air, I'm just trying to improve a truck that is a pretty good fit for me other than it's hwy handling.
Changing the caster setting helped a lot, I'm just looking to see if there is another simple fix.
I suspect that the majority of 4Runners never see off road use, but their owners have other reasons to own a 4wd. I used it yesterday to back a trailer up a gravel driveway which I could not have done with a 2wd.
Everyone has different needs. I buy what works for me and what I can afford. A new Suburban may have been a better fit but the $20,000 difference in price was not.
If someone feels the need to modify the suspension or up their tire size do you recommend they buy a Humvee?
03-22-2024, 11:28 AM
#59
Well....I wouldn't describe it as floating on air but the driving experience is immensely better with the 4Runner than with a solid-axle Jeep. Still have my Rubicon but it is now relegated to Search and Rescue duties where the terrain is really difficult.
03-22-2024, 01:13 PM
#60
Originally Posted by rob_dixon
The stock 5th gen has very poor steering feel of the road, so its relatively easy to accidentally sway into other lanes.
I LOVE the 4Runner, but its my biggest complaint of the vehicle as it really could be a safety issue. If this could somehow be improved, I would invest a lot in order to do so.
My understand it the height is factor that causes this, (and of course the engineering in all the linkages) and it may be impossible to really improve it.
But I thought i would ask those who might be mechanically inclines and know the intricacies of this stuff.
Sounds like you need to take a driving school refresher, or buy a car with lane change correction sensors. Seriously, you are a danger to the rest of the drivers on the road.
