Jetboy
Quoting myself, as i did a search and found people explaining it way more. ANd the analogy is way better than my terribly unsafe example. ;-)
hyundai - what is exactly steering feedback? - Motor Vehicle Maintenance & Repair Stack Exchange
In auto parlance at the high end its called "Dynamic steering"
Dynamic steering varies the steering ratio by nearly 100 percent as a function of driving speed and the setting in the Audi drive select system in which it is integrated. Transitions are continuous and practically imperceptible.
This both makes the car feel more sporty at higher speeds and safer, while also making it easier to do things like parallel park or make a u-turn. Instead of trying to achieve the perfect balance of steering ratio and power steering assistance, these cars can vary it to give you the best of both worlds.
Hope that helps. Basically the 4Runner is poor at "steering feedback" and has no dynamic steering - this is what i want to improve as best I can for the near "perfect" vehicle
You can do a lot with a light duty car suspension that you can't with a vehicle that also has to be able to handle the type of abuse that a 4Runner is intended to. Everything on the 4Runner has to be much larger and heavier. The result is a relatively heavy feeling.
There are also geometry compromises that are inherent in off road vehicles. For example on most Audi models that use a design that locates the upper ball joint over top of the tire with a pivot axis that runs approximately through the center of the tire's tread. That means you can never put a larger tire on due to physical constraint. You can't do that on a vehicle where a large portion of customers are going to put larger tires on.
There are many more compromises for a big heavy SUV, but those are just a few examples.
My guess is that you'd probably solve most of your issue with a better alignment set to around 3.5-4* caster. For comparison example a typical sedan will often have a caster angle of around 7-8*.
