Old 07-24-2020, 07:46 PM #1
Jpilot Jpilot is offline
Real Name: Joe
Jpilot will become famous soon enough Jpilot will become famous soon enough
Real Name: Joe
Roof Rack and RTT install Completed
So, finally got everything buttoned up and the rooftop tent installed. Here is the series of photos as I went along.
The Rack is by NiseRack, @Eitek1 was kind enough (and smart enough) to design and make these available to us here.
His website is:
Shop | NiseRack.com
A good write-up of the rack is here:
5th Gen Aluminum Roof Rack Using OEM Siderails: NiseRack
And here is my build
Roof Rack and RTT install Completed-6f95a4c7-2bff-491a-8f72-f9aedaba833d_p-jpg
2015 T4R Trail Red, 3” lift, 285s, Niserack, HF rock sliders, BA bumper
2006 4runner sport, v6, Tacoma TRD springs front, airbags And 2” spacers in rear. 440k and still chuggin along.
1977 FJ40, V8, lifted, Warn 8274 winch etc.
2006 GX470, 285s, 2” lift, C4lo sliders
Jpilot is offline   Reply With QuoteReply With Quote
Old 07-24-2020, 07:50 PM #2
Real Name: Joe
Real Name: Joe
Started with the rack legs, they come with all the hardware. Only took about 4 days to arrive from NiseRack. Great job there.
Roof Rack and RTT install Completed-3ddfd160-500c-42a7-87c1-1d7030a10361_1_201_a-jpg
Old 07-24-2020, 07:53 PM #3
Real Name: Joe
Real Name: Joe
Pry the end cap off of the roof rails. I used a wide scraper to distribute my wedging load, so as to not dent the top of the truck. Worked well.
Roof Rack and RTT install Completed-b53e81f3-af09-4bca-9491-7be9e11fe446_1_201_a-jpeg
Old 07-24-2020, 07:58 PM #4
Real Name: Joe
Real Name: Joe
Then the brackets just slide into place. I ordered 4 "sets" of brackets, which will give you left and right brackets for 4 rails. I found if you loosen the bolt a little at a time, while you insert into the rail, it goes in well, and then you can tighten a bit by hand as soon as it is slid in.
Roof Rack and RTT install Completed-img_3209-jpeg
Old 07-24-2020, 08:00 PM #5
Real Name: Joe
Real Name: Joe
After all brackets are on (I had 8 for 4 crossbeams) , slap the covers back onto the rails and then attach the crossbeams. I used an old sweatshirt to hold the far side while the first went on.
Roof Rack and RTT install Completed-img_3217-jpeg
Old 07-24-2020, 08:04 PM #6
Real Name: Joe
Real Name: Joe
Once everything was on, I tightened everything up and was good to go. Great rack. Entire rack system was less than $300, so a big saving over a custom full or 3/4 rack.
Roof Rack and RTT install Completed-img_3220-jpeg
Old 07-24-2020, 08:07 PM #7
Real Name: Joe
Real Name: Joe
Rtt
Final piece to the job was the Roof-Top tent. I have a 23zero tent, soft shell, and absolutely LOVE it. Has been a great way to camp, get yourself off the ground and get some great sleep. Brackets fit really well over the 3' wide crossbeams and are solid. Tent pretty much goes from end to end of the factory side rails, so does not look out of place.
Roof Rack and RTT install Completed-img_3238-jpg
Old 07-24-2020, 08:09 PM #8
Real Name: Joe
Real Name: Joe
Final picture from the back.
Roof Rack and RTT install Completed-img_3241-jpg
Old 07-25-2020, 10:11 AM #9
Eitek1 Eitek1 is offline
Eitek1 will become famous soon enough
Awesome! Looks like a great fit. I’m really happy it worked well with your rooftop tent.
Eitek1 is offline   Reply With QuoteReply With Quote
Old 07-28-2020, 05:17 PM #10
jimgsmith jimgsmith is offline
Real Name: Jim
jimgsmith is on a distinguished road
Real Name: Jim
His website is:
Shop | NiseRack.com
Looks great! A couple questions. 1. How hard was it to bolt the tent onto the rack? I'm thinking clearance under the tent to attach the hardware. and 2. How high is the top of the tent from the roof of the runner? I'm wondering if it will fit in my garage.
Thanks!
jimgsmith is offline   Reply With QuoteReply With Quote
Old 07-28-2020, 07:39 PM #11
Real Name: Joe
Real Name: Joe
Thanks!
Tent bolts were about a 1 hammer difficulty on the “outside” bolts and about a 3 hammer difficulty on the “inside” bolts. Helps to have a family member with small hands and limber wrists to get the nuts started.
Tent sits about 16” above the rack. No way mine goes in the garage, but my 4R is also lifted with 285s.
Roof Rack and RTT install Completed-67b716b2-4f15-456a-9646-e85e5319fdfa-jpeg
Old 07-28-2020, 10:37 PM #12
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
It’s quicker if you pre-set the inside bolts, that way all you do is slide the bracket around and tighten the outside bolts only. If you ever take it off keep that in mind! Just undo the outside bolts! Hope that helps.
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 08-02-2020, 07:58 PM #13
Real Name: Joe
Real Name: Joe
Absolutely correct. We needed to set and capture on this install because it was going on a new size rack for the first time. From now on out, ‘outside’ nuts only and slide off.
Thanks
kind , make , rack , roof , smart
Front Runner full length roof rack. First production run rack install. Apex Overland 5th gen T4Rs 61 04-29-2023 01:46 PM
How to install roof rack crossbars x67934 5th gen T4Rs 104 02-10-2021 02:24 AM
Gobi Stealth Roof Rack!! Finally completed 991-GT3MJK 5th gen T4Rs 24 04-01-2017 10:47 PM
Transfer Case install (completed) few little things c0mmon 3rd gen T4Rs 4 11-13-2015 10:52 AM
Yakima Roof Rack install - but no tracks on roof! icdawg Engines / Suspension / Wheels / Tires / Audio / Accessories 2 01-20-2011 04:56 AM
